weld leaking on transmission pan.
by motor_oil_madman
02/07/16 03:41 PM
PP and Honda CR-V
by klt1986
02/07/16 03:04 PM
113,800 miles on plugs w/ pics - 2009 F150 5.4 3V
by 04SE
02/07/16 02:59 PM
Sludged 1zz-fe pic... Ex-fleet car.
by SanProsan
02/07/16 02:53 PM
Autozone oil score today
by jdavis
02/07/16 01:12 PM
Valvoline V0-88, 5,000 miles, CUT OPEN
by car51
02/07/16 12:27 PM
Timken throwout bearings?
by buck91
02/07/16 12:17 PM
Whole house water filtration types of set ups
by oilboy123
02/07/16 11:54 AM
QS Defy is now QS"high mileage"
by hjones
02/07/16 11:47 AM
TGMO came out reddish
by chiefsfan1
02/07/16 11:41 AM
Run Oversized Fram Ultra 25k & Multiple OCIs
by WillsYoda
02/07/16 11:35 AM
Rislone Zinc Additive
by hjones
02/07/16 11:34 AM
Compignite, pezman65, Wansu, DaleAZ, Nazmorgul
56846 Registered Users
107 registered (AndyB, 901Memphis, 2015_PSD, ABerns, 04SE, 9 invisible), 1719 Guests and 192 Spiders online.
56846 Members
66 Forums
244375 Topics
Page 1 of 2 1 2 >
#3309550 - 03/12/14 03:31 PM Gas coming out of tank while filling
Tom NJ Offline
Loc: Virginia
Two of the last three times I filled my tank (2008 Altima 2.5SL), the pump kept kicking off prematurely and gas was coming out of the tank. I had to fill the tank very slowly to avoid this. Any idea what can be causing this? It was three different gas stations.
Tom NJ
#3309557 - 03/12/14 03:37 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
Bob_E Offline
Loc: Long Island NY
I had a similar problem with my old Hyundai. In my case it was the EVAP purge valve. But it could be the vent line being clogged too or the charcoal canister
'12 Mazda6 2.5L PP 0W-20 & MC Fl-910s
'16 Hyundai Sante Fe 3.3L unknown
#3309558 - 03/12/14 03:37 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
K20FA5 Offline
Loc: Frisco, TX
My Nissan Frontier does this from time to time. I read somewhere that this might be caused by the EVAP canister? I'm wondering if it's a Nissan thing?
#3309559 - 03/12/14 03:38 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
Olas Offline
Loc: Manchester, England
I'll guess at the non-return flap in the filler neck sticking partly closed - fill too fast and the filler starts to overflow, fill real slow and the fuel has time to trickle through the small gap under the flap.
Or maybe the breather is blocked.
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3309560 - 03/12/14 03:39 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
Shannow Offline
Loc: Oz
I don't know for sure, but I've had a couple of cars which formed air pockets, and they would spit fuel out as the bubble escaped (think fish tank bubble pump).
If I found the right pump on the right slope, I could "overfill" nearly 10L from the manual.
Is there something on the evaporative emissions system that should be venting while filling ?
#3309561 - 03/12/14 03:39 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
123Saab Offline
Loc: PA
Happens on our 08 Liberty too, Chrysler does not think it happens.
Twenty-twenty-twenty four hours to go I wanna be sedated
Nothin' to do and no where to go-o-oh I wanna be sedated
#3309563 - 03/12/14 03:40 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
dparm Online   content
Loc: Chicago, IL
Certain cars seem to be worse at this than others. My mother's 2001 Infiniti I30t (basically a Maxima) was notorious for this at many pumps.
I think that it's a poor design of the valve in the filler tube in these cases -- it isn't sending the "shut off" to the pump nozzle.
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#3309575 - 03/12/14 03:52 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
salv Offline
Loc: Cadyville, NY
Canister is clogged or vent valve stuck closed.
2003 Trailblazer: Mobil Super HM 5w30 L25288
2000 Ford Focus Wagon: Mobil Super 5000 DW-5230
#3309623 - 03/12/14 04:35 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
jrustles Offline
Loc: Ontario, Canada
The only time I've had gasoline back up and shoot out the filler neck was in the USA, Sheetz I believe was the station. Has never happened to me in Canada. shrug
I was expecting the pump to click off when the tank gets full... apparently not.
Probably not the same issue you're having, but thought i'd mention it
Edited by jrustles (03/12/14 04:36 PM)
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3310134 - 03/13/14 03:20 AM Re: Gas coming out of tank while filling [Re: Tom NJ]
paulo57509 Offline
Loc: Tracy, CA
This started happening with one of my cars after someone tried to siphon the fuel out of the tank. During the attempted theft, they bent the feces out of the little nozzle flap so that it now just dangles inside the filler neck.
I have to hold the fuel nozzle by the hose an force it upwards at an angle to get the fuel to flow into the tank.
1987 Chevrolet Camaro IROC-Z 5.0L
1987 Acura Legend L Coupe 2.7L (5-Speed)
1992 Lumina Euro Coupe 3.1L
1998 Lexus LS400
2003 GMC Safari
#3310171 - 03/13/14 06:10 AM Re: Gas coming out of tank while filling [Re: 123Saab]
Pop_Rivit Offline
Loc: Midwest
My 2006 Durango was experiencing a similar fuel spit back issue. It was covered under an extended Chrysler lifetime warranty on the part, and I had it replaced a month or so ago. It hasn't happened since.
Interesting. When I researched the issue on my Durango everything that I read said that it also covered the 2008 Liberty-service bulletin 14-003-13. Why is it that Chrysler would issue a service bulletin and cover it by an extended warranty, while at the same time they don't think it happens?
#3310173 - 03/13/14 06:12 AM Re: Gas coming out of tank while filling [Re: Tom NJ]
MaxZX Offline
Loc: VA
Friend at work had a 2011 VW CC. Took 20 minutes to get 10 gallons in the tank. Turns out some vent tube near the filler neck was clogged. The air in the tank couldn't evacuate when gas was pumped in, so the gas coming from the nozzle backed up quickly, causing the pump to stop. The only way for air to escape was back up the filler neck, so gas had to be added very slowly to allow for that. No idea if your Altima has a similar set up. Google up a parts diagram of the fuel filler for your car, might give you a clue as to what's going on.
#3310304 - 03/13/14 08:40 AM Re: Gas coming out of tank while filling [Re: Tom NJ]
Tom NJ Offline
Loc: Virginia
Thanks all! I'll investigate the flap valve, venting system, and canister to see if I can clear the problem.
Tom NJ
#3310364 - 03/13/14 09:34 AM Re: Gas coming out of tank while filling [Re: MaxZX]
zzyzzx Offline
Loc: Baltimore, Maryland, USA
I was thinking that all cars had that second tube for venting purposes. My 1995 Escort does.
#3310452 - 03/13/14 10:58 AM Re: Gas coming out of tank while filling [Re: Tom NJ]
MaxZX Offline
Loc: VA
A quick google image search for that year/make/model filler neck shows it has a vent tube parallel to the filler tube. The vent looks to attach to the tank at one end and back into the filler neck a few inches down from the top at the other end (the end where the gas nozzle is inserted). Quite possible something is blocking that. I even saw pics of where spiders had nested in there and clogged it.
Page 1 of 2 1 2 >
