Cheap brake fluid tester working properly?
by LucasDK
05/28/16 04:00 AM
Help finding specific oil.
by Mickxalix
05/28/16 02:28 AM
Found at Walmart: STP Multipurpose Motor Treatment $1.50
by MrQuackers
05/28/16 01:36 AM
Mobil 1 5w50 now FS too
by BobFout
05/27/16 11:55 PM
Front brakes for 1991 GMC Sierra 2500
by sr17
05/27/16 11:35 PM
7200 Miles
by Yup
05/27/16 11:08 PM
Result; 5 additives tested in a lab
by DrAdmin
05/27/16 09:25 PM
What are advantages of rotation ?
by HTSS_TR
05/27/16 09:22 PM
Arthritic joints
by Eddie
05/27/16 08:55 PM
Trouble Installing Filter
by Astro_Guy
05/27/16 08:09 PM
Kia P0138 Code From Old Amsoil Stabilizer ??
by Quadrasteer
05/27/16 07:43 PM
Micro Guard Filter
by Jason1221
05/27/16 07:38 PM
troutwest66, AIRJAC3, bpete65, LEVY, Timmytimmy
58000 Registered Users
28 registered (Bandito440, Char Baby, dlundblad, crazyoildude, bdcardinal, 2 invisible), 495 Guests and 330 Spiders online.
58000 Members
66 Forums
249510 Topics
Page 5 of 8 < 1 2 3 4 5 6 7 8 >
#3304463 - 03/07/14 12:57 PM Re: ford focus hard start [Re: ram_man]
OVERKILL Offline
Loc: Ontario, Canada
Originally Posted By: ram_man
Everyone the problem was found. It was a bad temp sensor. And they are replacing motor mounts since the car has a vibration has had it for atleast 30,000 miles. They guys said the focus mounts are junk.
yes, the motor mounts on them are a known problem point. On the older ones (not sure if that's the case with a 2011) the passenger-side mount was a fluid filled type that the fluid would eventually degrade or disappear in, which greatly reduced its functionality and led to the driver feeling a great deal of vibration. They are relatively cheap and easy to replace though, as I did the one on our 2000.
So the ECT had gone south? Your scanner should have picked that up wink
Good to hear it is fixed though.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3304472 - 03/07/14 01:09 PM Re: ford focus hard start [Re: kyxtremetuber]
tig1 Offline
Loc: Illinois
Originally Posted By: kyxtremetuber
Throttle body was probably dirty and stuck for a second is just get some carb cleaner and clean it I bet that's what the dealer does that's what we would do at work
+1. I have had that same problem on my 2007. About every 1 1/2 years I pull the air intake off and use throtle plate cleaner to clean the are around the throtle plate. All engines should have this done. It's caused from oil fumes collecting in the upper parts of the engine.
2007 Ford Fusion 181,000 miles
M1 0-20 AFE
2007 Ford Focus 154,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#3304510 - 03/07/14 01:45 PM Re: ford focus hard start [Re: OVERKILL]
ram_man Offline
Loc: southern mo
There scanner didn't pick it up either it never threw a code or had freeze frame data stored. He didn't say how he found it though.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3304522 - 03/07/14 01:52 PM Re: ford focus hard start [Re: ram_man]
OVERKILL Offline
When it was exhibiting the problem, it would show up under live data as out to lunch. It may not set a code, but the values being read would be obviously wrong.
So for example, if I had all of the relevant parameters on the screen like bat voltage, ACT, ECT, TPS...etc and the car was acting up, the ECT probably would have shown like -40C or something. If it was out of range it should have thrown a code, so we have to assume that it wasn't out of range, just way off.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3304523 - 03/07/14 01:52 PM Re: ford focus hard start [Re: ram_man]
andrewg Offline
Loc: Covington, Wa.
