Gumout Cleaning Deposits from GDI Q&A
Click here to participate in the Gumout Cleaning Deposits From GDI Q&A
12 quarts Redline 5w30 $96.00 York pa area
by spiderbypass
05/24/16 03:00 AM
Trying to prevent high mileage leaks
by twincam00
05/24/16 02:04 AM
food depot
by urrlord
05/24/16 12:13 AM
Re-surfacing original GM wheels
by HM12460
05/23/16 10:28 PM
Valve guide seals? - This much smoke?
by Nick1994
05/23/16 10:12 PM
Opinions on goodyear Viva 3's
by Toaster_Jer
05/23/16 09:37 PM
Suggestions for used suv/cuv
by dohnuts
05/23/16 09:26 PM
60's GM S/W With Speedometer That Changed Color ??
by crazyoildude
05/23/16 08:55 PM
old oil
by OkieHick
05/23/16 08:48 PM
Good lubricant for door hinges that last?
by wolf_06
05/23/16 08:47 PM
Mini Cooper OEM Purflux 5153 miles [cut open]
by nicrfe1370
05/23/16 08:11 PM
Mag 1 and SuperTech knockoffs not looking so good
by AP9
05/23/16 08:02 PM
showstopr30, any_user, NibbanaBanana, h22rider, Troyselby
57963 Registered Users
21 registered (DemoFly, alcyon, Atesz792, earlyre, bobbob, 1 invisible), 528 Guests and 109 Spiders online.
57963 Members
66 Forums
249324 Topics
#3289475 - 02/21/14 11:52 AM Run Away Diesel
GreeCguy Offline
Loc: Elderly County, Florida
Happy Friday afternoon fellow Bitogers - enjoy
http://youtu.be/WrAeUf7v49g
"Dyslexics are teople poo!!."
#3289501 - 02/21/14 12:12 PM Re: Run Away Diesel [Re: GreeCguy]
Miller88 Offline
Loc: Onondaga County
It didn't want to give up!
Held his composure a bit more than the people in this video ...
http://www.youtube.com/watch?v=8M1o2rpO_JY
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#3289542 - 02/21/14 01:01 PM Re: Run Away Diesel [Re: Miller88]
Drew99GT Offline
Loc: Colorado Springs
Originally Posted By: Miller88
It was the MMO!
#3289543 - 02/21/14 01:02 PM Re: Run Away Diesel [Re: Miller88]
BMWTurboDzl Offline
Loc: Atlanta,GA
Love how the older guy just nonchalantly took care of it while the kids scattered like roaches.
'15 435i - BMW branded Shell 5w30.
Prev
'10 335d
'06 330i
'03 330i
#3289656 - 02/21/14 02:58 PM Re: Run Away Diesel [Re: BMWTurboDzl]
440Magnum Offline
Loc: Texas
The power of "been there done that." :-)
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3289688 - 02/21/14 03:22 PM Re: Run Away Diesel [Re: GreeCguy]
Panzerman Offline
Loc: Port Orange, Florida
Ive had that happen before. Only way to shut them down is smother them. The old Detroit two strokes actually had a pull out shut-off cable in the cab, that controlled a butterfly in the air box to block it off. I ve had it happen several times on two stroke gas engines too. If the crank seal is leaking, they will take off full tilt and you cant shut them down either. You have to smother them.
2007 Ford F-150 FX-2 73,000
2007 Ford F-150 FX-4 198,000 (Sold to the Son).
2006 Dodge Ram 2500 Sport 4x4 69,000
2002 Lincoln Continental 153,000
#3290368 - 02/22/14 09:34 AM Re: Run Away Diesel [Re: GreeCguy]
Jarlaxle Offline
Loc: New England
My uncle once stopped a runaway 6-71 by blasting a huge CO2 extinguisher down the intake while another dude stopped the fuel flow. No damage to the engine...but he had to take the tach apart, because the pointed had spun past the end of the scale (4000) and gotten stuck.
1979 Coupe de Ville, 542 stroker, 15W-40 Super Tech, Delco
2011 Crown Vic P71, 5W-20 Valvoline NextGen, Purolator
2012 Suzuki AN400A, 10W-40 ST, Delco
#3290716 - 02/22/14 02:44 PM Re: Run Away Diesel [Re: GreeCguy]
Michael_P Offline
Loc: By the Lake
It had 0W20 oil in it too!
#3291179 - 02/22/14 10:53 PM Re: Run Away Diesel [Re: Panzerman]
artificialist Offline
Loc: Florida
Oil exploration machinery have this as well, however, it activates automatically. This is needed because natural gas might leak out the oil well, and then cause a runaway engine.
2010 Lancer Ralliart Sportback
#3298658 - 03/01/14 08:44 PM Re: Run Away Diesel [Re: GreeCguy]
supton Offline
Loc: NH
I've heard of them running away while drinking their own oil.
Guy I sort know is a long time VW fan. He had at least one of the original Rabbits. Towards the end it started to have a problem with blowby; one time it went into runaway. I forget how he got it to stop, probably parked the car and popped the clutch in 5th. Then cleaned out the diesel version of a PCV valve.
But another time he was running late to the airport when it decided to go into runaway. At first it bothered him--then he realized it was running faster than normal so he simply let it go full out so he could make his plane.
2011 Toyota Camry, base, 6spd manual, 113k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 122k, his
#3299283 - 03/02/14 02:12 PM Re: Run Away Diesel [Re: supton]
rslifkin Offline
Loc: Rochester, NY
In the case of the old detroit 2 strokes, this could definitely happen. If it wasn't shut down before it drank all of its oil and lost oil pressure, it's not unheard of for one to lock up violently enough to shear the flywheel bolts and launch the flywheel.
1998 Jeep Grand Cherokee 5.9 Limited with lots of mods (207k miles, bought with 100k in 1/2010)
Rotella T6 @ 6k OCI
