1999 ford expedition factory mercon v synthetic??
by merconvvv
07/23/16 11:40 PM
Buick 3800 - "Von Voyage" oil change?
by Alex_V
07/23/16 10:41 PM
Low oil level light on, but level not THAT low....
by gregk24
07/23/16 10:26 PM
Is SuperLube syn multi grease universal
by NattyBoh
07/23/16 10:05 PM
How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
2016 Tacoma 3.5L V6 4x4
by NavyVet88
07/23/16 07:10 PM
Question on 05 Nissan tranny w/120k
by NattyBoh
07/23/16 06:58 PM
Denso FTF oil filters
by mclasser
07/23/16 06:50 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
59 registered (ag_ghost, 4WD, 69GTX, 41 Plymouth, aquariuscsm, 6 invisible), 1259 Guests and 15 Spiders online.
58578 Members
66 Forums
252173 Topics
#3274207 - 02/07/14 08:37 PM Fluid Film for stuck fasteners
buck91 Offline
Loc: West Michigan
Just curious if anyone has tried fluid film as a penetrating oil for stuck nuts and bolts? Figured it creeps like crazy after application, but does so rather slowly, so maybe given time it would work well but that might mean quite a bit of time.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#3274306 - 02/07/14 09:37 PM Re: Fluid Film for stuck fasteners [Re: buck91]
JHZR2 Offline
Loc: New Jersey
Far too viscous. Id use something like PB, kroil, or apparently ATF thinned with acetone works too...
#3274316 - 02/07/14 09:44 PM Re: Fluid Film for stuck fasteners [Re: buck91]
demarpaint Offline
Loc: NY
Kroil would be my first choice followed by PB Blaster.
God Bless Our Troops
#3274356 - 02/07/14 10:23 PM Re: Fluid Film for stuck fasteners [Re: buck91]
oilboy123 Offline
Loc: Everett, Washington
I don't think that's the primary application of the product. Other things would be better.
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
#3308420 - 03/11/14 03:33 PM Re: Fluid Film for stuck fasteners [Re: buck91]
camelCase Offline
Loc: Southeastern, USA
Typically, you want a pretty low viscosity to get good creeping. Think that higher viscosity means more shear is needed to move the fluid, so with low viscosity the fluid will continue to move even with a minute amount of shear (gravity in this case).
I'd go with an actual formulated penetrating spray lube. There are so many uses for a good can of PSL that it's always worth the cost to pickup a can if you don't have any.
#3308516 - 03/11/14 05:07 PM Re: Fluid Film for stuck fasteners [Re: buck91]
buck91 Offline
Loc: West Michigan
Well the situation I had more in mind was on older, rusty nuts and bolts that you know you will need to remove one day, but there is no current need.
For example, strut bolts or other such fasteners on a used car which you know will get replaced eventually but that time has yet to come. To me, it would seem FF would creep nicely over time while not evaporating and rinsing off as readily as a penetrating oil. But that is untested.
2011 F150 4x4 5.0L
1980 Yamaha XS850G
