5w-40 synthetic vs 15w-40 synthetic
by mbacfp
11 minutes 41 seconds ago
SCAM!Anyone renting their water heater tank?
by KrisZ
22 minutes 58 seconds ago
Donaldson PowerCore as HEPA filter?
by PeterPolyol
25 minutes 40 seconds ago
Clearance oversized filters for M20x1.5 w/bypass
by PeterPolyol
33 minutes 36 seconds ago
Prestone vs. DEX-COOL Concentrate
by Ramblejam
44 minutes 22 seconds ago
Severe service and OEM oil Filters
by Tech819
52 minutes 52 seconds ago
ContiTech Pro Series timing belt kit 2009 Galant
by Ruturaj
Today at 12:25 PM
Bogus Coolant Test! - did Pat Goss make a mistake?
by i_hate_autofraud
Today at 11:57 AM
The "zero posters"
by OVERKILL
Today at 11:57 AM
Removing "Holder?" From Dash
by coopns
Today at 11:53 AM
Concrete Cleaners
by dkryan
Today at 11:45 AM
What makes CVTF?
by horse123
Today at 10:40 AM
karpouzi, Tapan, shindery, Josh_Westwood, Brogan
58283 Registered Users
90 registered (AirgunSavant, 69GTX, Al, 4WD, 901Memphis, 360kid, 8 invisible), 2139 Guests and 11 Spiders online.
58283 Members
66 Forums
250883 Topics
Page 2 of 3 < 1 2 3 >
#3272040 - 02/06/14 12:28 AM Re: Mobil 5w50 SN VOA [Re: LoneRanger]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Originally Posted By: LoneRanger
Nice but how might it hold up in a shared sump motorcycle with wet clutch? There's your test for sheer stability! wink
Probably not that great since it's made with lighter base stocks than a 10W-40 4T oil. But there is only one way to find out, try it and report back.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3272068 - 02/06/14 03:03 AM Re: Mobil 5w50 SN VOA [Re: CATERHAM]
Shannow Offline
Loc: Oz
Interested in how you can work that one out CATERHAM...got a hints for dummies on how to work out which base-stock is lighter ?
I look at the PDS for either and get a different answer re basestock weight.
#3281044 - 02/13/14 06:08 PM Re: Mobil 5w50 SN VOA [Re: Shannow]
CATERHAM Offline
5W oils use lighter base stocks than 10W oils, plus the the 5W-50 has a 180 VI, a further indication that relatively light base stocks are used. Are you going to argue with that?
#3283389 - 02/15/14 06:25 PM Re: Mobil 5w50 SN VOA [Re: CATERHAM]
Shannow Offline
Loc: Oz
Yes, I am going to argue with that.
firstly, 5W requiring lighter basestocks than 10W is a myth perpetuated even on the 101 on the front page... You don't "start with a 5W, and make it act like a 40/50 at the top end.
VII work both ends of the spectrum, improving the cold perforamnce, AS WELL AS the top end.
Don't believe me, then believe AFTON...
http://www.aftonchemical.com/ProductDataSheets/Lubricant%20Components/HiTEC-5710_PDS.pdf
Check out the treat rates of the 150N oil.
At a treat rate of 10%, in what's basically an ISO32 mineral oil, the characteristics are in the ballpark of the M1 5W-50 (very close, with a mineral, VI 100 basestock).
Note how the pour point has dropped from -15 to -42 in that example.
Note, this was a mineral "5W-50", with an ISO32 basestock.
Another manufacturer of VIIs (these are solid, not pre-diluted)
http://www.functionalproducts.com/Catalogs/Solid_VII_Products.pdf
Lists the starting oil for their 10W-40 recipe (page 4) as also an ISO 32...
So it's entirely possible that a 10W-40 and a 5W-50 could have identical basestocks...your assertion that the 40 has to have heavier basestocks because it's a 10W is not true.
As to why I called you out in the first place, looking at the PDS' for either oil
http://www.mobil.com/Australia-English/Lubes/PDS/GLXXENPVLMOMobil1_Racing_4T.aspx
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_5W-50.aspx
shows the 10W-40 has a flash point of 212C, while the 5W-50 has 231C...logically, the 5W-50 is made of "heavier" stuff than the 10W-40, most likely base-stocks, as the VII additives tend to be somewhat lower in FP.
