OVERKILL
$100 Site Donor 2021
Originally Posted By: ram_man
Everyone the problem was found. It was a bad temp sensor. And they are replacing motor mounts since the car has a vibration has had it for atleast 30,000 miles. They guys said the focus mounts are junk.
yes, the motor mounts on them are a known problem point. On the older ones (not sure if that's the case with a 2011) the passenger-side mount was a fluid filled type that the fluid would eventually degrade or disappear in, which greatly reduced its functionality and led to the driver feeling a great deal of vibration. They are relatively cheap and easy to replace though, as I did the one on our 2000.
So the ECT had gone south? Your scanner should have picked that up
Good to hear it is fixed though.
