Differences between TCW-3 and regular 2-stroke?
Canada
Just wondering 2 things:
What is the difference between TCW-3 2-stroke oil, and 'regular' 2-stroke oil; and
Would there be any long-term harm in running 'regular' 2-stroke oil as a UCL, instead of TCW-3? Those who use 2-stroke as a UCL seem to push using a TCW-3 product, not 'regular' stuff.
Just curious....
tc-w3 is for watercooled application
tc is for air cooled, also has more ash
then you can get into jaso FD etc.
Briefly --
TC-W3: Marine (water-cooled), ashless detergents.
JASO/ISO: Land (air-cooled), ash-type detergents.
As for automotive UCL usage, TC-W3 is appropriate as the ashless formulation will curb deposit formation. Using a "regular" oil would be inappropriate, as the low temperatures would lead to nasty desposit accumulation.
There are of course exceptions, but that's the basics.
Originally Posted By: 901Memphis
Are you guys using the TC-W3 mineral or synthetic formula?
For this particular purpose, it doesn't matter. Just use the cheapest 2-cycle oil that meets the TCW3 standard. For our intended use, it is the additive package that is the most important factor. I have had excellent results using the cheap WalMart oil that you can buy by the gallon.
Here's the product I've been using:
Reading the label, it appears very similar to Evinrude XD50: http://shop.evinrude.com/product/343544/764354/_/XD_50_2-Cycle_Oil
Superior lubricity and combustion cleaner makes for a nice UCL...
Originally Posted By: dailydriver
^^^ I wonder if that is the Pennzoil stuff in an Evinrude bottle?
How do you figure that?
Just that there are not too many manufacturing a semi-synthetic TCW-3 oil, and I highly doubt that Evinrude-Johnson has an oil cracking plant anywhere.
But yes, it could be made by Conoco Phillips, or others.
I agree.
Tc-w3 is a spec. If the 2 stroke oil used meets this spec then its equal in performance to all others that meet the tc-w3 spec.
As an ucl using an expensive synthetic is absurd. Buy the cheapest available. It'll perform identically to any other tc-w3.
I hope you're just talking about TC-W3 within the confines of UCL usage.
i bought a gallon of ST TCW3 after reading Sarge's most excellent "been testing" thread. What a great maintenance procedure. I had the best DEQ results I have ever seen because of it. I just ran out of the Super Tech and just started using the Pennzoil TCW3 that I got for 49 cents a quart thanks to the 5 off 5 thing O'Reilly did last spring.
Yes. Only as it pertains to using it as an upper cylinder lube.
I agree.
So do you think that even the Pennzoil semi-synth stuff is "too good", and a waste of money?? (SERIOUS question, NO sarcasm/animosity inferred or implied.
I agree.
It isn't "too good", just a waste of money