#3283570 - 02/15/14 10:04 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
JHZR2 Offline
Loc: New Jersey
Didn't realize this was a product available in NA!
#3284398 - 02/16/14 05:52 PM Re: Mobil 5w50 SN VOA [Re: JHZR2]
CATERHAM Offline
Yes it's made and bottled in US quarts in the States but distribution is limited.
#3285423 - 02/17/14 05:14 PM Re: Mobil 5w50 SN VOA [Re: CATERHAM]
dailydriver Online   content
Loc: Bucks County, Pa.
Some NAPAs and select speed shops carry it.
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3285433 - 02/17/14 05:27 PM Re: Mobil 5w50 SN VOA [Re: dailydriver]
Clevy Offline
Loc: Saskatoon canada
I got like 10 quarts in my yard sale oil score a few years ago. I tried it in my Harley. Didn't like it.
In hindsight I should have saved it.
2006 Charger RT
Miles x 2 per oil filter
#3286478 - 02/18/14 05:32 PM Re: Mobil 5w50 SN VOA [Re: Clevy]
Wilhelm_D Offline
Loc: Tacoma, WA
Originally Posted By: Clevy
How exactly is dumping oil that isn't depleted and replacing it with oil that isn't depleted "cheap insurance"
Price oil. Price an engine. Voila!
#3286521 - 02/18/14 06:12 PM Re: Mobil 5w50 SN VOA [Re: Wilhelm_D]
Clevy Offline
That makes no sense.
How does draining oil that is still serviceable,and replacing it with oil that is serviceable cheap insurance. If the oil isn't depleted then its performing the same as new oil.
Actually since engine oil requires some oxidation to perform as intended the old oil is providing better protection.
Wanna try that voila again?
2006 Charger RT
#3286563 - 02/18/14 07:05 PM Re: Mobil 5w50 SN VOA [Re: Clevy]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Looking at the math, what I saved on oil and filters in the taxis by doubling the OCI and sticking to conventional was significant. Going to manufacturers recommended OCIs and synthetics for "cheap insurance" would have bought each taxi a brand new crate engine at the end of their service life, which wasn't needed anyhow since the engines ran fine while everything else was falling apart.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3297894 - 03/01/14 12:37 AM Re: Mobil 5w50 SN VOA [Re: Matt_N]
Shannow Offline
Loc: Oz
$36 for 5 litres today at Supercheap...
Bought the limit (1).
#3298347 - 03/01/14 02:50 PM Re: Mobil 5w50 SN VOA [Re: Shannow]
For the M1 5W-50??
If so, then they are giving it away considering the normal Ozzie prices!!
M1-206 oil filter
#3298416 - 03/01/14 04:20 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
Shannow Offline
Loc: Oz
Yep, half price on 5W-30, 0W-40, and 5W-50.
last 5L bottle of M1 in my store, so word is out.
Bought some shell helix for less than $3/l the other day.
Something's moving
#3304551 - 03/07/14 02:18 PM Re: Mobil 5w50 SN VOA [Re: Clevy]
Matt_N Offline
Loc: Akron, OH
Sounds more like expensive insurance considering if the tbn is at 7 and starts at 9 or 10 you've effectively thrown money out the window.
Cheap insurance,right,because the oil is some kind of risk.
Simple. Rather than spending $35 on a UOA+TBN, I spend $40 and put fresh oil in. I periodically send samples to make sure wear metals are in order, but not every OCI. If, as you suggest, I were using UOA+TBN to make sure I was getting every last ounce of life out of the oil, I'd be spending hundreds in oil analyses before finally changing the oil.
My engine spends about 25% of it's total miles at Mid Ohio Sports Car Course or Watkins Glen. Under those conditions, I'd rather have the piece of mind of KNOWING my oil is fresh, instead of wondering if the next sample is going to come back with TBN of 0.9 or [email protected] of 11.0 and wear metals through the roof. So to me, the $5 difference between sending in a sample or just changing the oil is cheap insurance.
Nevermind that Porsche re-manufactured engine is $13,000 + 30hrs labor.
