How bad is this?
by cnl64590
02/06/16 02:21 PM
Mag1 or ST Dino: what would YOU use?
by car51
02/06/16 01:54 PM
Ustria?
by Pontual
02/06/16 11:48 AM
Georgia bans 71 oils from 29 brands
by Tom NJ
02/06/16 11:27 AM
Trying to send a Blackstone sample
by 15SilvyEcotec
02/06/16 11:10 AM
2005 Trailblazer getting a new engine
by The_Eric
02/06/16 11:02 AM
AAP: 5 qt Castrol Edge, Boss filter, $30 PP $33
by DoubleWasp
02/06/16 10:48 AM
Make own external backup?
by doitmyself
02/06/16 10:33 AM
What should I use for my next oic?
by dan_erickson
02/06/16 10:25 AM
Motul Sport Ester 5w40 vs Gulf Competition 5w40
by Brit33
02/06/16 10:12 AM
M1 0W-20 EP / 15,745 mi oci / 2004 Honda Accord V6
by vinu_neuro
02/06/16 09:58 AM
Recommend me a small 12v battery.
by dlundblad
02/06/16 09:22 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
94 registered (b1amgm47, beetleything, 05LGTLtd, 2015_PSD, Bandito440, bmod305, 7 invisible), 1914 Guests and 187 Spiders online.
56834 Members
66 Forums
244313 Topics
Page 2 of 2 < 1 2
#3309369 - 03/12/14 12:34 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: andrewjoelpeters]
cptbarkey Offline
Loc: texas
good luck, i started on a similar path of hobby repairs and it has been very satisfying.
#3309682 - 03/12/14 05:39 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: andrewjoelpeters]
eljefino Offline
Loc: ME
I don't think you have to go as deep as the head gaskets.
If the cylinder walls are rusty, you're going to pop the pistons out the top anyway, scuffing in the process. So you might as well scuff the pistons by trying to turn it over.
I would do the timing belt though and cam cover/ oil pan gaskets. Probably a distributor o-ring of some sort.
I bet the junkyard owner is tickled. "Someday my ship will come in and I'm gonna sell that tercel motor..."
#3309765 - 03/12/14 06:57 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: expat]
TFB1 Offline
Loc: VA
Originally Posted By: expat
Originally Posted By: Propflux01
I would check carb first. Then fill with oil and spin it over and see what it does. If you get pressure then give it a source of fuel and try to start it. If it runs, then you can spend $$ on seals and gaskets
You might end up using the carb from your old Oil Burner.
Agreed, I'd swap and then maybe try the orig after the engine is running properly... More than likely though, I'd rebuild it before I tried it...
As others mentioned replace/swap anything with rubber, if it has a mechanical fuel pump I wouldn't trust it as old diaphragms often rupture, that'll dump the crankcase full of gas and ruin a good engine in short order...
#3310013 - 03/12/14 10:31 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: eljefino]
andrewjoelpeters Offline
Loc: NM
I think you're probably right! At first he saw my out of state area code and told me he wasn't interested in shipping it because he likes to deal in person, but when I told him I'm actually nearby, it sounded like he was getting pretty excited.
Originally Posted By: TFB1
...if it has a mechanical fuel pump I wouldn't trust it as old diaphragms often rupture, that'll dump the crankcase full of gas and ruin a good engine in short order...
To the best of my knowledge 1st generation Tercels had an in-take fuel pump--would there be second one mounted to the engine itself?
#3311139 - 03/13/14 09:33 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: andrewjoelpeters]
artificialist Offline
Loc: Florida
Valve seals on Tercels were weak. Replacing them now makes perfect sense. I worked on a carb'd 1989 Tercel, and the camshaft driven fuel pump had to replaced. Typically you see a cam driven fuel pump on a carb engine but there are exceptions. It isn't common, but some carb engines do have an in tank pump.
I suggest replacing the water pump. The bearings might seize.
I am sure that your engine has a maze of vacuum hoses, since it is a carb engine with smog devices. You probably need to replace all of them, unfortunately, most plastic parts connected those hoses will crack.
2010 Lancer Ralliart Sportback
#3311204 - 03/13/14 10:19 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: andrewjoelpeters]
morris Offline
Loc: ks, wichita
while its out in the open pop the old freeze plugs and replace with brass. and do a back yard clean out of the water jackets.
Page 2 of 2 < 1 2
