also you can use either the 59, 44 or 46 for the 6.0 The 59 is the biggest, but for some reason, they went the the smaller 44 in 2003. Some say it was something to do with piston slap, but I am unsure. If you want to use the UPF series, you will have to use the UPF-44. I have had good luck witht this filter in very cold conditions, it flows well. There is a filter study using a different UPF that indicated it does not flow well?
I will continue to use this filter.
