Low cost sedan looks better than expensive one
by HTSS_TR
8 minutes 10 seconds ago
Toyota red in motorcycles/snowmobi
les
by Altydoc
48 minutes 54 seconds ago
Looking at some old posts
by Oldmoparguy1
55 minutes 49 seconds ago
Towing a heavy trailer
by Donald
59 minutes 27 seconds ago
Envelope Budget System
by GMFan
Today at 06:37 PM
Saving OPE after a flood?
by Geauxtiger
Today at 06:18 PM
Late 80s/early 90s oil tech
by Pepsibottle1
Today at 06:08 PM
Best MT Fluid?
by mattri
Today at 05:48 PM
Harvest King full synthetic $11.99 5 qt dexos
by paulswagelock
Today at 05:41 PM
AC Delco vs Moog
by 007
Today at 05:34 PM
1998 Volvo C70
by ET16
Today at 04:57 PM
Makita Air Compressor Help
by GGorman04
Today at 04:25 PM
TonyG9050, krishna, Chuck1970, skylerG, LeeG
58890 Registered Users
98 registered (2002 Maxima SE, 2010Civic, 09_GXP, 04SE, 2KBMW, 7 invisible), 1721 Guests and 9 Spiders online.
58890 Members
66 Forums
253472 Topics
Page 1 of 3 1 2 3 >
#3302053 - 03/05/14 08:51 AM How bad is short tripping for a diesel engine?
Quattro Pete Offline
Loc: Great Lakes
Is it basically similar to short tripping a gasoline engine, i.e. you get fuel dilution and moisture accumulation in the crank case? Or are there additional aspects to consider? I am a total diesel engine newbie.
Wife has a fairly short commute - about 3 miles each way. In the winter time, in her current gasoline engine car, coolant doesn't get up to normal temp, much less oil. The car does see an extended 200-mile hwy trip once or twice per month.
Back in the day, I've read diesel engines take longer to reach operating temp, but I'm not sure if this was accurate and if so, if it's still true today. Obviously, any possible MPG gains from a diesel would be lost if it's not running at operating temp.
Anyway, no particular diesel car/engine in mind at this point. I'm just trying to educate myself if there are some specific driving patterns/conditions where a modern diesel engine would not be advisable.
Thanks!
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3302070 - 03/05/14 09:05 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Some diesels warm up faster than others-my intercooled ones warm up more slowly than the old IDI N/A ones do. In my opinion, at least with pickups, it is much better to work them hard & get them hot, short trips tend to carbon load.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3302074 - 03/05/14 09:11 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
m6pwr Offline
Loc: San Diego, CA
I've got a 2014 BMW 328d (fantastic car - 43-46 mpg urban/city, 51 mpg hwy, and a hoot to drive). It doesn't have a coolant temp gauge but does have oil temp. gauge. I haven't noticed any difference at all between warm up time for this car and other gas BMW's in same trip - - and I do pay close attention to the oil temps, always after a cold start drive it 'til the temp is up to normal (210 degrees) before I shut it down, even if that means going the long way around. I do that, but I'd never be able to convince my wife to do that.
#3302089 - 03/05/14 09:25 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
JHZR2 Offline
Loc: New Jersey
It's time at temperature, not just hitting a mark. A long drive now and again does wonders. If very cold, fuel,may be an issue; the problem I've read with the latest ones is that the particle trap may not regenerate properly...
There are lots of stories around about the EPA numbers being artificially low for diesels, perhaps because the warm-up time is longer and is not accomplished at idle the way it is in a gas engine.
#3302090 - 03/05/14 09:28 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
Donald Online   content
Loc: Upstate NY
My Cummins diesel warm up until I get to work, 30 miles away. (Well almost).
But others I know have issues with the particle trap and regenerate.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3302137 - 03/05/14 10:09 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
drolds Offline
Loc: KS, USA
Diesel engines are better suited to longer trips. If the 3 mile commute is going to be the daily usage, a diesel may not be a good fit. If you had two comparable cars, one a diesel and one a gas-hybrid, the diesel would win the efficiency game on highway driving while hybrid-gas could more cost effective in a short-trip city driving cycle. The diesel really needs at least 10 miles each way on a daily commute to be cost effective.
The basics of ownership are to take very good care of it with very strict maintenance. Air filters need to be of high quality and changed when full of contaminants. Many newer diesel vehicles have a visual indicator on the air-box that is tripped when the filter becomes too restricted. The fuel filters must be changed with OEM intervals at a minimum w/o exception and more often depending on how much crud is collecting in the fuel filter (time as well as miles driven are important on diesel). Very high quality oil and oil filters are a given for good diesel maintenance. Do not forget anti-gel additive in winter nor an
injector-cleaner/ lubricity fuel additive. All of these are key to preventing expensive repairs later. Don't forget oil analysis too- its cheap insurance.
