Any machinists?
by NavyVet88
05/26/16 09:28 AM
new XG750R flat-tracker
by Mik
05/26/16 08:55 AM
Walmart Supertech 5w20 full synthetic $8.12
by paulswagelock
05/26/16 08:51 AM
Thoughts on M1 V-Twin 20-50 Oil?
by ZZman
05/26/16 08:07 AM
Real Estate Rates
by AirgunSavant
05/26/16 06:30 AM
15w-40 in my boat, is diesel oil OK?
by chriscpmtmp
05/26/16 05:47 AM
20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
05/26/16 03:48 AM
new castrol edge high mileage synthetic
by hiflo
05/26/16 03:32 AM
Just an interesting question
by southernjeeper
05/26/16 01:52 AM
Value power Walmart battery acid flying out
by bbhero
05/26/16 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
05/25/16 10:35 PM
Steak-House Burgers
by sleddriver
05/25/16 09:53 PM
Rdyno, Darsahn, jerryg, 1971tr350, Mak712
57990 Registered Users
84 registered (2015_PSD, AirgunSavant, Atesz792, 4WD, ARCOgraphite, 8 invisible), 1673 Guests and 339 Spiders online.
57990 Members
66 Forums
249420 Topics
#3290208 - 02/22/14 04:55 AM VW 0w-30 506.01 - high oxidation level HELP
prescient Offline
Loc: Perth, Australia
Just had a sample back from the lab with a reading of 42 abs/cm which has been flagged as high - see sample details below.
Does anyone out there have an opinion on the VW range of oils. I am running a VW Touareg and was recommended (I guess for obvious reasons) to use the VW range. I have done just over 11,000km on this oil and am concerned that I have passed the oils useful limit - am I misunderstanding my report or have I really pushed it too far? Perhaps the lab is being way too conservative in marking 42 as high.
Any ideas much appreciated.
water <.1
calcium 2639
oxidation 42
lead 2
sodium 8
titanium 0
FTIR soot 0.1
cadmium 0
iron 19
fuel dilution
<1
magnesium
255
silver
boron
111
antimony
nitration
9
barium
molybdenum
3
phosphorus
1044
copper
2
tin
TBN
6.07
silicon
9
nickel
aluminium
2
vanadium
potassium
4
chromium
1
zinc
1257
#3290235 - 02/22/14 06:06 AM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: prescient]
fpracha Offline
Loc: MA
Did the lab not report the Viscosity reading?
Oil seems to be OK with plenty TBN reserve (additives) and moderate wear numbers... what's your total mileage on this vehicle ? Do you mostly travel on highway or short-trip this vehicle ?
#3290249 - 02/22/14 06:33 AM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: prescient]
tudorart Offline
Loc: Transylvania, Romania, EU
This lab flagged the ester content, which is common. It is my opinion that all 506.01 are ester/pao or ester/HC.It's a tough spec to meet. Toughest from VW actually : lowest wear with lowest viscosity/fuel economy HTHS.
Anyway viscosity should be higher if it's trully oxidized.
#3290251 - 02/22/14 06:36 AM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: prescient]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
What is the virgin oxidation number? A raw number like that without the virgin oil number is pointless. You are looking for a delta.
#3290448 - 02/22/14 10:40 AM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: prescient]
dparm Offline
Loc: Chicago, IL
What particular oil is this?
2011 BMW M3 sedan ZCP
#3291274 - 02/23/14 02:58 AM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: Pablo]
prescient Offline
So Pablo I guess my question is really "does anyone know what the virgin oxidAtion reading should be for this oil?"
- thanks.
#3292424 - 02/24/14 06:08 AM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: dparm]
prescient Offline
It is VW 0w-30. I am hoping someone can give me an idea of what a likely virgin oxidation reading would be for this oil.
http://www.opieoils.co.uk/c-753-vw-50601-oil.aspx
Any help much appreciated.
#3292635 - 02/24/14 09:59 AM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: prescient]
OVERKILL Offline
Loc: Ontario, Canada
I wouldn't be too worried. My oxidation was at 39 on my last UOA on the M5. That was with M1 0w-40.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3293520 - 02/25/14 06:11 AM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: prescient]
INDYMAC Offline
Loc: Magnolia, TX
Why don't you just test it yourself?
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
#3293915 - 02/25/14 01:16 PM Re: VW 0w-30 506.01 - high oxidation level HELP [Re: prescient]
edhackett Offline
Loc: Sequim, WA
Testing it yourself is the only way to get a correct answer. You need it reported by the same lab that did your analysis, ideally on a virgin sample of the same lot number submitted with your used oil.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
