Brakes for 2012 Subaru Legacy
by Picky1
2 minutes 20 seconds ago
Microgreen Oil Filter 50% Off Discount Code
by kohnen
7 minutes 53 seconds ago
Don't believe the hype of "never change the oil"
by Fsharp
28 minutes 5 seconds ago
tzlk to me about aeroflot
by Jetronic
Today at 12:21 PM
My extended drain OCI did not go as intended...
by firemachine69
Today at 11:10 AM
Honesty
by stockrex
Today at 11:04 AM
Valvoline's New "Cobalt" Grease availability
by EdandSherry
Today at 10:47 AM
Mobil Delvac 1 5w40: where to buy?
by car51
Today at 10:38 AM
Honda EM7000is stored too long with fuel
by henni
Today at 10:04 AM
1967 Ford F250- cooling system flush w/ Cascade??
by ryanschillinger
Today at 10:02 AM
Oil for FTO MIVEC used on track
by Spetz
Today at 09:13 AM
[Cut Open] Motorcraft FL500S - 5316mi
by DuckRyder
Today at 09:04 AM
Jennyp, dcdodge, igolfat8, makomike, Alexas
58338 Registered Users
90 registered (arob85, 13Tacoma, 1foxracing, aquariuscsm, 09_GXP, 13 invisible), 2037 Guests and 11 Spiders online.
58338 Members
66 Forums
251102 Topics
Page 1 of 2 1 2 >
#3309779 - 03/12/14 07:07 PM How can a driveshaft become unbalanced?
Vstrom Offline
Loc: SC
Just went through a real trial with fixing a vibration that turned out to be the driveshaft on a 96 F350 long bed crew cab so it is a 2 piece shaft.
Vibration had been getting worse for some time...changed the center support, no difference. Replaced the U-joints, no difference. Spline joint good.
Took it to one driveshaft shop that was stumped...told me I just needed to replace the whole thing.
Took it to another one- they took off most of the factory weights, took off the rubber damped heavy steel ring on the pinion end and welded on a washer for a balancing weight on the front shaft.
Smooth as can be now..just can't understand how it can get unbalanced in the first place!
#3309789 - 03/12/14 07:20 PM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
ZeeOSix Offline
Loc: PNW
Good question. Maybe some factory balance weights flew off at one time? In order for the balance to change, the mass distribution needs to change.
A filter's brand name doesn't matter ... what's inside does.
#3309793 - 03/12/14 07:22 PM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
turtlevette Offline
Loc: Massachusetts
did they check it for straightness? If it got slightly bent it'd be off then a rebalance would compensate.
#3309809 - 03/12/14 07:41 PM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
lomez Offline
Loc: California
damaged/worn u-joints....but then you said you replaced them.
Have no clue then.
Edited by lomez (03/12/14 07:44 PM)
2003 Toyota 4Runner LTD 4WD 140,000
1969 Ford Bronco 351W
1965 Corvette (sold)
Jaguar XK8 (sold)
DL1000
CB750
KLR650
#3309812 - 03/12/14 07:41 PM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
GreeCguy Offline
Loc: Elderly County, Florida
Back in the day I had a '67 Chevy half ton truck that did the same thing. The two piece drive shaft had a support bearing in the middle and the rubber bushing that held the bearing in place finally wore out and fell out which caused the shaft to "sag" in the middle. I bought a used one at a junkyard for 30 dollars - popped it in and no more problem.
"Dyslexics are teople poo!!."
#3309894 - 03/12/14 08:49 PM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
Chris142 Offline
Loc: apple valley, ca
Usually they get bent. Maybe that rubber balancer they removed got a heavy spot or off center?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3309921 - 03/12/14 09:14 PM Re: How can a driveshaft become unbalanced? [Re: Chris142]
Kira Offline
Loc: Champlain/Hudson Valley
Your 18 year old, two-piece shaft and center bearing needed some TLC. What was the total?
There's a shaft shop near me and anytime you need to remove ANY shaft and bring it to them for service-it's a joy.
You know smoothness is in your future.
Glad you got it sorted. Kira
#3310124 - 03/13/14 02:21 AM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
Vstrom Offline
Loc: SC
The first shop told me I used [censored] U-joints, they were the best Moog offers. They also told me the center bearing, an Anchor brand, was [censored] and I HAD to use the OEM Ford bearing that costs 6x as much.
