I can't seem to find any info on the FL2057. Since the FL910s has the "S" at the end of the part number, it has a silicone anti-drain back valve. That is one difference between them that I can see from the numbers alone.
FL-2057 is the filter fitted at the factory and is replaced in service by the FL-910S. There are no specs provided because this filter is only fitted at the factory and is not supplied through the Ford Customer Service Division.
Per the information provided to dealerships "SERVICED BY BE8Z-6731-AB PER PNAEF" with that being the long number for a FL-910S.
