How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
06/27/16 09:41 PM
Carpet cleaning methods.
by Run
06/27/16 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
06/27/16 09:26 PM
Emtrac Plus Battery
by Tapan
06/27/16 09:25 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
21 registered (edhackett, car51, Bill_G, bbhero, ac_tc, 1 invisible), 703 Guests and 10 Spiders online.
58295 Members
66 Forums
250917 Topics
Page 1 of 2 1 2 >
#2498558 - 01/18/12 09:08 PM delvac 15w40 10kmil detroit s60 14l
ColumbiaBob Offline
Loc: salt lake city, ut
this is in 05 freightliner columbia with detroit s60 14L EGR engine, with 755445 miles on engine and 10176 on oil delvac 15w40. I'm also using amsoil bypass filter for bigrigs. First time doing this. Did oil analysis at Speedco. Pls look over it and let me know how does it look. thx.
<2 Aluminium
<2 Chromium
3 Copper
3 Iron
<2 Lead
<2 TIN
15 Silicon
<2 Potassium
9 Sodium
33 Moly
<0.1 Water
2.0 Oxidation
14.4 [email protected]
- Glycol
<2.0 Fuel
8.5 TBN
6.3 Nitration
0.2 Soot
#2498574 - 01/18/12 09:19 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
Chris142 Offline
Loc: apple valley, ca
Put it back in!
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2498584 - 01/18/12 09:23 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
JRed Offline
Loc: Virginia
Wow...
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2498589 - 01/18/12 09:27 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
azsynthetic Offline
Loc: Phoenix AZ
Look at the soot number, the Amsoil bypass filter works per design.
#2498869 - 01/19/12 04:36 AM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
dnewton3 Offline
Loc: Indianapolis, IN
Welcome to the site!
Outstanding UOA. No reason to change that oil. Continue to use as is, and get another UOA in another 10k miles.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#2509552 - 01/29/12 04:50 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
ColumbiaBob Offline
Update
Well just did analysis at speedco and here are the results
Truck mil 767714
Oil mil 17514
Mobil delvac
Aluminum 5
Chromium <2
Cooper 3
Iron 2
Lead <2
TIN <2
Silicon 6
Potassium 2
Sodium 7
Moly 35
Water <0.1
Oxidation 5.8
[email protected] 14.5
Glycol ND
Fuel <2.0
TBN 8.5
Nitration 2.6
Soot 0.3
Had to add less than a gal so far ,oxidation and aluminum went up is that normal?
#2510210 - 01/30/12 10:14 AM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
dnewton3 Offline
Wow! Low soot; low wear; decent vis; high TBN. That load has life left in it.
#2522628 - 02/02/12 03:01 AM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
mongo161 Offline
Loc: Coney Island, NY
Outstanding results with Mobil Delvac! Thanks for posting both UOA's.
I get by with a little help from my friends....listen with your eyes....it's the ONLY way to believe what you hear...
#2523567 - 02/02/12 10:11 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
ColumbiaBob Offline
thx for comments, I used to change oil every 10k to 15k(before bypass filter and doing oil analysis), i'm not sure how far i can take this oil? I'm at 20k now, any suggestions? thx
#2523749 - 02/03/12 06:22 AM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
dnewton3 Offline
Yes, actually I'd suggest you change your way of thinking.
Don't think about how many miles will limit your OCI. Rather, set condemnation limits for the lube and run as many miles as you can to get there.
For example, here is a thread with some limits from many of the major diesel engine makers:
http://www.calrecycle.ca.gov/Publications/UsedOil/2008020.pdf
Look at page 11 of the report.
You'll see that soot might be limited at 3%. Fe might be around 100ppm. Cu at 30ppm. Etc, etc.
Too many people do not understand how to use a UOA. The goal is NOT to get low wear numbers. The goal is to set safe, effective limits for the lube, and then operate the lube up to that safe level. Once you reach or get near a limit, then you change oil.
Don't limit your OCI; limit your lube!
#2607937 - 04/23/12 10:35 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
Gene K Offline
Loc: Decatur AL USA
Imcluded for reference. I know this post is a few months old.
www.ddcsn.com/cps/rde/xbcr/ddcsn/DDC-SVC-BRO-0001.pdf
Table 4.3
Standard Interval is 15,000 miles.
