my Buick 03 lesabre has a flashing radio light?
by snake123
8 minutes 24 seconds ago
5000 miles in the Caprice
by ls1mike
32 minutes 58 seconds ago
Copper Reactivity and BMW Blue Coolant
by TXCarGeek
Today at 09:24 PM
lubegard biotech xle
by mobilaltima
Today at 09:05 PM
Schaeffer 5w-40 in Jeep 4.0
by JeepWJ19
Today at 08:53 PM
PP and PU 45% off this wk at CT !!!
by ST2008
Today at 08:49 PM
Photographic evidence of HDEO / synth oil cleaning
by OldEuroCarLover
Today at 08:35 PM
Limited Slip Additive needed for G80?
by Nick1994
Today at 08:28 PM
4-5k will it even matter?
by Camprunner
Today at 08:19 PM
Purolator BOSS
by kenpoed
Today at 08:04 PM
Neither Key Fob Works!
by bobbob
Today at 07:59 PM
How long can I go?
by kenpoed
Today at 07:53 PM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
72 registered (01rangerxl, 4WD, AIRJAC3, AirgunSavant, 2015_PSD, 2004tdigls, 6 invisible), 1490 Guests and 10 Spiders online.
58973 Members
66 Forums
253837 Topics
Page 1 of 3 1 2 3 >
#3301259 - 03/04/14 01:19 PM Garbage disposal
daves87rs Offline
Loc: Michigan
It's kinda starting to look like I need a new one! My current one, a sinkmaster bonecrusher 850, came with the house when we bought it. This week, it has started to leak, as I am thinking the motor is pretty much toast on this one.
I know nothing of these, and a google search doesn't help either. I'm not even sure when it was made! (I looked at it too) Would be cool to repair it, but not sure that is going to happen.
So, if I wanted a new one, what would I look for? I want something simple and cheap. We clean our plates pretty well here... smile
Any info would be great!
Whatever you are, be a good one.
#3301262 - 03/04/14 01:22 PM Re: Garbage disposal [Re: daves87rs]
supton Offline
Loc: NH
Do you have a septic, or town sewer? If I had a septic tank I'd remove the garbage disposal, unless if I knew for sure it wasn't the reason for frequent pumping of the tank. It puts a lot of stuff into the tank; a coworker has one, his wife won't let him get rid of it. Says he has to clean the filter on the outlet of the tank every 3 months, or something outrageous like that.
Beyond that, sorry, I'm of no help...
2011 Toyota Camry, base, 6spd manual, 119k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 129k, his
#3301264 - 03/04/14 01:25 PM Re: Garbage disposal [Re: daves87rs]
GSCJR Offline
Loc: Ontario, Canada
Waste-King is the unit we have. Going on 10 years with no issues and easy to install. HTH.
03 3.0L 1MZ-FE FS 5w-20-ProSelect 21348-222 KM
10 3.5L 2GR-FE CEB 0w-20-ProSelect 27047-140 KM
#3301267 - 03/04/14 01:26 PM Re: Garbage disposal [Re: daves87rs]
SrDriver Offline
Loc: Southeast Alabama
You can find some U Tube videos on how to replace the unit along with recommendations on horse power, etc.
#3301272 - 03/04/14 01:30 PM Re: Garbage disposal [Re: daves87rs]
HTSS_TR Online   content
Loc: Lake Forest, CA
I had my garbage disposal replaced more than 10 years ago. I took a picture of the old one and found one exactly likes that at Costco for $30-40. Paid handy man $50-60 to replace it.
Costco doesn't carry it anymore, you should take some pictures of the old one then go to Lowes or Home Depot, they will be able to find one that matches it. If you are handy you can replace it in less than 1 hour.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3301283 - 03/04/14 01:43 PM Re: Garbage disposal [Re: daves87rs]
Jimmy9190 Offline
Loc: Clermont, Florida
If it is leaking out the bottom of the disposer the internal seals in the disposer are bad. The only way to fix it is to replace it, AFAIK the seals are not replaceable and even if they were replaceable the motor has now been sitting in water for maybe quite some time and should be replaced. I just had to replace my own disposer back in December. It was leaking very badly out the bottom of the unit. I bought an Insinkerator 1HP at Home Depot. It cost about $110.00 and works like a champ. It came with directions and a tool to tighten the disposer to the bottom of the sink drain. I found a Youtube video that showed how to remove the old one. It was an easy job and I was glad it did not cost too much. I would suggest getting the 1HP unit. The guy at HD was right when he told me the 3/4 HP is weak.
Jimmy9190
2013 Honda Civic LX Sedan
Napa Synthetic 0W20, Napa Gold 7356
#3301294 - 03/04/14 01:48 PM Re: Garbage disposal [Re: daves87rs]
zzyzzx Offline
Loc: Baltimore, Maryland, USA
These things are really easy to replace. Probably easier than an oil change on a car.
