Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
06/30/16 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
06/30/16 08:39 PM
Firestone TF2876 C&P
by holdorf333
06/30/16 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
06/30/16 08:30 PM
Got to experience cornering ABS today
by LoneRanger
06/30/16 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
06/30/16 08:03 PM
What product was that?
by another Todd
06/30/16 07:19 PM
choice between reciprocating corded saws
by edwardh1
06/30/16 07:04 PM
Is the driving experience getting worse?
by fdcg27
06/30/16 06:24 PM
Scratched wheel
by gabriel9766
06/30/16 05:52 PM
Gear oil added to motor oil in engine
by TiredTrucker
06/30/16 05:52 PM
Purolator 10111 Cut Open- Red Can- NEW
by FordBroncoVWJeta
06/30/16 05:51 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
109 registered (alanwayne1908, AMC, 69GTX, andyd, 2002 Maxima SE, 901Memphis, 8 invisible), 1701 Guests and 6 Spiders online.
58322 Members
66 Forums
251062 Topics
#3286355 - 02/18/14 03:55 PM tire maintainance confusion
jrtribology Offline
Loc: New Jersey, USA
What is the difference between open and closed dual head "air chucks" (the tools you plug into air compressor hoses to inflate truck tires)? I insist I want to get one from one of the big name tool companies like Snap-On, Mac, Matco, SK, ect. Because the ones in the autopart stores really are bad. It's confusing because the different "air chucks" designated as open and closed look the same???
#3286364 - 02/18/14 04:03 PM Re: tire maintainance confusion [Re: jrtribology]
Ramblejam Offline
Loc: Kentucky
Closed chucks have built-in shut off valve, and are intended for live air lines.
Open chucks are for valved air lines (tire installation machines/inflation gauges, etc).
#3286376 - 02/18/14 04:12 PM Re: tire maintainance confusion [Re: jrtribology]
Miller88 Offline
Loc: Onondaga County
I need to find a reasonable priced open chuck for my HF compressor.
It is a piston style compressor with no tank. So I have to screw this thing onto the tire, then turn the compressor on, then connect it to the compressor.
Would work much better (easier) if I had an open chuck that I could just connect to the valve after turning on the compressor.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3286377 - 02/18/14 04:13 PM Re: tire maintainance confusion [Re: Ramblejam]
jrtribology Offline
So I would want an open one if I had a separate hand held gauge and kept alternating between the two until I knew I had the right pressure?
#3286431 - 02/18/14 04:56 PM Re: tire maintainance confusion [Re: jrtribology]
Traction Offline
Loc: iowa
You only need a open chuck when inflating a tire without a valve core. For just airing up tires you need a clip-on chuck, But I would for sure use a pressure regulator. It would be all to easy to get distracted, blow up a tire to 100 psi. That is why I think clip on chucks should never be used with a air tank either. To the OP, I am not for sure what you are trying to do?
Edited by Traction (02/18/14 05:01 PM)
#3286462 - 02/18/14 05:25 PM Re: tire maintainance confusion [Re: Traction]
jrtribology Offline
Basically I'm a CDL driver\sanitation worker that carries a bag with a dual end tire gauge (among other things) and routinely stops in a garage where there's an air compressor to fill tires that are not up to pressure. Unfortunately I don't have the experience of a mechanic or a tire maintainance specialist.
#3286514 - 02/18/14 06:04 PM Re: tire maintainance confusion [Re: Ramblejam]
Cardenio327 Offline
Loc: Oaxaca, Mexico
^^This^^
To clarify:
A closed chuck dispenses air at the moment it is pushed onto the valve stem, automatic operation if you will.
An open chuck is connected to a device which has a valve actuated by a button, trigger or pedal. You would push the chuck onto the valve stem then momentarily turn on the air with one of the above mentioned valves.
'08 Honda C90ST Super Cub 15w-40 Delvac 1300
'08 Honda NX4 Falcon 5w-40 Delo 400LE
'09 Honda Fit LX 5w-20 PP
'99 F-150 W/T 4.2L 10w-30 QSUD
#3286527 - 02/18/14 06:21 PM Re: tire maintainance confusion [Re: Cardenio327]
jrtribology Offline
Then I'm wrong, I would need the closed chuck which would start inflating into the stem as soon as it's pushed in the stem and then stop when it's pulled off. And the open chucks are like the coin operated machines you see at gas station that have those levers on them and only dispense the air when you squeeze the lever?
#3286718 - 02/18/14 08:58 PM Re: tire maintainance confusion [Re: jrtribology]
Rand Offline
Loc: NE,Ohio
no. thats still closed. because nothing comes out if you squeeze the lever unless its on the tire valve.
pretty much all normal ones are closed except special service ones.
Edited by Rand (02/18/14 08:58 PM)
2015 Forester I-Premium 6MT
#3287097 - 02/19/14 10:55 AM Re: tire maintainance confusion [Re: jrtribology]
Ken2 Offline
Loc: Washington St.
Is there anything wrong with a Milton brand air chuck? The Miltons I've bought have worked well. They're widely available and better priced than the ones sold from the tool trucks.
The dual-head air chuck is for reaching in to the inner rear valve stem on dual rear wheels. Is there such a thing as an open dual-head? (I don't think so--the other half of the head would blow air.)
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
