Pirelli
by borgward
05/29/16 02:10 PM
'88 Cadillac smog (Emission test) fails
by momo
05/29/16 01:59 PM
Towing what to look for?
by Camprunner
05/29/16 01:48 PM
The Critic's Choice 2014 Yaris vs 2015 Accent
by Gasbuggy
05/29/16 12:52 PM
What Fram Ultra For 95 Cadillac Seville?
by crazyoildude
05/29/16 12:46 PM
Import Multi-Vehicle, Valvoline vs. Castrol, VI?
by Samzone
05/29/16 12:36 PM
Fram Ultra Bypass Valve Spring Life
by Digital2k2
05/29/16 11:32 AM
CARQUEST Filters are now made by Purolator (pics)
by sir1900
05/29/16 11:03 AM
Small 4 Cycle Engines, longevity tips
by henni
05/29/16 10:05 AM
Car won't star after new serpentine belt
by AlaninPA
05/29/16 09:06 AM
Was this sold by Costco?
by Vikas
05/29/16 09:03 AM
Gas or lithium-ion powered string trimmer?
by skyactiv
05/29/16 08:41 AM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
67 registered (Astro_Guy, 4wheeldog, 123Saab, Bandito440, 69GTX, AZjeff, 7 invisible), 1669 Guests and 320 Spiders online.
58013 Members
66 Forums
249560 Topics
#3286359 - 02/18/14 03:59 PM replaced raidiator...still smell coolant..no leaks
Mark72 Offline
Loc: Illinois
I guess the subject speaks for itself. I own a 2001 Nissan Sentra 2.0. Had a new radiator put in it 3 weeks ago. No leaks, all clamps are working and no moisture around any of the hoses but when I shut the car off after a drive I still smell coolant on the outside of the car. When I open the hood, it confirms it because that is definitely what Iím smelling but nothings leaking and I donít know what to do. Any ideas? Would it take 3 weeks for residual to burn off?
#3286369 - 02/18/14 04:07 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Drew99GT Offline
Loc: Colorado Springs
Coolant can stick around and stink for a while. If your Sentra has splash shields underneath, it can puddle up and take a while for the water component to evaporate and /or for the coolant to get splashed out of any crevices/nooks/crannies from driving. As long as the level stays normal and no visible coolant is leaking, you should be good to go.
Edited by Drew99GT (02/18/14 04:07 PM)
#3286373 - 02/18/14 04:10 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Mark72 Offline
Loc: Illinois
Well that was my thought to..but Iíve had the car on several highway trips since the radiator was replaced 3 weeks ago. Would that not have burn it off by now?
#3286374 - 02/18/14 04:12 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Have you checked the coolant level? If it's low it may be a bad Intake Manifold Gasket.
#3286381 - 02/18/14 04:17 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Warstud]
Mark72 Offline
Loc: Illinois
Thought of that too...so I been checking the oil and it looks fine...no discoloration at all.
#3286467 - 02/18/14 05:27 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Did you smell coolant prior to replacing the rad? And why did you replace the rad?
#3286505 - 02/18/14 06:01 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
MolaKule Offline
Loc: Iowegia - USA
Take off the shields and go to a manual car wash and spray the engine compartment with soap and rinse thoroughly.
Let it dry and check for any new coolant leaks.
Sometimes the hose clamps need re-tightening or replacement.
"You are free to choose, but you are not free from the Consequences of your choice." Dr. Laura. smile
