Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
5 minutes 15 seconds ago
2007 corolla oil pan steel or aluminum?
by Rolla07
41 minutes 24 seconds ago
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
51 minutes 55 seconds ago
Paint correction
by mjoekingz28
53 minutes 12 seconds ago
Filtertran Filter From My Vehicle 96K Miles
by oil_abuser
55 minutes 48 seconds ago
Bleeding brakes cleanly
by mjoekingz28
57 minutes 43 seconds ago
Any thoughts on the Super Bumper? (Hitch Bumper)
by Fsharp
Today at 08:37 PM
Ransomware.....
by BrianF
Today at 08:22 PM
Electic motor lube oil
by Ztill
Today at 07:39 PM
CJ-4 Synthetic Oil for Kawasaki FX engine?
by lawnguy
Today at 06:54 PM
Body was there for months......
by OVERKILL
Today at 06:23 PM
Promotive by Purolator ph241/pl10241 13 months/10k
by Xrs2zz
Today at 06:01 PM
SkipKaye, MikeHancho, tempnexus, cobra1616z, meyer
56896 Registered Users
99 registered (901Memphis, 01_celica_gt, 2015_PSD, 04SE, 2009Edge, 5 invisible), 1447 Guests and 222 Spiders online.
56896 Members
66 Forums
244573 Topics
Page 1 of 2 1 2 >
#3294541 - 02/26/14 12:31 AM 02' Buick Century, PP 5w30, 5,738 miles, High lead
901Memphis Online   content
Loc: Northern Kentucky
Code:
OIL             PP 5w30
MILES IN USE    5,738
MILES           98,603
SAMPLE TAKEN    2/22/14
ALUMINUM        10
CHROMIUM        1
IRON            32
COPPER          32
LEAD            40
TIN             2
MOLYBDENUM      51
NICKEL          1
MANGANESE       1
SILVER          0
TITANIUM        8
POTASSIUM       6
BORON           13
SILICON         52
SODIUM          12
CALCIUM         2151
MAGNESIUM       9
PHOSPHORUS      604
ZINC            759
BARIUM          0
INSOLUBLES      0.4
WATER           0.0
FLASHPOINT F   415
SUS VIS 210F   62.1
cSt @ 212F     10.82
TBN             1.5
Originally Posted By: Blackstone
Wear metals are pretty high here. Aluminum shows piston wear and iron is from steel parts.
Copper and lead traditionally show bearing wear and lead at 40 ppm shows a lot of it. Copper can also be
from any other brass/bronze parts. You mentioned changing the air filter. Silicon is quite high here, so maybe
some abrasive dirt was getting into the engine. That might explain the metal, but there could be a problem
here too. No fuel showed up. The TBN shows a little active additive left at 1.5, but try just 3,000 miles on the
next oil and resample.
This is a sample from my 2002 Buick Century. Fill was Pennzoil Platinum 5w30 API SN + a older Made in the USA K&N HP-1001 oil filter w/filtermag.
Previous air filter was a K&N air filter and very shortly after changing the oil i went to change the air filter and the gasket was trashed and the filter was collapsed letting dirt into the engine the whole time. I am guessing there was a lot of abrasive dirt in the engine from the entire time the K&N was letting unfiltered air in the engine.
Link here w/pics. - http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3030430
I used techron 3 times during this fill, had very high idle time in the cold sometimes 4-5 hours a week. Not sure if the techron leached lead out like i have heard before? I sure wish the lead was from something else.
The engine consumes zero oil, and the 0.6 quarts i added for top up were just the leftovers from the 5.1 quart jug i had since the engine only takes 4.5 with a oil change and i dumped that in probably halfway through the oci.
Right now it has the whole PU 5.1 quart jug in there with an oversize Fram XG filter.
I am going to start doing shorter changes in the future and monitor the lead. I have seen high iron/high copper GM engines last awhile but not with high lead. I saw a light amount of copper glitter in the bottom of the oil pan when i drained it.
I can still see the Ti from the last fill of Kendall GT1. Interesting to see the TBN so low after only 5,700 miles with the extra half a quart i threw in there halfway through the OCI.
2002 Buick Century 118k - Built 4T65e - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317
#3294548 - 02/26/14 12:54 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
johnachak Offline
Loc: L.I. NY USA
Copper sparkles in the oil pan is never a good sign. I hope you changed the air filter in time. I have read that the K&N oil filters are high flow filters. Wonder if it was letting too much of the sucked in dirt circulate. Well, you did what you can and hopefully, those numbers will improve after a short oci or two. Good luck.
06 Ford Freestyle, PP syn 5w20 MC filter
09 CTS 3.6 D.I. AWD, M1 5w30 Delco filter
Daughters Jeep Compass 2011, 2.4 AWD, 4WD switchable on the fly.
