ACDelco X66P
by OldEuroCarLover
Today at 12:07 AM
FL910S C&P, 4,000 miles
by cb4017
Today at 12:02 AM
Mobil 1ô Full Synthetic $3.99 AR Menards
by John_K
Yesterday at 10:32 PM
Causes of steering wheel shudder
by buck91
Yesterday at 10:14 PM
Brand new Focus ST...
by Striker
Yesterday at 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
Yesterday at 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
Yesterday at 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
Yesterday at 08:35 PM
Tundra steering wheel
by RN89
Yesterday at 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
Yesterday at 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
Yesterday at 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
Yesterday at 07:50 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
52 registered (Astro_Guy, Bighorn2500, Bear, Alex_V, 2015_PSD, beanoil, 5 invisible), 915 Guests and 38 Spiders online.
58926 Members
66 Forums
253568 Topics
#3286359 - 02/18/14 03:59 PM replaced raidiator...still smell coolant..no leaks
Mark72 Offline
Loc: Illinois
I guess the subject speaks for itself. I own a 2001 Nissan Sentra 2.0. Had a new radiator put in it 3 weeks ago. No leaks, all clamps are working and no moisture around any of the hoses but when I shut the car off after a drive I still smell coolant on the outside of the car. When I open the hood, it confirms it because that is definitely what Iím smelling but nothings leaking and I donít know what to do. Any ideas? Would it take 3 weeks for residual to burn off?
#3286369 - 02/18/14 04:07 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Drew99GT Offline
Loc: Colorado Springs
Coolant can stick around and stink for a while. If your Sentra has splash shields underneath, it can puddle up and take a while for the water component to evaporate and /or for the coolant to get splashed out of any crevices/nooks/crannies from driving. As long as the level stays normal and no visible coolant is leaking, you should be good to go.
Edited by Drew99GT (02/18/14 04:07 PM)
#3286373 - 02/18/14 04:10 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Mark72 Offline
Loc: Illinois
Well that was my thought to..but Iíve had the car on several highway trips since the radiator was replaced 3 weeks ago. Would that not have burn it off by now?
#3286374 - 02/18/14 04:12 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Have you checked the coolant level? If it's low it may be a bad Intake Manifold Gasket.
#3286381 - 02/18/14 04:17 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Warstud]
Mark72 Offline
Loc: Illinois
Thought of that too...so I been checking the oil and it looks fine...no discoloration at all.
#3286467 - 02/18/14 05:27 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Did you smell coolant prior to replacing the rad? And why did you replace the rad?
#3286505 - 02/18/14 06:01 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
MolaKule Offline
Loc: Iowegia - USA
Take off the shields and go to a manual car wash and spray the engine compartment with soap and rinse thoroughly.
Let it dry and check for any new coolant leaks.
Sometimes the hose clamps need re-tightening or replacement.
"Never buy flowers from a monk; only YOU can prevent florist friars." Smokey smile
