I guys,
/Just changed the air filter in my accord, and noticed that the last time it was changed, someone took a chunk out of the outward facing lip that hangs over the lower portion of the air box.
You can see the side (seal) of the filter, but the two faces where the filter sits flush against to form the seal are intact. Just for mind I put a dab of gasket maker on the face of the seal above where the crack would be.
I actually took the whole box out, and it looks like it seals well top and bottom when its closed. the crack doesn't go above the mating surface, if that makes sense.
Its a tight fit, and looks like it got caught on the fender at some point.
any cause for concern? I guess this is common. See drawing....I was a bit bored.
[img=http://s3.postimg.org/lvu3n4n7j/Filter.jpg]