Noting the cars you already drive, a M-Benz diesel would be terrific. Be sure to use an extremely high quality synthetic oil that meets Benz spec 229.51 for example. The VW-TDI is another that needs an extremely good oil.(The VW diesel is much better w/ a manual trans). I have significant experience servicing the above mentioned cars. There are also differences between the non-DPF 2006 and older cars and the 2007 and up ones with a DPF. The M-Benz will require Diesel exhaust fluid(for DPF) for any 2007 or newer vehicles is but one example. Let us know what exact car you eventually consider and I'm sure others who own such can chime in.
Dr. Olds
#3302141 - 03/05/14 10:12 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
scurvy Offline
Loc: Chicago IL USA
VWAG TDIs that are short tripped suffer from coking the VNT mechanism in the turbocharger, oil buildup in the intercooler (from seeping past the turbo labyrinth seals) and relatively poor fuel economy. Oil dilution was not typically a concern in the past but post-injection engines will have that issue even moreso with short tripping... for that reason alone I would only want a urea SCR system. DPF will also do more frequent active regens with short trips.
Keep them on boost and up to temperature and they typically live long, happy lives.
For short trips, I would only recommend a gasser. Fuel economy will likely be the same and maintenance on a short tripped diesel will erode any savings at the pump very quickly.
FWIW, my Golf is extremely cold blooded and takes much longer than the Mazda to warm up. To help that I have pipe insulation foam blocking off the grill and a kilowatt Zerostart so my first start of the day in my garage is fairly warm... not so much after it's been sitting outside this horrible winter.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#3302160 - 03/05/14 10:40 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
Clevy Offline
Loc: Saskatoon canada
3 summers ago when we first bought our forklift My dad and brother would just start it,work it for a half hour then shut it down.
We had a sample taken at 250 hours and iron was past 200ppm. Kraemer tractor called us and said they wanted to look at the machine because the previous used oil analysis were at 50ppm iron at 250 hours.
So they came out and did an inspection and found nothing wrong. So the technician asked how it was operated.
Once he heard about the frequent starting and shutting down he explained that's why the iron was so high.
So he told my dad the exact same thing I did. Diesel is cheap compared to an overhaul on one of these engine.
We now let it run all day. It start in the morning and gets shut off at days end. And our used oil analysis look consistent again without any anomalies.
So not really short tripping but it's an example of short runs and the added wear associated with cold starts.
2006 Charger RT
Miles x 2 per oil filter
#3302184 - 03/05/14 11:18 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
BMWTurboDzl Offline
Loc: Atlanta,GA
Off hand I can think of being stuck in perpetual regeneration with regards to the DPF. I would think slightly higher soot loading depending on whether it's hwy or city.
'15 435i - BMW branded Shell 5w30.
Prev
'10 335d
'06 330i
'03 330i
#3302204 - 03/05/14 11:35 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Nissan Leaf.
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3302735 - 03/05/14 08:59 PM Re: How bad is short tripping for a diesel engine? [Re: ARCOgraphite]
friendly_jacek Offline
Loc: southeast US
Originally Posted By: ARCOgraphite
Nissan Leaf.
Even plug-in hybrid will do fine in a 3 mile commute. Or better a bike or walk.
#3302750 - 03/05/14 09:09 PM Re: How bad is short tripping for a diesel engine? [Re: friendly_jacek]
Loc: Great Lakes
Thanks, all. Sounds like I should stay away from diesel here.
Sure. Please ask your wife to take a 3 mile walk in -10F weather with 2 feet of snow on the ground and report back from where you'll be sleeping tonight. smile
#3302768 - 03/05/14 09:28 PM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
Loc: southeast US
Same as every night: a dog house.
#3305881 - 03/09/14 01:30 AM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
sdude2k2000 Offline
Loc: Southern Oregon, USA
Someone said it already and I agree that the largest issue with short trips on a DPF equipped diesel deals with the regen process. Diesels produce more soot when cold... so the DPF is going to try and regen more frequently. That process takes approx 10-15min to complete (depending on your specific vehicle). So if the trip to & from work only takes 10ish minutes, then the cycle may not have adequate time to complete. If your vehicle uses post-cylinder-injection for igniting the DPF, then you'll more than likely run into fuel dilution issues which is already an issue even with normal operation. If your vehicle has an extra injector in the DPF, then fuel dilution is a moot point by comparison..
Edited by sdude2k2000 (03/09/14 01:31 AM)
'08 Ford Fusion SEL 3.0L
Pennzoil Ultra Plat 5w20 | Fram Ultra
'15 Toyota Prius
Pennzoil Ultra Plat 0w20 | Fram Ultra
#3306399 - 03/09/14 06:33 PM Re: How bad is short tripping for a diesel engine? [Re: Quattro Pete]
AP9 Offline
Loc: Chicago suburbs
There is also the possibility that if the regen never gets to complete, there will over time be enough soot buildup to require the DPF to be replaced.
2000 Ford Explorer XLT 4WD (4.0L OHV) - QSUD 5W-30/MC FL1A
1996 Chevrolet Impala SS - M1 0W-40/M1-201
Page 1 of 3 1 2 3 >
