Buying services for new vehicles?
by powayroger
10 minutes 13 seconds ago
Hard to find QSUD 0w20
by chiefsfan1
56 minutes 8 seconds ago
Small compressor advice + a story of stupidity
by dishdude
Today at 04:33 PM
w116 300sd Lower shock bolt type/size
by Gito
Today at 04:20 PM
FRAM XG7317 Cut Open
by HX520W
Today at 04:17 PM
weld leaking on transmission pan.
by motor_oil_madman
Today at 03:41 PM
PP and Honda CR-V
by klt1986
Today at 03:04 PM
113,800 miles on plugs w/ pics - 2009 F150 5.4 3V
by 04SE
Today at 02:59 PM
Sludged 1zz-fe pic... Ex-fleet car.
by SanProsan
Today at 02:53 PM
Autozone oil score today
by jdavis
Today at 01:12 PM
Valvoline V0-88, 5,000 miles, CUT OPEN
by car51
Today at 12:27 PM
Timken throwout bearings?
by buck91
Today at 12:17 PM
Compignite, pezman65, Wansu, DaleAZ, Nazmorgul
56846 Registered Users
85 registered (Al, amusing, 1foxracing, 440Magnum, 13Track38, 1989outlaw, 2 invisible), 1173 Guests and 203 Spiders online.
56846 Members
66 Forums
244380 Topics
Page 1 of 2 1 2 >
#3301515 - 03/04/14 05:48 PM Ready for Subaru front & rear differential change
Phishin Offline
Loc: Indiana
Package from Amazon arrived. I'm itching for my weekend project on my wife's Subaru.
12 quarts of Subaru ATF-HP on the bench top already....good for a couple D&F's on the tranny and power steering. Her Subaru is gonna be one happy girl by Saturday night.
Edited by Phishin (03/04/14 05:49 PM)
2010 Accord-LX K24: PU 5w30
2009 Subaru Forester 2.5X: M1 TDT
1990 Chevy K1500 350TBI: Frankenbrew
2008 Ruckus 50ccGET: M1R Mix
#3301525 - 03/04/14 05:55 PM Re: Ready for Subaru front & rear differential change [Re: Phishin]
JC1 Offline
Loc: Oshawa, Ontario Canada
The million dollar question is will you be a happy man Sunday morning after your front differential gets a treatment? Sorry I couldn't help myself.. LMAO.
Regards, JC.
#3301532 - 03/04/14 06:05 PM Re: Ready for Subaru front & rear differential change [Re: Phishin]
gathermewool Offline
Loc: New England
What's your plan for the rear diff?
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#3301543 - 03/04/14 06:11 PM Re: Ready for Subaru front & rear differential change [Re: gathermewool]
Phishin Offline
Loc: Indiana
I'm hoping it's one of those rare nights where the rear diff is easy to access....
#3301617 - 03/04/14 07:04 PM Re: Ready for Subaru front & rear differential change [Re: Phishin]
Loc: New England
Like, one of those nights where you park the car head first into a sink hole?
14 Forester XT
08 Civic LX (Auto)
#3301642 - 03/04/14 07:35 PM Re: Ready for Subaru front & rear differential change [Re: Phishin]
Rob_Roy Offline
Loc: Northern, NY
Did you order some extra gear oil? I bought three quarts and had some leftover when I did the front and rear diff's on my Legacy.
Can't be much fun trying to exchange that power steering fluid...the reservoir is tiny.
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
#3301648 - 03/04/14 07:40 PM Re: Ready for Subaru front & rear differential change [Re: Phishin]
sprintman Offline
Loc: Canberra ACT Australia
Used RL on our Outback a few years back and when changed at 50,000 km's the mechanic refused to believe it hadn't just been replaced.
#3301753 - 03/04/14 09:11 PM Re: Ready for Subaru front & rear differential change [Re: Phishin]
R80RS Offline
Loc: Wisconsin USA
That funnel is made with "High Grade Steel". Sweet.
