My father has a '93 Ford 2120 that her purchased new that has been used rather gently (1000hrs). The tractor is stored and used in Central Pa. Apparently he did not realize taht Diesel oils had different specs than gas engines, so he has primarily been running traditional gas engine oil.
Be/c he does not change the oil frequently and be/c I'd like to clean out anythign left behind with his extended change intervals, I want to change the oil to a synthetic. Is there any good reason not to go with Syntehtic at this point ? Would M1 5W-40 be a good bet for light year round use in Central Pennsylvania ?
