Saved a puppy
by barkingspider
08/24/16 10:39 PM
Slick 50
by CrackyWainwright
08/24/16 09:28 PM
Bmw twin power 5w30
by BTLew81
08/24/16 09:08 PM
Older car but low mileage. Change or not?
by Martin10
08/24/16 08:07 PM
F1 - 2016 Belgian Grand Prix
by gofast182
08/24/16 07:55 PM
Ethernet card uograde needed?
by NHHEMI
08/24/16 07:27 PM
2012 Suzuki DL1000 VStrom Oil Recommendations
by RHALL
08/24/16 07:24 PM
Audio/Micro Adapter Help
by coopns
08/24/16 07:18 PM
Purolator boss 2222 6,200 miles
by gabriel9766
08/24/16 06:49 PM
Fram Ultra paint peeling
by Run
08/24/16 06:26 PM
Cell phone mount suction cup doesn't stick
by mclasser
08/24/16 06:02 PM
2008 Nissa Versa 110,000 miles second report.
by Datarock
08/24/16 05:07 PM
ShadowSix, warfire, Brutus232, gojoneeded, jimmyangst
58911 Registered Users
56 registered (Americana, 79sunrunner, AZjeff, AntsinmyEyes, 29662, 5 invisible), 1242 Guests and 7 Spiders online.
58911 Members
66 Forums
253515 Topics
#3286359 - 02/18/14 03:59 PM replaced raidiator...still smell coolant..no leaks
Mark72 Offline
Loc: Illinois
I guess the subject speaks for itself. I own a 2001 Nissan Sentra 2.0. Had a new radiator put in it 3 weeks ago. No leaks, all clamps are working and no moisture around any of the hoses but when I shut the car off after a drive I still smell coolant on the outside of the car. When I open the hood, it confirms it because that is definitely what Iím smelling but nothings leaking and I donít know what to do. Any ideas? Would it take 3 weeks for residual to burn off?
#3286369 - 02/18/14 04:07 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Drew99GT Offline
Loc: Colorado Springs
Coolant can stick around and stink for a while. If your Sentra has splash shields underneath, it can puddle up and take a while for the water component to evaporate and /or for the coolant to get splashed out of any crevices/nooks/crannies from driving. As long as the level stays normal and no visible coolant is leaking, you should be good to go.
Edited by Drew99GT (02/18/14 04:07 PM)
#3286373 - 02/18/14 04:10 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Mark72 Offline
Loc: Illinois
Well that was my thought to..but Iíve had the car on several highway trips since the radiator was replaced 3 weeks ago. Would that not have burn it off by now?
#3286374 - 02/18/14 04:12 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Have you checked the coolant level? If it's low it may be a bad Intake Manifold Gasket.
#3286381 - 02/18/14 04:17 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Warstud]
Mark72 Offline
Loc: Illinois
Thought of that too...so I been checking the oil and it looks fine...no discoloration at all.
#3286467 - 02/18/14 05:27 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Did you smell coolant prior to replacing the rad? And why did you replace the rad?
#3286505 - 02/18/14 06:01 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
MolaKule Offline
Loc: Iowegia - USA
Take off the shields and go to a manual car wash and spray the engine compartment with soap and rinse thoroughly.
Let it dry and check for any new coolant leaks.
Sometimes the hose clamps need re-tightening or replacement.
"Never buy flowers from a monk; only YOU can prevent florist friars." Smokey smile