OK....the vib was the same before and after the U-joints and center bearing replacement. Beside that the OEM bearing is discontinued and no longer available from Ford. The original U-joints appeared perfect when removed and had no play in them.
I did replace the center bearing again with a Timken branded one that made no difference whatsoever.
No factory weights were missing. There was no visible damage to the shaft or any components. The truck has never been in an accident.
The shop that got it right said it was severely out of balance and really had no definitive answer as to why it was. They said a lot of towing caused it....huh?
Total at the shop was $250 to fix, that didn't include the $45 I spent on Moog U-joints and one $20 center bearing followed by another $45 center bearing. This was with the shaft removed and carried to them.
There is 200,000 miles on the truck and I am the original owner. There was a TSB shortly before my truck was built in the fall of 95 adding the vibration damper ring to the rear of the back shaft to stop a "moaning" noise some trucks had. So now mine is gone-
I may be hearing a little different noise but the truck is "noisy" anyway with the diesel and stiff suspension so it is hard to tell. The vibration is gone, which was at 35 and 65 MPH.
I'm happy but puzzled.
#3310132 - 03/13/14 03:11 AM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
paulo57509 Offline
Loc: Tracy, CA
My GMC van has a one-piece drive shaft and the R&R instructions in the FSM state to mark the drive shaft and companion flange before separating the two so that the drive shaft is replaced in the same orientation because the drive shaft and differential were balanced as an assembly.
I'm going to guess that the same might be true of your two-piece drive shaft. They might not be balanced with the differential, but their relationship and balance with each other was lost when the center support was replaced.
Edited by paulo57509 (03/13/14 03:13 AM)
1987 Chevrolet Camaro IROC-Z 5.0L
1987 Acura Legend L Coupe 2.7L (5-Speed)
1992 Lumina Euro Coupe 3.1L
1998 Lexus LS400
2003 GMC Safari
#3310190 - 03/13/14 07:01 AM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
Trav Offline
Loc: MA, Mittelfranken.de
In the salt belt a lot of drive shafts have severe rust and large rusty scales.
Its common they go out of balance, i always attributed it to that but who knows.
I have a local metal company steel shot blast them, then etching primer and paint, new joints and have them balanced by a reputable drive shaft company.
Cost is about $70 for the balance, $10 to blast them and whatever the paint and joints cost.
I usually have about $150- $180 into a totally rebuilt and balanced shaft.
The etching primer and high quality paint pays back in spades! One has been 7 yrs in the salt belt doing plow duty and still looks like new.
#3310219 - 03/13/14 07:30 AM Re: How can a driveshaft become unbalanced? [Re: Trav]
rockydee Offline
Loc: VA
That's a good idea. Can you pull the drive-shafts on a new rwd vehicle, mask off the joints and spray them with spray bomb primer and paint? Then chuck it all back together again. I'd rather do it before rust attacks rather than after if I can.
I like reading your posts, you are quite in the know when it comes to anything automotive. I've read your posts for a long time now, I figured it was about time to say thanks for what I learned from you.
#3310243 - 03/13/14 07:50 AM Re: How can a driveshaft become unbalanced? [Re: rockydee]
Trav Offline
I wouldn't do it. It doesn't take much to put it out of balance and there is no way to guarantee the thickness of the paint film is the same over the whole shaft.
You can use something like 389 rust blocker or Bullfrog before winter then drive the car, it wont throw it out of balance.
http://www.theruststore.com/Cortec-ECOSp...pYrAXhs1UVcYuSU
http://www.theruststore.com/Bull-Frog-Ru...pYrAXhs1UVcYuSU
#3310258 - 03/13/14 08:06 AM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
rockydee Offline
Loc: VA
Good point. I didn't think a spray bomb might be able to throw a DS out of balance.
#3310285 - 03/13/14 08:23 AM Re: How can a driveshaft become unbalanced? [Re: rockydee]
Trav Offline
Figure there is about 8oz of product in the spray can that actually ends up on the piece, prime and paint could be almost a pound of material.
Half an ounce out of balance can be noticeable.
http://www.rldial.com/Ultra%20High%20Speed%20Driveshaft%20Balancing.html
#3310368 - 03/13/14 09:36 AM Re: How can a driveshaft become unbalanced? [Re: Vstrom]
zzyzzx Offline
Loc: Baltimore, Maryland, USA
I would think that things like dirt or rust could throw it off balance.
Page 1 of 2 1 2 >
