Does this tail pipe pic tell you anything?
by LeakySeals
05/31/16 04:38 PM
Security Camera system
by Alfred_B
05/31/16 04:10 PM
Valvoline is going to be listed on the NYSE
by demarpaint
05/31/16 03:46 PM
Rislone or stp ethanol fuel treatment
by Indiana79
05/31/16 03:17 PM
Super Tech #3614 CUT OPEN
by car51
05/31/16 03:03 PM
Flight Tracker
by Eddie
05/31/16 02:33 PM
Art and ugly are separated by a fine line
by HTSS_TR
05/31/16 02:27 PM
2013 Ram 1500 Vibration Issue
by 757guy
05/31/16 11:21 AM
Speed & Temperature ratings vs cold PSI
by badtlc
05/31/16 10:52 AM
Worthy of a news story??
by andrewg
05/31/16 10:13 AM
Gorilla Shooting...decaying moral values?
by Smokescreen
05/31/16 09:53 AM
Oil Change Frequency - 04 Neon
by racer12306
05/31/16 09:15 AM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
80 registered (Branson304, bbhero, Atesz792, bdcardinal, Alfred_B, BeerCan, 10 invisible), 1981 Guests and 326 Spiders online.
58031 Members
66 Forums
249634 Topics
#3286359 - 02/18/14 03:59 PM replaced raidiator...still smell coolant..no leaks
Mark72 Offline
Loc: Illinois
I guess the subject speaks for itself. I own a 2001 Nissan Sentra 2.0. Had a new radiator put in it 3 weeks ago. No leaks, all clamps are working and no moisture around any of the hoses but when I shut the car off after a drive I still smell coolant on the outside of the car. When I open the hood, it confirms it because that is definitely what Iím smelling but nothings leaking and I donít know what to do. Any ideas? Would it take 3 weeks for residual to burn off?
#3286369 - 02/18/14 04:07 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Drew99GT Offline
Loc: Colorado Springs
Coolant can stick around and stink for a while. If your Sentra has splash shields underneath, it can puddle up and take a while for the water component to evaporate and /or for the coolant to get splashed out of any crevices/nooks/crannies from driving. As long as the level stays normal and no visible coolant is leaking, you should be good to go.
Edited by Drew99GT (02/18/14 04:07 PM)
#3286373 - 02/18/14 04:10 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Mark72 Offline
Loc: Illinois
Well that was my thought to..but Iíve had the car on several highway trips since the radiator was replaced 3 weeks ago. Would that not have burn it off by now?
#3286374 - 02/18/14 04:12 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Have you checked the coolant level? If it's low it may be a bad Intake Manifold Gasket.
#3286381 - 02/18/14 04:17 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Warstud]
Mark72 Offline
Loc: Illinois
Thought of that too...so I been checking the oil and it looks fine...no discoloration at all.
#3286467 - 02/18/14 05:27 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Did you smell coolant prior to replacing the rad? And why did you replace the rad?
#3286505 - 02/18/14 06:01 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
MolaKule Offline
Loc: Iowegia - USA
Take off the shields and go to a manual car wash and spray the engine compartment with soap and rinse thoroughly.
Let it dry and check for any new coolant leaks.
Sometimes the hose clamps need re-tightening or replacement.
When you choose the Behavior, you choose the Consequences. smile
