Hey guys.
My question is, what is the risk of double dosing Liqui Moly Ceratec. This is, adding two bottles instead of one to the engine in a sump that contains 4.5L of oil.
I know the bottle says that optimum dosage is at 6%, but I have a little track day car that has seen many days of abuse on the circuit. The last one most recently in 36C heat.
Would a double dose prevent bearing wear under severe loads a bit better ? Can it help with the oil thinning when running hard and hot to protect the engine ?
Also, would the double dose increase solids to much and hamper oil flow, seeing Ceratec contains not only Boron Nitride as well as ZDDP and Moly ?
Or would it simply be a case of wasting money and receiving marginal returns / improvement over one bottle.
Your comments and insights would be appreciated.
Thanks.
Thanks.
