Originally Posted By: martinq
Originally Posted By: JHZR2
You're running the battery closer to its max, so it will create issues with the chemistry, higher internal heating, etc. You can expect poorer life because of the size/rating you selected, unfortunately.
I'm hoping for 8-10 years out of this one. Time will tell.
Indeed it will. Doesn't change the physics of the situation which will occur exactly as I define. Lead acid is lead acid, regardless of if it is valve regulated with AGM, or anything else. There is very little difference besides some plate alloying. Your comment before worries me..
Originally Posted By: GaleHawkins
If one is buying a car AGM battery that needs the car's OEM charging system altered/tweaked it seems to me one is buying the wrong brand of AGM battery.
It's not the brand that's the issue it's the chemistry. AGM is not the same as FLA or SLA.
There is no magic to these things, and they will encounter the same thermally-induced calendar life issues/ageing that any flooded battery does,,they just can't have their electrolyte recovered. They will still offgas at above a 3C rate roughly, they will also be damaged just as easily by being undercharged. Running higher loads on a smaller,high impedance battery is going to take its loaded voltage way down, and create life issues too.
I wish you all the luck in the world, I just don't believe it will last for the long run given the service use.
