1991 Clean Acura NSX with some mods for $45k
by HTSS_TR
06/27/16 03:16 PM
Tiny metal particles suspended in oil?
by rustypigeon
06/27/16 02:35 PM
M1 0w20, 10,093 miles, 2006 Civic
by Patman
06/27/16 02:13 PM
5w-40 synthetic vs 15w-40 synthetic
by mbacfp
06/27/16 01:27 PM
SCAM!Anyone renting their water heater tank?
by KrisZ
06/27/16 01:16 PM
Donaldson PowerCore as HEPA filter?
by PeterPolyol
06/27/16 01:13 PM
Clearance oversized filters for M20x1.5 w/bypass
by PeterPolyol
06/27/16 01:05 PM
Prestone vs. DEX-COOL Concentrate
by Ramblejam
06/27/16 12:54 PM
Severe service and OEM oil Filters
by Tech819
06/27/16 12:46 PM
ContiTech Pro Series timing belt kit 2009 Galant
by Ruturaj
06/27/16 12:25 PM
Bogus Coolant Test! - did Pat Goss make a mistake?
by i_hate_autofraud
06/27/16 11:57 AM
The "zero posters"
by OVERKILL
06/27/16 11:57 AM
scuff, Tuar, ATFD48, Enumeratum, poc
58290 Registered Users
91 registered (69GTX, 901Memphis, 3for3, 01rangerxl, 1JZ_E46, 97f150, 11 invisible), 2100 Guests and 10 Spiders online.
58290 Members
66 Forums
250886 Topics
#3303597 - 03/06/14 05:37 PM Anybody got any ideas
faltic Offline
Loc: ga
OK first, I've been lurking around here for a while and you guys are my kind of people. I really like poring over data so thanks for that LOL. This is my first post so this is what I got. It's a 1995 toyota tacoma 2.4 automatic 176,000 miles I owned it it's whole life. When I started it last it took a tick longer to catch but didn't think much of it. As I got on down the road a couple miles it seemed to have an occasional slight miss then quit like the key was turned off and hasn't run sense. It cranks over good but want start. My code reader says "no codes". I've always used this code reader to get me started in the ball park anyway. Does the no codes suggest something obvious I'm overlooking? Anyway thanks for looking and any input is appreciated.
#3303605 - 03/06/14 05:45 PM Re: Anybody got any ideas [Re: faltic]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Any fuel pressure in the fuel rail?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3303607 - 03/06/14 05:48 PM Re: Anybody got any ideas [Re: faltic]
wog Offline
Loc: massachusetts
Timing chain? Fuel pump? Just some thoughts, pull plug and see if spark. Or tow to mechanic.
#3303625 - 03/06/14 06:02 PM Re: Anybody got any ideas [Re: faltic]
spasm3 Offline
Loc: out there
You are going to have to check the first three then go from there. Do you have fuel?, do you have fire?, and do they occur at the right time?. It could be anything from a fuel pump, a jump in a worn timing chain sprocket, to a crankshaft position sensor.
Edited by spasm3 (03/06/14 06:03 PM)
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3303753 - 03/06/14 07:41 PM Re: Anybody got any ideas [Re: faltic]
artificialist Offline
Loc: Florida
Does your truck have a distributor ignition? It is very common for one to fail on an OBDI Toyota, and give no codes.
But you have to go through all the diagnostic steps before you can determine if the distributor is the problem. Get an OEM one, practically every rebuilt distributor lasted only 1 year.
2010 Lancer Ralliart Sportback
#3303760 - 03/06/14 07:45 PM Re: Anybody got any ideas [Re: faltic]
Boomer Offline
Loc: Pennsylvania
Fuel filter could be clogged.
2003 Saturn L 300 128,200 miles
2013 VW Passat TDI SE, 31,600 miles
2014 VW Jetta TDI SportWagen 17,300 miles
#3303866 - 03/06/14 09:21 PM Re: Anybody got any ideas [Re: faltic]
FL_Rob Offline
Loc: gulf coast FL.U.S.
I'm going with bad coil on this one.Almost everything else would set a code.
#3303872 - 03/06/14 09:27 PM Re: Anybody got any ideas [Re: faltic]
Donald Offline
Loc: Upstate NY
Squirt some starter fluid in there and that will tell you whether its spark or fuel. I would guess its spark. I had a 1994 Camry 4 cyl that died at roughly the same mileage. The coil which was inside the dist. failed. I was told they fail between 150K and 200K. But your 1995 could certainly be different.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3303889 - 03/06/14 09:41 PM Re: Anybody got any ideas [Re: faltic]
spasm3 Offline
Loc: out there
Come back and post what you find, its interesting to see what the problem turns out to be.
#3305408 - 03/08/14 01:31 PM Re: Anybody got any ideas [Re: faltic]
faltic Offline
Loc: ga
OK, this is how it went. Yesterday I put starter fluid into the throttle body inlet and
tried to start it, nothing. Today I removed the distributor cap, it looked fine. The rotor
was pretty eroded but not the worst I have seen. I removed the inside cover to access the
coil terminals, it had a little oil sheen on the lower inside of that, so cleaned that. The
coil checked within spec primary and secondary according to my Haynes book. I scrubbed the
tip of the rotor on the drive way and reassembled. Pulled the front plug wire and put a
plug in it. When the engine was turned it had a spark and almost started on three plugs.
Put the plug wire back on and tried it again. It started then died. It finally started on
third try and ran ruff a few seconds the idled as normal. Went to auto Zone and got a new
rotor and installed it. Guess I will drive it and see what happens. Thanks to all for your
input.
95 Tacoma 2.4 2wd AT 180k
03 Element 2wd AT 191k
07 EX250 18.5k
09 EN500 8.5k
