0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
02/05/16 07:20 PM
Anyone else have "See Cashier" issues with Shell?
by SLO_Town
02/05/16 07:16 PM
Shear rates in engine components...
by Shannow
02/05/16 06:32 PM
Windows Live Mail Question
by Wingman
02/05/16 06:21 PM
Royal Enfield Himalayan....Giddy Up!
by BigJohn
02/05/16 06:17 PM
clear no tint 1994 dakota windshield?
by bmwjohn
02/05/16 06:14 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
93 registered (77GrandPrix, aquariuscsm, bandz7, babyivan, 2015_PSD, 17 invisible), 1320 Guests and 124 Spiders online.
56834 Members
66 Forums
244289 Topics
Page 1 of 2 1 2 >
#3287255 - 02/19/14 01:26 PM Random transmission lockup Craftsman 28"
Vikas Offline
Loc: NorthEast
I think this is a Murray/MTD under Craftsman name. For the last couple of storms, the wheels get locked up randomly. I then toggle between R1/F1 etc and eventually it starts working again. Do these have real transmission or just a metal disc and rubber wheel? If so, what would cause the whole thing to lock up? It also has the handle bar levers for quick turning.
#3287384 - 02/19/14 03:47 PM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
tomcat27 Offline
Loc: Midwest
Mine has metal wheel and disc. Not sure of cause
2014 Sentra, 2005 Starcraft Aurora 2410, 2002 Echo
2002 Intrepid, 2002 Liberty, 1998 Dodge B1500
1996 Sebring Jx, 1995 Jeep ZJ, 1970 Cougar, 2001 Camry
#3287507 - 02/19/14 06:04 PM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Dean85 Offline
Loc: MN
There is also a chain as part of the drive system. It is possible the chain is jumping the sprocket causing it to lock up and when you go between f & r the chain jumps back onto the sprocket. When it locks up, tip it up, remove the bottom plate for the drive train and see if the chain has jumped the sprocket. A loose chain will cause this. How old is it?
1985 Camaro
1995 Ford F150 XLT 4x4
1998 Pontiac Transport
1985 Honda Big Red
1983 Honda 200s
#3287738 - 02/19/14 09:27 PM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Vikas Offline
Loc: NorthEast
This is about 5 years old. I am not sure if there is a chain on this unit. Is there an adjustment for the chain if there is one?
#3287908 - 02/20/14 02:53 AM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Dean85 Offline
Loc: MN
Generally these units have an axle with a rubber friction wheel and a sprocket that transfers motion to the wheel axle via a chain. Have never seen an adjustment for this. You can check the side to side movement of the axle. There should be almost no side to side movement. If there is to much movement the chain can get stuck on the sprocket. Usually there is a washer with teeth on it and a flat washer on each side of the axle between the wheel and frame. Next time it locks up, leave it and take the bottom plate off and see what is causing it.
Edited by Dean85 (02/20/14 02:55 AM)
1985 Camaro
1985 Honda Big Red
1983 Honda 200s
#3287965 - 02/20/14 06:10 AM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
lars11 Offline
Loc: Sweden
if snow is blowing in the air, it may very well be that there is water or moisture on the disc and not enough pressure causing the disc to slip. that may cause an intermittent drive/no drive. You may try to adjust the drive wheel pressure a bit and check that the drive disc is i good working condition.
#3288138 - 02/20/14 09:04 AM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Vikas Offline
Loc: NorthEast
I looked at the owner's manual. It has friction disk. I see no chain in the picture. The thing is when the wheels stop spinning, they lock up i.e. I can't manually move the snow thrower either. So it is not slipping at that time. Can something get frozen there?
#3288507 - 02/20/14 02:15 PM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
jeepman3071 Offline
Loc: Storrs, Connecticut
It sounds like something is getting stuck internally. Either the chain is catching on something or a linkage is seizing up. I've never seen drive parts freeze on a snow blower while its operating. I've seen them slip from water getting in, but never just randomly freeze during use.
I'd pop the bottom cover off and have a look. You might see something obviously wrong. I popped the cover off my Toro 826 and found the drive was full of mouse nests. The nest material was bound up so tightly in the gears I'm surprised everything still moved.
If everything looks ok, pop off the drive belt and spin the pulley by hand (with the engine off) with the drive engaged. You will start to feel it bind up and see what is causing it.
2000 Jeep Cherokee Sport 4.0L (161k) - PYB 5w30, Napa Gold 1516, Magnefine trans filter
#3288612 - 02/20/14 03:57 PM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Vikas Offline
Loc: NorthEast
Since this is random, I am somewhat reluctant to open it up while it is working fine. If it has a chain, then that explanation makes the most sense. I will dig deeper in the manual to see if it does have the chain.
#3288790 - 02/20/14 07:01 PM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Dean85 Offline
Loc: MN
What is the model of the blower? If you go to the sears website, access parts direct, you can enter the model # and it will give a complete breakdown of the blower. When it locks up again, leave it and take the bottom plate off to see what the cause is. Sure sounds like the chain to me.
Edited by Dean85 (02/20/14 07:02 PM)
1985 Camaro
1985 Honda Big Red
1983 Honda 200s
#3288921 - 02/20/14 08:52 PM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Vikas Offline
Loc: NorthEast
Model# 247.887900
The friction wheel is part of the drive shaft assembly which has two gears on either side which meshes with the gears on drive wheel axle. I suppose chunk of frozen ice could jam the gears.
#3288997 - 02/20/14 10:06 PM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
enigma-2 Offline
Loc: Northern Indiana
Don't know anything about having a chain in a MTD unit, never used them that I'm aware of, but the lockup is probably caused by the needle bearings on the trasnsfer gear going dry or getting gummed up.
There's a good video on YouTube showing how to repair a stuck snow thrower transmission. How to Repair Stuck MTD snowblower drive system.
#3289083 - 02/21/14 12:47 AM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Dean85 Offline
Loc: MN
Looking up your model # on the sears site, it shows there are two chains. Did you take the cover off and look?
1985 Camaro
1985 Honda Big Red
1983 Honda 200s
#3289178 - 02/21/14 06:44 AM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
Vikas Offline
Loc: NorthEast
interesting! The printed owner's manual does not show it.
#3289279 - 02/21/14 08:42 AM Re: Random transmission lockup Craftsman 28" [Re: Vikas]
jeepman3071 Offline
Popping the cover to have a look won't hurt anything. The cover is usually 4 bolts. You might be able to spot a problem before it gets worse and the machine quits moving altogether.
Page 1 of 2 1 2 >
