Trying to figure out what oil to use for my 2006 Cayenne 6 speed manual transmission (uses some obscure Castrol/Porsche Oil called Burhma BOT 338 75W). Looking at ZF's list of approved lubricants (TE-ML11) they cross reference BP Castrol BOT 338 to BMW MTF-LT2, VW Oil No. N 05279800, and Castrol Syntrans B 75w.
I researched the [censored] out of it and there is very little information out there. Castrol's MSDS for the BOT 338 and Syntrans B 75w fluids show they have a thickness of 7.3 cSt @100c. The Fuchs MTF-LT2 apprpved oil is their Titan Sintofluid 75w-80 GL-5 which is thicker 9.4 cSt @ 100c, while Pentosin's MTF-LT2 oil is speced at 7.7 cSt @100c. Finally, Penrite specs their Progear 70w-75 as meeting the ZF TE-ML11 and MTF BOT 338 specs with a thin 6.9 cSt @100c.
I am debating between trying Redline (which I have had great luck with) and Fuchs. Looking at Redline, the D4 ATF has a thickness of 7.5 cSt @ 100c. MTL 75w-80 steps it up to 10.4 cSt @ 100c. For replacing MTF-LT2 oils Redline recommends either D4 ATF or MTL 75w-80. Dave Granquist at Redline has said that the MTL works well except in cold climates where the transmissions can get really stiff and suggests mixing D4 and MTL 50/50.
I am pretty sure the transmission in the Cayenne is an off the shelf ZF 6 speed, but so few have been made it has been impossible to determine what variant it is. I am guessing it is virtually identical to the version used by BMW (it is actually stamped VW on the side).
What do the BITOG members think for the oil choices? Fuchs or Redline? If Redline, which one or mix?
Thanks,
Cary
Thanks,
Cary
