Originally Posted By: evandostert
I think we need a permanent sticky. Where to trim HIR bulbs for application. Do they fit and what bulb was used. I have read of certain bulbs needed sanding down. Some not fitting. Methods used for cutting.
I will post pics this week. I am going for HIR in 9006 for my silverado.
Wait.....you are going to put HIR's (9011) in your low beam 9006 holders? I cannot at all recommend this. Not even sure your harness will be up to that (probably but still, too bright)
In 9005 high beam holders, yes, simple trim. Some cars like my WRX, fitting the Philips 9011 was easy, simple nip with the cutter and breaking the edges with a machinist file. The NLA Toshiba HIR were a real project - I trimmed, filed and sanded several surfaces.
