VR1 Only suitable for 3 month / 3000mi oci's?
by FordCapriDriver
04/29/16 04:07 AM
4-year old oil in a sealed container
by rickeroo
04/29/16 12:05 AM
Cowboys fans should be happy tonight.
by deven
04/28/16 11:03 PM
2012 Civic - MaxLife ATF update
by sw99
04/28/16 10:58 PM
Champ PH820 on closeout at Rockauto
by sw99
04/28/16 10:52 PM
Is two years too long?
by kohnen
04/28/16 10:34 PM
Keep getting TR.APK popup on S III cell phone...
by daves66nova
04/28/16 10:16 PM
Curse You Road Salt Version 2
by Oldtom
04/28/16 07:34 PM
Anyone have advice for moving a cat cross-country?
by earlyre
04/28/16 07:23 PM
MLB baseball games are very expensive
by Joe1
04/28/16 07:20 PM
Additive technology used in Euro mid-saps oils
by skyactiv
04/28/16 05:41 PM
Would I be crazy if I did this:
by Doog
04/28/16 05:36 PM
carver1, Handy7rick, sicilien, Crater_77, hiker17
57737 Registered Users
27 registered (AirgunSavant, 1foxracing, Bandito440, alcyon, 5 invisible), 561 Guests and 317 Spiders online.
57737 Members
66 Forums
248196 Topics
#3308286 - 03/11/14 12:54 PM How to check ATF LEVEL on 2009-2013 Corolla
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
Anyone have the real factory instruction on how to check ATF level on a corolla? My manual is so boastfully sure that it is a "lifetime" fluid that it wont evn explain if it should be in park or neutral.
#3308448 - 03/11/14 04:05 PM Re: How to check ATF LEVEL on 2009-2013 Corolla [Re: SumpChump]
Voltmaster Offline
Loc: California
My 2006 corolla was not much diffrent between park and Neutral....
I'd go with Park and Idle and call it a day.
#3308460 - 03/11/14 04:17 PM Re: How to check ATF LEVEL on 2009-2013 Corolla [Re: SumpChump]
friendly_jacek Offline
Loc: southeast US
Now, the 2009-2013 has a dipstick, right?
#3311813 - 03/14/14 01:23 PM Re: How to check ATF LEVEL on 2009-2013 Corolla [Re: SumpChump]
SumpChump Offline
Yes the dipstick
Such a thing as a 15k oil change or a lifetime transmission fluid!!??
#3312114 - 03/14/14 06:49 PM Re: How to check ATF LEVEL on 2009-2013 Corolla [Re: SumpChump]
Rhymingmechanic Offline
Loc: VA
Here's the procedure from the 2010 Vibe owner's manual (kin to the Matrix/Corolla). Summary: drive a few miles, then check fluid with the engine running in park.
(On my Vibe at least, the handle is not orange as stated. Also, the operation is not "difficult." And, after all the warnings about using the wrong fluid, the manual recommends the wrong fluid. But that's beside the point for your purposes.)
How to Check Automatic Transmission Fluid
This operation can be difficult, you may choose to have this done at the dealer/retailer service department. If you do it yourself, be sure to follow all the instructions here, or you could get a false reading on the dipstick.
Notice: Use of the incorrect automatic transmission fluid may damage your vehicle, and the damages may not be covered by your warranty. Always use the automatic transmission fluid listed in Part D: Recommended Fluids and Lubricants on page 11-18.
Wait at least 30 minutes before checking the transmission fluid level if you have been driving:
When outside temperatures are above 90F (32C).
At high speed for quite a while.
In heavy traffic especially in hot weather.
While pulling a trailer.
To get the right reading, the fluid should be at normal operating temperature, which is 158F to 176F (70C to 80C).
Get the vehicle warmed up by driving about 15 miles (24 km) when outside temperatures are above 50F (10C). If it is colder than 50F (10C), you may have to drive longer.
Checking the Fluid Level
Prepare your vehicle as follows:
1. Park your vehicle on a level place. Keep the engine running.
2. With the parking brake applied, place the shift lever in P (Park).
3. With your foot on the brake pedal, move the shift lever through each gear range, pausing for about three seconds in each range. Then, position the shift lever in P (Park).
4. Let the engine run at idle for three to five minutes.
Then, without shutting off the engine, follow these steps:
The automatic transmission dipstick has an orange handle and is located near the front of the engine compartment.
1. Release the tab and pull out the dipstick and wipe it with a clean rag or paper towel.
2. Push it back in all the way, wait three seconds and then pull it back out again.
3. Check both sides of the dipstick, and read the lower level. The fluid level must be between the two dimples in the hot range.
4. If the fluid level is in the acceptable range, push the dipstick back in all the way; then press the tab down to lock the dipstick in place.
#3312251 - 03/14/14 09:33 PM Re: How to check ATF LEVEL on 2009-2013 Corolla [Re: SumpChump]
clinebarger Offline
Loc: Fort Worth, Texas
Both are acceptable. The only vehicles I've ever checked in Neutral are Chrysler Corp.
ATF's are not lifetime, I drain & fill my Corolla every 24K with Toyota WS. It's ran in severe conditions.
2001 Chevy Camaro 5.3L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3314441 - 03/17/14 01:59 AM Re: How to check ATF LEVEL on 2009-2013 Corolla [Re: SumpChump]
SumpChump Offline
Thanks!