2004 F150 214k mi. Amsoil XL 5w-20, Fram Ultra
2003 VW Jetta TDI, 199k mi. Amsoil HDD 5w-30, Mahle
#3301782 - 03/04/14 09:53 PM Re: Ready for Subaru front & rear differential change [Re: Rob_Roy]
Phishin Offline
Loc: Indiana
Yep....I bought enough for 2 services.
And yeah...the PS reservoir is ridiculously small. Should only take me 40 or so turkey baster drains to get out half the fluid.....
It's nice. Got a nice screen filter in it too. Only $10 from Amazon.
Edited by Phishin (03/04/14 09:55 PM)
#3301805 - 03/04/14 10:17 PM Re: Ready for Subaru front & rear differential change [Re: Phishin]
R80RS Offline
Loc: Wisconsin USA
Yup. Behrens products are good stuff.
#3301849 - 03/04/14 11:10 PM Re: Ready for Subaru front & rear differential change [Re: Phishin]
BHopkins Online   content
Loc: Utah
What are you planning on using for fluid on the PS? My Outback calls for Dexron V. I didn't see any in your pic, so I was curios.
As far as a method for the PS, someone on the SubaruOutback website mentioned a method where they used the turkey baster to drain the reservoir. Then the removed the drive belt from the ps pump, removed the return line from the bottom of the reservoir, and ran the return line into a waste container. Then turn the ps pump by hand until the fluid is all drained. Put the return line back on, fill the reservoir and turn the ps pump by hand until the system appears to be full. But the belt back on, take the car for a drive and make a few stop to stop turns, then top off the reservoir.
It seems that this method would be much more effective, and less expensive material wise, than the typical method of only draining the reservoir, driving for a few days, and repeating a couple times.
2013 Subaru Outback 2.5i - RP 0W-20 & NAPA Gold filter
2003 Oldsmobile Alero 3.4 - M1 5W-30 & NAPA Gold filter
#3301927 - 03/05/14 03:41 AM Re: Ready for Subaru front & rear differential change [Re: Phishin]
Phishin Offline
Loc: Indiana
I assumed PS used Subaru ATF....No?
#3302097 - 03/05/14 09:34 AM Re: Ready for Subaru front & rear differential change [Re: Phishin]
FutureDoc Offline
Loc: North Carolina
I am not sure about the Gen4 OB but older Subarus used ATF.
I "switch" between Supertech D/M AFT (red), Prestone PS fluid (yellow) and Supertech PS Fluid (green).
Use a vacuum pump with a large reservoir (I use a modified 1qt jar) and I drain the reservoir, refill with different color fluid, and, start/turn the wheel... and then repeat till the fluid is the color I want.
'01 MR2 Spyder,57K, Havoline Syn 5w30
'99 Subaru Legacy Outback, 208K, T5/QS-Wix
'14 Subaru Outback, Havoline 0w-20 & Wix
Fleet Manager, Ph.D.
#3302129 - 03/05/14 10:04 AM Re: Ready for Subaru front & rear differential change [Re: Phishin]
i812 Offline
Loc: Central, FL
The Forester specification are: Forester Specs
· SUBARU ATF
· IDEMITSU ATF HP
·0.7 US qt (0.7 liters, 0.6 Imp qt)
My Outback Specs are:
· SUBARU ATF
· IDEMITSU ATF HP
· “Dexron III” Type Automatic Transmission Fluid
Edited by i812 (03/05/14 10:04 AM)
'13 Outback Limited 3.6R
#3302165 - 03/05/14 10:49 AM Re: Ready for Subaru front & rear differential change [Re: Phishin]
Loc: New England
I had a very hard time adding gear lube to my Subies, even using the bottle that come with the extending neck (Motul.) I used a Wilmar W1145 pump purchased on Amazon, which worked very well. I also use a small syringe that I find at Wal-Mart for PSF exchanges. I know "turkey blaster" is the method , but for those who don't know, using an actual turkey blaster is messy and inefficient. A small syringe that comes with a small length of tygon tubing is ideal.
Edited by gathermewool (03/05/14 10:53 AM)
14 Forester XT
08 Civic LX (Auto)
Page 1 of 2 1 2 >
