$1.33 for a GALLON of 87!
by Vern_in_IL
8 minutes 45 seconds ago
Eating out, beware you all
by CourierDriver
25 minutes 15 seconds ago
Best Sponge For Washing Cars
by George7941
30 minutes 5 seconds ago
Old school (ethanol) and (leaded) fuels
by mjoekingz28
Today at 05:37 PM
Opinions on this oil filter relocation setup
by bspag
Today at 04:42 PM
E-brake tightening on Cobalt Chevrolet
by mjoekingz28
Today at 04:32 PM
Mobil 1 EP rollbacks at local Walmart
by HTSS_TR
Today at 04:29 PM
GM worker Saves a life on company property.
by Charlie1935
Today at 03:43 PM
Idle wear
by DrRoughneck
Today at 03:27 PM
Download a WHOLE site? AllData, Toyota TIS etc
by SumpChump
Today at 03:07 PM
Mixing washer fluid with windex?
by 55Test
Today at 02:48 PM
Car won't start, no gas movement observed, pump?
by Hal9000
Today at 02:39 PM
Miningman, pocketdrummer, bspag, Lana, phem0r
56883 Registered Users
107 registered (barkingspider, akela, 901Memphis, Astro14, adamrc, Abakev, 12 invisible), 1554 Guests and 208 Spiders online.
56883 Members
66 Forums
244520 Topics
Page 2 of 2 < 1 2
#3295471 - 02/26/14 07:14 PM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
GreeCguy Offline
Loc: Elderly County, Florida
Thanks for the replies fellows. "Wonder the Thunder Pig" is currently at 153,000 and I noticed yesterday the pump seemed to be on the loud side. It also seems to labor under load, (climbing hills and accelerating from a stop). Pretty sure it's the original pump. Didn't know if it was me or if that was a warning sign of problems in the near future. I think for the sake of not being stranded in the middle of no where in the middle of the night, I'll be dropping the tank and replacing the pump this Saturday.
"Dyslexics are teople poo!!."
#3295484 - 02/26/14 07:26 PM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
yonyon Offline
Loc: NJ, USA
Another sign of a fuel pump about to quit is feeling a sudden, inexplicable, and urgent need to completely fill up your gas tank even though it has enough gas in it already. If this happens you should not shut the engine down until you drive to wherever you're going to replace the pump. If you feel that you must fill up the tank right away and can't fight the urge you can leave the engine running while you fill up.
#3295506 - 02/26/14 07:43 PM Re: Warning signs of a failing fuel pump [Re: Donald]
clinebarger Offline
Loc: Fort Worth, Texas
Originally Posted By: Donald
Buying a GM vehicle.
The Lift pumps on 24v Cummins engine's are known for their reliability....Right??? The fact it takes out the Injection Pump if ran too long is just icing on the cake.
Back on track....When was the last time the fuel filter changed? A clogged filter will make the pump louder.
2001 Chevy Camaro 5.3L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3295589 - 02/26/14 09:13 PM Re: Warning signs of a failing fuel pump [Re: clinebarger]
GreeCguy Offline
Originally Posted By: clinebarger
[quote=Donald]Back on track....When was the last time the fuel filter changed? A clogged filter will make the pump louder.
Just changed it about a month ago.
#3295613 - 02/26/14 09:41 PM Re: Warning signs of a failing fuel pump [Re: yonyon]
Vikas Offline
Loc: NorthEast
Knowing you, I think you are joking. I presume you expect having to drop the tank to replace the fuel pump and by Murphy's Law, you will need to do it just when the gas tank is completely full!
But then again, sometimes you are serious, so one never knows!
#3295630 - 02/26/14 09:51 PM Re: Warning signs of a failing fuel pump [Re: clinebarger]
Donald Offline
Loc: Upstate NY
I have an AirDog to go in to replace the current lift pump.
Cummins did their best to make a great engine, and Dodge did their best to screw it up with a poor lift pump, then moved it into the tank and still more problems.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3295644 - 02/26/14 10:01 PM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
TooManyWheels Offline
Loc: Houston, Tex
A mechanic who is up on the technology can monitor the waveform of the pump circuit with a scanner and tell when it is underperforming, i.e. about to die. I don't have a link handy, but it shouldn't be hard to find.
#3295686 - 02/26/14 10:36 PM Re: Warning signs of a failing fuel pump [Re: Vikas]
yonyon Offline
Loc: NJ, USA
I'm serious this time.
#3295688 - 02/26/14 10:41 PM Re: Warning signs of a failing fuel pump [Re: TooManyWheels]
yonyon Offline
Loc: NJ, USA
This is pretty much true, but requires an oscilloscope or equivalent tool. Some scan tools will have that built in, but not all and not any cheap ones.
#3295840 - 02/27/14 06:55 AM Re: Warning signs of a failing fuel pump [Re: Donald]
George7941 Online   content
Loc: Toronto, Canada
The blame for the lift pump goes to Cummins, not Dodge. Cummins supplied the Carter-sourced lift pump mounted on the block. I agree that Dodge's in-tank pump wasn't very good.
2006 GMC Sierra 4.3l, NV3500,G80 locker rear, Formula Shell Synthetic 5W30, Wix 51036, Dexcool.
1987 BMW R80
Staying out of the right lane a lot.
#3296130 - 02/27/14 11:13 AM Re: Warning signs of a failing fuel pump [Re: yonyon]
Vikas Offline
Loc: NorthEast
And frankly, if I ever see a real mechanic who gets paid on the flat rate ever did that in a real life (vs youtube) I would probably die of heart attack! Seriously, driveablity specialist are extremely rare breed and you won't find them employed by a corner gas station or a generic car dealer.
#3296620 - 02/27/14 06:24 PM Re: Warning signs of a failing fuel pump [Re: Vikas]
yonyon Offline
Loc: NJ, USA
The best driveability guy I ever knew was working at a gas station when I met him, but he was salaried, not on flat rate. I worked with him for a few years and in that time I never saw him put the scope on a fuel pump.
Edited by yonyon (02/27/14 06:24 PM)
#3296894 - 02/27/14 11:08 PM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
artificialist Offline
Loc: Florida
sometimes when a car doesn't start due to a failed fuel pump, you can smack the gas tank, and it will make the pump work again.
But you can't count on this method.
2010 Lancer Ralliart Sportback
#3296936 - 02/28/14 01:07 AM Re: Warning signs of a failing fuel pump [Re: GreeCguy]
Nick R Offline
Loc: Albany, NY
Our expedition had no warning. Just started, chugged for a few seconds, and then died. Fortunately it was right across the street when this happened, but it gave me no warning when it did.
2013 Ford Focus SE 2.0L/67,000miles/Motorcraft Blend 5W-20/FL-910S
Page 2 of 2 < 1 2
