Quote:
DIAGNOSIS
All wear rates normal. Light concentration of water
present. Other contaminant levels acceptable. Unable
to perform viscosity testing due to excessive water
contamination.
Action: Advise check sampling procedure for possible
source of contamination. Change oil and filter(s) if not
already done. Resample next service interval to
monitor and establish wear trend.
The water, Na, and K could be from antifreeze contamination. I'm not sure how that would have happened as antifreeze has never been anywhere near my drain pan. The Si could be from sealers or assembly lubes as this was the factory fill on a brand-new trans. Of course, the Na, K, and Si could be additives. No VOA, so I don't know for sure. I wish they had been able to run a viscosity test. Nice amount of calcium and boron. TBN looks low but I'm not sure how important that is for CVT fluid, or how high it was in the first place.
The Valvoline CVT fluid will come out in another 30,000 so I'll have that for comparison. I should send in some for a VOA so I'll know how to interpret the results better.
