Brother passed away this morning
by oilboy123
2 minutes 14 seconds ago
Changed oil tonight - what a fine evening
by pacem
12 minutes 52 seconds ago
Interesting observation on Ultra
by RusskiBoSS
Today at 08:48 PM
2009 Honda Civic Cooling fan running continuously
by Doog
Today at 08:31 PM
adhesive for pea gravel?
by xfactor9
Today at 08:19 PM
Micro guard Gl14609 150 hours
by robo339
Today at 08:02 PM
walking thru a Harbor Freight is better than sex
by turtlevette
Today at 07:58 PM
'14 Durango 3.6L, PUP 5w20, 7.5k, TBN/TAN
by Mantooth
Today at 06:59 PM
Advice: Odyssey or Sienna?
by Barwich
Today at 06:43 PM
Any HR specialists out there?
by bustednutz
Today at 06:23 PM
Jawa 350/360 (two-stroke) motor oil
by volodymyr
Today at 05:52 PM
Red Line 20W60 Synth. 1k Miles '13 KTM DUKE 690
by albertdi
Today at 05:49 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
95 registered (66chevelle, 2015_PSD, 1977c10phxdriver, 2010Civic, 4WD, 2009Edge, 7 invisible), 1478 Guests and 102 Spiders online.
57973 Members
66 Forums
249368 Topics
#3235091 - 01/02/14 07:30 PM Detroit Series 60 and Schaeffer 700 15w40 blend
TiredTrucker Offline
Loc: Central Iowa
Well, here is my first UOA on Schaeffer 700 15w40 syn blend I just started using in my Detroit Series 60. 200008 miles on the engine, 13733 miles on the oil. Was previously using a Delo 5w40.
Iron 13
Chromium 1
Lead 2
Copper 1
Tin 1
Aluminum 1
Silicon 2
Boron 17
Sodium 15
Potassium 2
Magnesium 885
Calcium 1161
Phosphorus 1104
Zinc 1429
Molybdenum 46
Vis 100c cSt 13.34
TBN 6.12
Water 0
glycol N
Soot .46
Oxidation 13
Nitration 6
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
#3235171 - 01/02/14 08:43 PM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
Rob_Roy Offline
Loc: Northern, NY
I hope you are still running that oil?
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
#3235186 - 01/02/14 08:56 PM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
Loc: Central Iowa
Well, I bought a 30 gallon drum the first go around to see how it would work out. I am on the second fill of it now and just got the report from the first fill. I just put in another order for another drum. The Delo was breaking down bad. In the same time frame on oil, the viscosity on the Delo was tanking pretty bad. I was getting a lot of things going on we couldn't trace as the problem. So, decided to make a switch. This came out pretty good for the first go around. Now, will have to see how it trends.
#3236090 - 01/03/14 02:28 PM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
TiredTrucker - this seems to be a reasonable report for the mileage. For comparison please find the averages (over some millions of kms) for my vehicles all with the same engine family:
AVERAGES (all engines) at Avge OC point of 90051 kms (55955 miles)
Soot = 3.23%
Iron = 130 ppm
Alum = 3 ppm
Chro = 12 ppm
Cop = 7 ppm
Lead = 36 ppm
Sil = 33 ppm
Sod = 14 ppm
Vis @40C = 86
TBN = 2.64 (D4739)
TAN = 6.67
The lubricant was Delvac 1 5W-40 and a Mann-Hummel (Spinner) centrifuge and SS FF filter inserts were used
This may give you a chance to compare uptake rates in your case
My OCI limits were based on:
Iron @ 150 ppm
Soot @ 3.50%
TBN @ 1
TAN @ 8
or any other out of balance situation (which never occurred)
I hope this is of interest
Regards
Doug
#3237031 - 01/04/14 11:09 AM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
Loc: Central Iowa
Thanks Doug. Will be interesting to see how mine compares over time.
#3279031 - 02/12/14 08:02 AM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
Loc: Central Iowa
Well, next UOA on the Schaeffer and the Detroit 60. 15040 miles on the oil, with 215048 miles on the engine.
Iron 17
Chrome 1
Lead 2
Copper 1
Tin 1
Aluminum 1
Nickel 0
Silicon 2
Calcium 1194
Phosph 1216
Zinc 1437
Moly 51
Visc 13.65
TBN 7.31
Soot 0
No fuel, water, glycol detected.
Not bad. Will start extending drains a little at a time now that I have a couple of samples to see results.
#3284684 - 02/16/14 10:08 PM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
panthermike Offline
Loc: Phoenix, AZ
Has Schaeffer scaled back the Moly on the current 15w40 formulation. I thought it had 200+ppm?
'16 Ram Sport 1500;FF 1K
'15 Lincoln MKC; PP 5w30 21K
'77 F250 "Ol Yeller"; Kendall/Mos2
'98 ES300; ML/Biotech 201K
#3284913 - 02/17/14 08:38 AM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
salesrep Offline
Loc: lllinois
Schaeffer's current formula uses "Next Generation" Moly which will stay plated longer than the previous version. Bottom line is that it is better.Gauging on a ppm bases is not comparing apples to apples.
"A patriot must always be ready to defend his country against his government."
Edward Abbey
#3284991 - 02/17/14 09:57 AM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: salesrep]
OVERKILL Offline
Loc: Ontario, Canada
Is this the much lauded "tri-nuclear" moly that Mobil has been using?
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3285338 - 02/17/14 03:39 PM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: OVERKILL]
salesrep Offline
Loc: lllinois
I am not sure what Mobil uses, though I highly doubt that they are using the same layered structure chemistry that creates a lower coefficient of friction that Schaeffers uses.
Edward Abbey
#3285775 - 02/17/14 11:01 PM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: salesrep]
OVERKILL Offline
IIRC Molakule spoke about it a while back, I believe it was an Infineum product (so XOM/SOPUS) that is essentially a far more effective form of Moly, so less of it is required to achieve the same benefit.
Just curious if it was the same stuff, not delving into other aspects of the formulation smile
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3285863 - 02/18/14 04:59 AM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
dnewton3 Offline
Loc: Indianapolis, IN
Check out the normalcy article for macro data on the D60 ...
Looks like your sample is below averages; very good performance! Easy to extend those OCIs if that's indicative of the lube abilities.
Edited by dnewton3 (02/18/14 05:01 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3288502 - 02/20/14 02:09 PM Re: Detroit Series 60 and Schaeffer 700 15w40 blend [Re: TiredTrucker]
Loc: Central Iowa
I am going to take the next change to 20,000 miles from my normal 15,000 now that I have two oil changes on the Schaeffer and have a nice base line. Will be chomping at the bit to see what that sample shows. Got a bypass unit on the engine and running dual Donaldson ELF 3998 full flow filters. Should be a good combination to get more time between changes.
All in all, I am very pleased how this factory rebuilt Series 60 is performing. Detroit did a great job remanning the engine.
