Is Legalizing Marijuana Safe????
by qwerty1234
05/30/16 03:44 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
05/30/16 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
05/30/16 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
kevinstoyhauler, jimx1169, W9HDG, LloydChristmass, dodge96
58019 Registered Users
18 registered (bernau, ASW338, bubbatime, asand1, bbhero, 2 invisible), 560 Guests and 310 Spiders online.
58019 Members
66 Forums
249584 Topics
Page 2 of 2 < 1 2
#3295471 - 02/26/14 07:14 PM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
GreeCguy Offline
Loc: Elderly County, Florida
Thanks for the replies fellows. "Wonder the Thunder Pig" is currently at 153,000 and I noticed yesterday the pump seemed to be on the loud side. It also seems to labor under load, (climbing hills and accelerating from a stop). Pretty sure it's the original pump. Didn't know if it was me or if that was a warning sign of problems in the near future. I think for the sake of not being stranded in the middle of no where in the middle of the night, I'll be dropping the tank and replacing the pump this Saturday.
"Dyslexics are teople poo!!."
#3295484 - 02/26/14 07:26 PM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
yonyon Offline
Loc: NJ, USA
Another sign of a fuel pump about to quit is feeling a sudden, inexplicable, and urgent need to completely fill up your gas tank even though it has enough gas in it already. If this happens you should not shut the engine down until you drive to wherever you're going to replace the pump. If you feel that you must fill up the tank right away and can't fight the urge you can leave the engine running while you fill up.
#3295506 - 02/26/14 07:43 PM Re: Warning signs of a failing fuel pump [Re: Donald]
clinebarger Offline
Loc: Fort Worth, Texas
Originally Posted By: Donald
Buying a GM vehicle.
The Lift pumps on 24v Cummins engine's are known for their reliability....Right??? The fact it takes out the Injection Pump if ran too long is just icing on the cake.
Back on track....When was the last time the fuel filter changed? A clogged filter will make the pump louder.
2001 Chevy Camaro 5.3L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3295589 - 02/26/14 09:13 PM Re: Warning signs of a failing fuel pump [Re: clinebarger]
GreeCguy Offline
Originally Posted By: clinebarger
[quote=Donald]Back on track....When was the last time the fuel filter changed? A clogged filter will make the pump louder.
Just changed it about a month ago.
#3295613 - 02/26/14 09:41 PM Re: Warning signs of a failing fuel pump [Re: yonyon]
Vikas Offline
Loc: NorthEast
Knowing you, I think you are joking. I presume you expect having to drop the tank to replace the fuel pump and by Murphy's Law, you will need to do it just when the gas tank is completely full!
But then again, sometimes you are serious, so one never knows!
#3295630 - 02/26/14 09:51 PM Re: Warning signs of a failing fuel pump [Re: clinebarger]
Donald Offline
Loc: Upstate NY
I have an AirDog to go in to replace the current lift pump.
Cummins did their best to make a great engine, and Dodge did their best to screw it up with a poor lift pump, then moved it into the tank and still more problems.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3295644 - 02/26/14 10:01 PM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
TooManyWheels Offline
Loc: Houston, Tex
A mechanic who is up on the technology can monitor the waveform of the pump circuit with a scanner and tell when it is underperforming, i.e. about to die. I don't have a link handy, but it shouldn't be hard to find.
#3295686 - 02/26/14 10:36 PM Re: Warning signs of a failing fuel pump [Re: Vikas]
yonyon Offline
Loc: NJ, USA
I'm serious this time.
#3295688 - 02/26/14 10:41 PM Re: Warning signs of a failing fuel pump [Re: TooManyWheels]
yonyon Offline
Loc: NJ, USA
This is pretty much true, but requires an oscilloscope or equivalent tool. Some scan tools will have that built in, but not all and not any cheap ones.
#3295840 - 02/27/14 06:55 AM Re: Warning signs of a failing fuel pump [Re: Donald]
George7941 Offline
Loc: Toronto, Canada
The blame for the lift pump goes to Cummins, not Dodge. Cummins supplied the Carter-sourced lift pump mounted on the block. I agree that Dodge's in-tank pump wasn't very good.
2006 GMC Sierra 4.3l, NV3500,G80 , Formula Shell Synthetic 5W30,Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
#3296130 - 02/27/14 11:13 AM Re: Warning signs of a failing fuel pump [Re: yonyon]
Vikas Offline
Loc: NorthEast
And frankly, if I ever see a real mechanic who gets paid on the flat rate ever did that in a real life (vs youtube) I would probably die of heart attack! Seriously, driveablity specialist are extremely rare breed and you won't find them employed by a corner gas station or a generic car dealer.
#3296620 - 02/27/14 06:24 PM Re: Warning signs of a failing fuel pump [Re: Vikas]
yonyon Offline
Loc: NJ, USA
The best driveability guy I ever knew was working at a gas station when I met him, but he was salaried, not on flat rate. I worked with him for a few years and in that time I never saw him put the scope on a fuel pump.
Edited by yonyon (02/27/14 06:24 PM)
#3296894 - 02/27/14 11:08 PM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
artificialist Offline
Loc: Florida
sometimes when a car doesn't start due to a failed fuel pump, you can smack the gas tank, and it will make the pump work again.
But you can't count on this method.
2010 Lancer Ralliart Sportback
#3296936 - 02/28/14 01:07 AM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
Nick R Offline
Loc: Albany, NY
Our expedition had no warning. Just started, chugged for a few seconds, and then died. Fortunately it was right across the street when this happened, but it gave me no warning when it did.
2013 Ford Focus SE 2.0L/70,000miles/Motorcraft Blend 5W-20/FL-910S
Page 2 of 2 < 1 2