#3301302 - 03/04/14 01:54 PM Re: Garbage disposal [Re: daves87rs]
Donald Offline
Loc: Upstate NY
If its leaking where it mounts to the sink, they re-bed with plumbers putty. If its at the outlet/drain, probably loose.
If the unit itself is leaking, replace it.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3301318 - 03/04/14 02:03 PM Re: Garbage disposal [Re: daves87rs]
Schmoe Offline
Loc: Oklahoma
Lot of times there is a simple rubber washer that goes between the sink and the disposal. Most of the disposals are simple twist on with some sort of locking mechanism. See if it's coming from there and replace or build your own, gasket.
01 Supercrew Lariat 4X4
06 Accord EX V6
10 CRV EX-L
(traded 02 Accord EX V6 @ 208K miles for)
14 CRV EX-L
(traded 10 CRV for)
#3301331 - 03/04/14 02:13 PM Re: Garbage disposal [Re: daves87rs]
stephen9666 Online   sick
Loc: USA
I have a couple recommendations if it turns out it needs to be replaced.
Like a lot of things, only a couple companies make most of the units you can buy under various brands.
Waste King models have some good online reviews, but they're all made in China, if you care about that. You'll find Waste King models rebranded under some other brands.
Emerson's Insinkerator brand makes tons of models that are sold under many different brands. They're all made in the USA. The Emerson models range from the cheap Badger models to much more expensive models with lots of sound deadening, multiple grinding stages and stainless steel parts.
Our aged rebranded Badger died recently and I decided to go cheap and get another Badger to replace it. I kind of wish I had stepped up to a better model, but we don't use it a ton.
One of the better bargains I was considering is this Kenmore, which is a rebadged Emerson model. It has a good warranty, it's made in the USA and it has the nicer sound deadening and stainless grinding parts. It goes on sale sometimes, if memory serves.
http://www.sears.com/kenmore-3-4-hp-food...mp;blockType=G1
#3301600 - 03/04/14 06:42 PM Re: Garbage disposal [Re: daves87rs]
tom slick Online   sleepy
Loc: Central Coast, Calif.
Never had a problem with In-Sink-Erator. Their insulated models are very quiet. They are made in USA and start about $80 for a very basic unit.
You get what you pay for...
So keep in mind how much you paid for this advice.
#3301778 - 03/04/14 09:50 PM Re: Garbage disposal [Re: daves87rs]
The_Eric Online   content
Loc: Iowa
Ditch it and plumb the sink for a regular drain and pocket the savings. People put way too much stuff down the drain anyway. Either throw it in the waste bin and/or start a compost pile.
We used to have one... Replaced the one that came with the house against the advice of a former plumber coworker and also a Lowes employee who also used to be a plumber. When that one started leaking a few years later, we had enough... Replumbed the sink drain and haven't looked back. Honestly, I don't miss it one bit.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#3301894 - 03/05/14 12:47 AM Re: Garbage disposal [Re: daves87rs]
MNgopher Offline
Loc: Lakeville, MN
As noted, the first step is to figure out exactly where the leak is coming from. It may just be the gasket. If its anywhere on the unit itself, then its time to change it out.
I replaced our cheap insinkerator badger unit when it sprung a leak a few years ago. We upgraded in HP and sound deadening and both were noticeable. The new unit has way less vibration and is much, much quieter.
One of the easier home repalcement projects to do. Extremely simple.
#3302039 - 03/05/14 08:38 AM Re: Garbage disposal [Re: MNgopher]
Stelth Offline
Loc: California
If you end up replacing it, I recommend Waste King. Waste King, Whirlaway, and GE are all basically the same, but for some reason the Waste Kings seem to be generally more reasonably priced. I've had various ISE Badgers, and a Pro 333 myself, and they didn't last very long. Then I got a GE, and it's still going strong after more than 10 years. When it finally goes, I'll probably buy a Waste King Legend 8000 which has a lifetime in-home warranty.
Experts are often wrong, but rarely in doubt.
#3302127 - 03/05/14 10:03 AM Re: Garbage disposal [Re: The_Eric]
pandus13 Offline
Loc: Chicago,IL,USA
+1,000 on what he said!
OP, over the topic but,
this winter, i had my drain froze (probably the leftovers formed a cap) and had 2 fun days until it melted/let the chemicals make some room.
we do not use the garbage disposal a lot, we do not let grease down the drain, but it still happen to us.
13 Mazda5
08 Toyota Yaris Sedan
04 Elantra (sold)
95 accent (sold)
95 mystique (sold)
97 concorde (gone)
Page 1 of 3 1 2 3 >
