Trailer wiring connector.
by wolfehunter
06/29/16 07:10 AM
Oil for High Performance Turbo Application
by T_Bortz
06/29/16 06:52 AM
Walmart.com Valvoline WB 6x1Quart 10W-30 $7.22
by Farmer
06/29/16 06:41 AM
Dyade, Eurol, Ravenol Lubricants
by RaM30
06/29/16 04:46 AM
'88 Caddy Brougham - dark oil + lifters noise
by momo
06/29/16 02:57 AM
Which Oil for Duramax?
by Jamn
06/29/16 02:11 AM
Oil for Binding Foundry Sand
by smw
06/29/16 01:38 AM
Found a good high zinc breakin oil
by 1977c10phxdriver
06/29/16 01:12 AM
What is this radio modulating sound?
by Pontual
06/29/16 01:00 AM
The reason brake fluid can be Dot 3&4 - Viscosity!
by CharlieBauer
06/29/16 12:56 AM
No injector pulse, '92 Prelude, F20B, GSR ECM
by redhat
06/29/16 12:02 AM
Finding #1 Cylinder
by motorguy222
06/28/16 11:31 PM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
72 registered (97K15004WD, Bear, Asterix, barkingspider, AandPDan, 97f150, 5 invisible), 1516 Guests and 9 Spiders online.
58314 Members
66 Forums
250970 Topics
Page 1 of 3 1 2 3 >
#3286561 - 02/18/14 07:04 PM Best oil for new 17.5 HP engine?
Volv04Life Offline
Loc: Virginia
I just got a new lawn tractor at lowes. Can I run 15w-40 in it? I have a huge supply. If not what is the best oil?
05 Nissan Altima 3.5 - Motorcraft/ Fram Filter
#3286565 - 02/18/14 07:07 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
Ramblejam Offline
Loc: Kentucky
Yes.
#3286569 - 02/18/14 07:08 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
kyxtremetuber Offline
Loc: Kentucky
More then likely yes what brand engine
2012 Ford Fusion
2.5L Duratech 40000mi
0-30000 Motorcaft 5w-20 Full Syn 30000- Kendall GT1 FL910s
2000 Ford Excursion 6.8L Triton 150000
#3286571 - 02/18/14 07:09 PM Re: Best oil for new 17.5 HP engine? [Re: kyxtremetuber]
Volv04Life Offline
Loc: Virginia
Briggs
#3286575 - 02/18/14 07:10 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
cknight49090 Offline
Loc: south haven mi
you could probably use it as long as its warmer weather I use 5w30 defy in my Kohler.
#3286576 - 02/18/14 07:11 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
lubedude13 Offline
Loc: North Carolina
I would run 10w30 which is what kohler recommends. Briggs recommends 5w30 synthetic. I have a kohler and ran rotella 10w30 for 20 hours.....came out black and thick.
I now run Amsoil Small Engine Oil which is designed for small engines. Comes out looking a lot better than the rotella I was using.
If I was using rotella again I'd use the 5w40 full synthetic
2010 Toyota Camry:
Amsoil Signature Series 0W20
Amsoil Signature Series Trans Fluid
Amsoil ATF Power Steering Fluid
#3286580 - 02/18/14 07:13 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
Loc: Kentucky
15-40 will work on a mower that won't see true cold starts I've been running 5w-40 in all my ope with great results
2012 Ford Fusion
#3286581 - 02/18/14 07:13 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
simple_gifts Offline
Loc: Middlesex County CT
What does the OM indicate?
2003 Echo >392K miles; Castrol 5W-50
2006 B2300;108K;ALM
Please conserve paper; it is not like it grows on trees.
#3286582 - 02/18/14 07:13 PM Re: Best oil for new 17.5 HP engine? [Re: lubedude13]
Volv04Life Offline
Loc: Virginia
Thanks guys. Ill probly run T5
#3286587 - 02/18/14 07:14 PM Re: Best oil for new 17.5 HP engine? [Re: simple_gifts]
Volv04Life Offline
Loc: Virginia
OM doesnt say
#3286590 - 02/18/14 07:16 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
JHZR2 Offline
Loc: New Jersey
Amsoil ACD
#3286591 - 02/18/14 07:16 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
lubedude13 Offline
Loc: North Carolina
Briggs recommends 5w30 full synthetic which is available at tractor supply or lowes
2010 Toyota Camry:
#3286593 - 02/18/14 07:18 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
Oil Changer Offline
Loc: Michigan
You have to know what the proper viscosity is if you want to care for the engine correctly. Somewhere in the OM it says what the proper viscosity is. Did it come with a separate engine manual? Call the place you bought it from and ask them. Then talk what brand.
#3286596 - 02/18/14 07:19 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
95busa Offline
Loc: Tennessee
Doesn't matter
2005 Ford F250 Super Duty 4x4
2009 Dodge Grand Caravan
2014 Kia Forte KOUP- totaled by a drunk driver
#3286602 - 02/18/14 07:20 PM Re: Best oil for new 17.5 HP engine? [Re: Volv04Life]
JR Offline
Loc: Michigan born but my heart bel...
Yes. 15w-40 will work great for summer use. i have used it many times. i prefer 5/10w-xx oil for cold weather starts.
Ken
Page 1 of 3 1 2 3 >
