Highway conditions in the Midwest
by grampi
07/01/16 08:22 AM
Indian head shellac or something?
by JHZR2
07/01/16 08:15 AM
Need Help! Tombstone
by AirgunSavant
07/01/16 07:38 AM
Truck bedliner - pros and cons and option
by ryan2022
07/01/16 07:33 AM
Delo 400 SD 15w30 From Amazon
by AirgunSavant
07/01/16 07:27 AM
GM LS 6.0 Suggestion
by akcooper9
07/01/16 06:58 AM
Penrite 5W-30 Full Synthetic
by KL31
07/01/16 06:08 AM
PP HM at Walmart
by dlundblad
07/01/16 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
07/01/16 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
07/01/16 03:29 AM
Old Toyota
by artbuc
07/01/16 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
07/01/16 03:03 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
85 registered (ac_tc, ARCOgraphite, badtlc, AirgunSavant, b1amgm47, AEHaas, 6 invisible), 1596 Guests and 12 Spiders online.
58332 Members
66 Forums
251084 Topics
#3307610 - 03/10/14 08:18 PM kleen flo carb cleaner
Chirs Offline
Loc: Ontario, Canada
Hi Guys, this is my first post. I found this site while trying to answer what the best oil for my boat would be, and figured if anyone could answer my questions it would be someone here.
I bought a gallon of Kleen Flo carb cleaner and happily began to clean my carb. As I continued it became abundantly clear that this stuff really stinks. So much so I don't dare use it anywhere inside the house, and need to be meticulous about spilling a drop of the stuff. Does anyone have any suggestions on how to deal with the odour? I've checked the MSDS for it and it's not terribly bad, but man does it ever smell, and the smell lingers.
Edited by Chirs (03/10/14 08:20 PM)
#3307639 - 03/10/14 08:40 PM Re: kleen flo carb cleaner [Re: Chirs]
Donald Online   content
Loc: Upstate NY
Anything that can clean gum and varnish is bound to be potent and stinky.
Keep in mind that getting your carb ready for the boating season may require more than a cleaning and rebuild kit. Such as dealing with water corrosion and worn linkages.
I was quoted $175 + postage to rebuild my 4 barrel Rochester. I cannot tell you how many times its stalled while backing it into my slip, thus I felt it was time for a rebuild.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3307761 - 03/10/14 10:07 PM Re: kleen flo carb cleaner [Re: Chirs]
Chris142 Offline
Loc: apple valley, ca
I wonder if its the same nasty stuff i have used. It would stink for weeks if you got any on you and it would remove skin so dont go sticking your hand in the bucket to pull a part out.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3308034 - 03/11/14 07:42 AM Re: kleen flo carb cleaner [Re: Chris142]
Chirs Offline
Yup nasty stuff. I have my own work shop at work and thought I'd just keep it to the side and work on it on my lunch and after work. As soon as I poured it into the tray to soak the throttle plates I knew I was in trouble. I ended up cleaning the whole area, putting everything in plastic bags and boxing it all up and taking it home right away. I had ventilation fans going for 2 days, and even now when you walk by my office you can smell it from when I put the soaking tray on the steps outside my office. That was 2 weeks ago. I've worked with all kinds of solvents over the years and never have I encountered anything like this. Now I have to develop a plan to get it all cleaned and back together and hope that it doesn't stink up the boat for ever.
#3308526 - 03/11/14 05:12 PM Re: kleen flo carb cleaner [Re: Chirs]
Clevy Offline
Loc: Saskatoon canada
That stuff is the perfect premix to add to gasoline. It's got acetone,toluene,xylene and something else. I mix it 50/50 with tc-w3 and into my gas tank
2006 Charger RT
Miles x 2 per oil filter
#3309135 - 03/12/14 09:04 AM Re: kleen flo carb cleaner [Re: Clevy]
Chirs Offline
I don't think it's the same stuff. The MSDS lists Methylene chloride 2-Methylphenol 3-Metylphenol 4-Methylphenol Xylene Orthodichlorobenzene, Methanol 2-Butyoxyethanol. Potassium oleate soap, caustic potash
#3347427 - 04/19/14 01:55 PM Re: kleen flo carb cleaner [Re: Chirs]
andyd Offline
Loc: Marshfield , MA
Last total rebuild of a carb , I used a gallon of stale gas and 3 spray cans of carb cleaner. If there is up and down play in the throttle shafts, they can be re-bushed with brass.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