However notice the note at the bottom of the chart:
"The oil drain interval for Engines with EGR can be increased to 22,500 miles if the oil used is PGOS 93K218 or 93K214 approved".
Mobil Delvac 1300 CJ4 is on the 93K218 approved list.
With a Bypass Filter its possible with synthetic you wouldnt even have to change the filter. I think the biggest issue might be the
Here is an analysis with Rotella T3 (The cheap fleet oil but also PGOS 93K218 approved) in my Series 60 EGR with 22500 miles. This is without a bypass filter.
Code:
34 - Iron
1 - Chromium
0 - Nickel
2 - Aluminum
0 - Copper
2 - Lead
0 - Tin
0 - Cadmium
0 - Silver
0 - Vanadium
3 - Silicon
2 - Sodium
3 - Potassium
0 - Titanium
46 - Molybdenum
0 - Antimony
0 - Manganese
0 - Lithium
12 - Boron
1064 - Magnesium
1088 - Calcium
1 - Barium
1106 - Phosphorous
1360 - Zinc
<1.0 - Fuel Dilution % Vol
0.7 - Soot % Vol
<0.1 - Water % Vol
14.4 - Viscosity 100 C cSt
5.26 - Base Number mg KOH/g (D4739)
12 - Oxidation abs/cm
19 - Nitration abs/cm
Sample #1
18-Jul-2011 Date Sampled
27-Jul-2011 Date Received
28-Jul-2011 Date Tested
60 Days / 22,500 miles - Lube Time
519,388 miles (Odometer / Actual is 606,908) - Unit Time
Yes - Lube Change
1 gallon - Lube Added
Yes - Oil Filters Changed
Gene
2014 Mustang GT 5.0 SC - 675 bhp
PP 10W30 / FL500S
2015 F150 4x4 2.7 EB
PSB Gold 5W30 / FL2062
2015 Enclave 3.6
GM Dexos 5W30 / PF63
#2608022 - 04/24/12 01:05 AM Re: delvac 15w40 10kmil detroit s60 14l [Re: Gene K]
Gene K Offline
Loc: Decatur AL USA
Table 4.3
Code:
34 - Iron
1 - Chromium
0 - Nickel
2 - Aluminum
0 - Copper
2 - Lead
0 - Tin
0 - Cadmium
0 - Silver
0 - Vanadium
3 - Silicon
2 - Sodium
3 - Potassium
0 - Titanium
46 - Molybdenum
0 - Antimony
0 - Manganese
0 - Lithium
12 - Boron
1064 - Magnesium
1088 - Calcium
1 - Barium
1106 - Phosphorous
1360 - Zinc
0.7 - Soot % Vol
<0.1 - Water % Vol
Sample #1
Yes - Lube Change
Ignore the following line in my original post. It was fragments of several sentences accidentally run together during editing: With a Bypass Filter its possible with synthetic you wouldnt even have to change the filter. I think the biggest issue might be the
Gene
PP 10W30 / FL500S
2015 Enclave 3.6
#2609599 - 04/25/12 04:22 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
kenneth neeley Offline
Loc: London,KY
Our 60 series run on Delo 10w30 with no bypass filtration run 32kand drains along with the ISX. Mack E-7 and ACET operate on 28k drains with factory spinner. We currently have some older E7 engines with over 1.9 million on them without pulling heads or pan off.
2006 Dodge M/C 5.9-48RE
2003 Chevrolet 2500HD. 3.73's, 5 exhaust,PPE Xcelerator, 513/1098 Gone.....
#3288766 - 02/20/14 06:40 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
Chris142 Offline
Stevens out of mesquite TX was going 40K on delvac back in 1998.
87 F250 delo 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#3292101 - 02/23/14 07:24 PM Re: delvac 15w40 10kmil detroit s60 14l [Re: ColumbiaBob]
TiredTrucker Offline
Loc: Central Iowa
Impressive! And I thought my samples with Schaeffer 7000 15w40 in my S60 were pretty good. Well, they are, but yours are darn good also.
Only difference, is mine is getting Silicon levels at 2-3 ppm. Seems like you might not be getting good air filtration on the first sample, but it did drop on the second. Just an observation.
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
Page 1 of 2 1 2 >
