Costco Canada Michelin wiper blades $9.99
by JC1
08/26/16 06:47 PM
Havoline Car Giveaway
by SatinSilver
08/26/16 06:47 PM
Opinions please
by ceast
08/26/16 06:41 PM
UOA, Pennzoil Platinum 5W30, 15K KM, 10 months
by ST2008
08/26/16 06:19 PM
Cruise control going downhill
by Donald
08/26/16 05:58 PM
O'REILLY SYNTHETIC OIL
by dooscoop32
08/26/16 05:10 PM
Anyone here a ice road truckee?
by car51
08/26/16 04:42 PM
What is business model of UBER ride-hailing co. ?
by HTSS_TR
08/26/16 04:12 PM
Old wall furnace
by Jarlaxle
08/26/16 02:55 PM
automatic side folding mirror squeak
by Grambo
08/26/16 02:11 PM
Anybody own a new Mazda 6?
by AirgunSavant
08/26/16 01:58 PM
Do Employees Of Car Companies Get New Cars Cheap ?
by crazyoildude
08/26/16 01:54 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
85 registered (4WD, 01rangerxl, 09_GXP, 2015_PSD, 1JZ_E46, abycat, 9 invisible), 1382 Guests and 36 Spiders online.
58935 Members
66 Forums
253596 Topics
#3284541 - 02/16/14 08:08 PM stainless frame in berrymans dip tank?
1 FMF Offline
Loc: CT
I have my Kimber Pro carry stainless frame completely stripped. looking for a gGood way to completely clean it, has some decent powder residue and grime inside the Mag well and trigger Area. I might buy an ultrasonic cleaning thing from Harbor Freight for 40 bucks but if I can do the same job in either the dishwasher or dumping it in a gallon of berrymans I'd rather do that. the only thing I'm not sure is if there's a coating on the stainless frame if its anodized or something.
#3284622 - 02/16/14 09:12 PM Re: stainless frame in berrymans dip tank? [Re: 1 FMF]
Slick17601 Offline
Loc: Pennsylvania
Don't do it. You have a nice piece there so don't ruin it. Odorless mineral spirits would be a better choice.
#3284764 - 02/17/14 01:03 AM Re: stainless frame in berrymans dip tank? [Re: 1 FMF]
BlownF150 Offline
Loc: Louisiana
Berrymans won't hurt it but you are just as well served by hosing it down with CLP or bore solvent and letting it soak for a few hours. Scrub it out then use some compressed air to blow it out.
Toy: 2000 F-150, ECRB, 5.4L, ProCharger
#3284969 - 02/17/14 09:34 AM Re: stainless frame in berrymans dip tank? [Re: 1 FMF]
strat81 Offline
Loc: Nebraska
I don't think B12 Chemtool would hurt it as those are mostly organic solvents. Stainless steel is not anodized - that's a finish for aluminum. I don't believe Kimber coats their stainless frames - a phone call would confirm that, or even just looking at high-wear areas such as the frame rails, or the spots where your holster contacts the frame and slide. Peeling/flaking should be evident.
But why? Soak it in mineral spirits or kerosene, then give it a quick scrub with a GI toothbrush.
If you want to get creative, mix up some Ed's Red and soak it in there for a few hours: equal parts odorless mineral spirits, K1 kerosene, acetone, and ATF. It's an excellent bore cleaner.
Molon Labe
#3291109 - 02/22/14 09:36 PM Re: stainless frame in berrymans dip tank? [Re: 1 FMF]
1 FMF Offline
Loc: CT
the thought was to clean it with using the least amount of manual labor. i ended up dipping most of the stainless parts in the berrymans after testing one piece first. worked fine, then rinsed off in the sink and scrubbed down with a bristle brush and dish soap. i had a lot of that red dye gunk from wolf ammo inside the frame that i couldn't easily reach and what i could didn't come off easily with gun cleaner spray.
#3292275 - 02/23/14 10:08 PM Re: stainless frame in berrymans dip tank? [Re: 1 FMF]
AVB Offline
Loc: Georgia
You won't hurt it as you found, but I just wanted to add that a dish washer works well too. Especially after a soak like you did.
#3293469 - 02/25/14 02:39 AM Re: stainless frame in berrymans dip tank? [Re: 1 FMF]
AMC Offline
Loc: South Eastern, CT
Don't do it! It is totally not necessary and won't even work that well. Just wet a stiff bristled nylon brush with your favorite gun cleaner and scrub it away.
If you really want to try an unconventional method, hose the entire gun down with simple green, scrub with a toothbrush and then thoroughly rinse with fresh water. Dry the parts the best you can manually and then finish drying with a hair drier. Thoroughly re-oil when you are done of course.
11 Chevy Silverado - PP 5w-30
10 Ford Focus - WH 5w-20
14 Yamaha Super Tenere - Delo 15w-40
1oz TCW-3 Per 5 Gallons of Fuel.