JMH
#3294550 - 02/26/14 01:11 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: johnachak]
I was told by motorking that when Fram was making the made in USA filter like i had on my vehicle it was mid 90s efficiency, so it was supposed to be just like the M1 filters.
#3294619 - 02/26/14 06:31 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
bigt61 Offline
Loc: Virginia
Seems like the air filter is now fixed - cut back on the Techron and let it eat. That 3.1L V6 is hard to kill.
92 Suburban 2500 7.4L 58k M1_5w30 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 29k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#3294702 - 02/26/14 08:18 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
gregk24 Offline
Loc: FL, USA
Copper in the oil pan? That cant be good. Hard to believe dust/dirt ingestion would cause copper flakes. I would be giving K&N a call/email and let them know whats up.
2012 Honda Accord EX-L 36K
M1 AFE 0w20 / Fram Ultra
2005 Chevy Uplander 133K
QSD 5w30 / Fram Ultra
1991 Buick Park Avenue 120K
Supertech 5w30 / Fram Ultra
#3294723 - 02/26/14 08:32 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: gregk24]
Kuato Offline
Loc: 327km N of the other border
And send them the oil report when you do.
Resampling at 3k sounds like a good plan; hopefully with better air filtration thr numbers will return to normal levels.
Apostrophe and spelling nazi.
Amsoil
13 F150, 5.0, 69000km (43k mi)
04 Wrangler, 2.4, 312000km (194k mi)
#3294746 - 02/26/14 08:50 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Has the LIM been repaired - IDK if this year had LIM issues. You have some K there but not a ton. What coolant are you running?
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#3294802 - 02/26/14 09:37 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Si is super high-bet the XG catches it & you'll be good.
06 Ram 3500 CTD 4X4 48RE SRW, 93 GMC C3500 6.2 diesel, 89 F-450 7.3 IDI, 98 Cherokee 4.0, 05 Scion xB, 15 Transit 250 3.7
#3294872 - 02/26/14 10:59 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: ARCOgraphite]
Yes it was repaired in 2010. Not sure if it's still washing coolant out. I'm using G05.
#3295507 - 02/26/14 07:43 PM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: gregk24]
K&N already replaced the damaged air filter but I got rid of it for a high efficiency PureOne. I will re sample the PU after 3k and continue to monitor my wear.
Maybe it's just my lead foot? I heard that an sae paper pointed to most wear coming from acceleration and load rather than cold starts like some others believe. I do give it WOT when it's warm often.
#3295519 - 02/26/14 07:58 PM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
Clevy Offline
Loc: Saskatoon canada
To me the dirt ingestion turned the oil into a 300 grit abrasive fluid which ground at the bearings and cylinder walls.
Personally I would have run a couple of wash out oil changes with something g cheap to try an purge the system of any residual grit then run an extended interval of ultra testing it at 5000 and 7500 miles to see what's up.
If you really want to get all that stuff out of there I suggest mmo or seafoam added to the oil right now then drain it in 500 miles.
Then cheap conventional and mmo or seafoam and another short wash out interval.
Do that twice then run an extended drain and retest just to spot any changes.
2006 Charger RT
Miles x 2 per oil filter
#3295641 - 02/26/14 09:58 PM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
I will probably use my peak conventional 5w30 for the next short interval then a Franken brew after that with more peak leftovers and some Mobil 1 TDT 5w40 I got on clearance.
#3298827 - 03/02/14 01:52 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
Merkava_4 Offline
Loc: Clovis, CA
Switch over to Airaid 850-214
#3299067 - 03/02/14 10:35 AM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: 901Memphis]
Boss302fan Offline
Loc: Oconomowoc Wi
Standard stock air filter... Then use PYB and any decent oil filter.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#3300276 - 03/03/14 01:38 PM Re: 02' Buick Century, PP 5w30, 5,738 miles, High lead [Re: Boss302fan]
It's got a PureOne in there, which is a very high efficiency lightly oiled media type filter. It should be about the best thing i can put in there to reduce silicone, and as much of a pain in the rear it is to change the filter on these cars, i plan on not touching it for awhile!
I've got an over sized Ultra on there right now, i am debating on leaving it on there for 2 x 3,000 mile OCI. I know the filter can handle it but knowing i had possible contamination just wants me to get it off of there.
It's unfortunate that i already put the Pennzoil Ultra in there, but i have to dump it around 3,000 miles like Blackstone recommended in case i still have high metals.
I have another Fram Ultra laying around and a standard sized Wix filter too i may use next for the shorter intervals.
I will almost surely go with PYB for my next shorter drains and save my jug of PU for a latter time.
Page 1 of 2 1 2 >