Probably nothing wrong with the Focus. Only start the car about once a week or less....then DRIVE it about 30 minutes or more. Sounds like you just dumped way too much fuel into the engine. Why would you PUMP the throttle? Never good to do that with fuel injection.....at least from what limited knowledge I have. I know that I have started cars when cold just to move them for the purpose of parking them in a spot to wash them......then I shut it down. When I start the vehicle again after washing it, it nearly always runs rough or sputters a bit from such a short run cycle. I always take it out for a spin to make sure things are COMPLETELY warmed up before putting the car away.
I think it's obvious that what you are doing IS the cause for the hard starting.
Edited by andrewg (03/07/14 01:53 PM)
2016 Mazda MX5
2015 Honda Fit
2012 Honda Ridgeline
#3304568 - 03/07/14 02:38 PM Re: ford focus hard start [Re: andrewg]
JHZR2 Offline
Loc: New Jersey
Sounds obvious that you didnt read the thread wink
An issue was found.
Mr_man wasnt doing any favors by starting and running like that, but there was at least one faulty item. Why it only showed up then is interesting. Perhaps Mrs. _man (the mother) just ignored it?
#3304579 - 03/07/14 02:48 PM Re: ford focus hard start [Re: ram_man]
KrisZ Offline
Loc: Toronto, Canada
So what I get from this is that the faulty sensor was causing a very low temp reading and that caused the ECU to add too much fuel essentially flooding the engine. Does this sound correct?
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#3304584 - 03/07/14 02:53 PM Re: ford focus hard start [Re: JHZR2]
andrewg Offline
Loc: Covington, Wa.
An issue was found.
You are correct! I got bored before I finished the second page and blurted out a response. Oh well....life goes on.
2016 Mazda MX5
2015 Honda Fit
#3304592 - 03/07/14 02:59 PM Re: ford focus hard start [Re: KrisZ]
OVERKILL Offline
That's what I'm taking away from it.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3304605 - 03/07/14 03:14 PM Re: ford focus hard start [Re: OVERKILL]
ram_man Offline
Loc: southern mo
It probably would have but I didn't have the scanner hooked up when it happened I did hook it up on the drive to the dealer and it was all good of course. Least it was a simple issue.
#3304648 - 03/07/14 04:00 PM Re: ford focus hard start [Re: ram_man]
Rand Offline
Loc: NE,Ohio
Gee that's funny since 2011 duratech focii dont have a ECT.
Post up a copy of the work order so I can laugh at the ford dealer.
In the spirit of the thread, you could be making it up, LOL! grin
Seriously though, it could also be something as stupid as water in the tank. "Warranty will cover it", as ranger noted, is a rather bold statement considering they have no idea what the "issue" is yet. Would they cover draining the tank and replacing the fuel filter if somebody peed in your mom's gas tank? shrug
Edited by Rand (03/07/14 04:11 PM)
Edit Reason: removed troll attack on chevyboy.
2015 Forester I-Premium 6MT
#3304668 - 03/07/14 04:18 PM Re: ford focus hard start [Re: Rand]
ram_man Offline
Loc: southern mo
its a 2010 focus and it most certainly does have a temp sensor. Check your facts.
#3304814 - 03/07/14 07:16 PM Re: ford focus hard start [Re: ram_man]
Rand Offline
Loc: NE,Ohio
please post the work order
#3304824 - 03/07/14 07:29 PM Re: ford focus hard start [Re: ram_man]
ram_man Offline
Loc: southern mo
Why? Ill have it tomorrow but why? Why cant you believe what I said and rest easy? Feel like i am on trial on here.
#3304887 - 03/07/14 08:44 PM Re: ford focus hard start [Re: ram_man]
Vikas Offline
Loc: NorthEast
Why would 2011 Focus won't have ECT? Or is it integrated into thermostat? Knowing Ford and how they decided to make the air cleaner as lifetime component, they may have indeed removed the ECT but I would be still surprised.
Edited by Vikas (03/07/14 08:46 PM)
