Kendall GT-1 synthetic oils
by SR5
02/09/16 02:43 AM
2015 F 150
by BISCUT
02/09/16 01:19 AM
Ever have an "old guy" day?
by daves87rs
02/08/16 10:25 PM
Fram Ultra C$11.87 (Ontario)
by dgunay
02/08/16 10:16 PM
dodge 4.7 fram problem?
by joel95ex
02/08/16 09:45 PM
ok until oil change 4.7 dodge
by joel95ex
02/08/16 09:41 PM
0w20 vs 5w20 running on a Mazda 3 2014
by Stewie
02/08/16 09:37 PM
5w20/30 4.4L Castrol Edge WM Canada $24.88
by Stewie
02/08/16 09:31 PM
Back to greasing stuff...
by JHZR2
02/08/16 09:04 PM
Castrol Import Multi question
by Carguy21
02/08/16 08:20 PM
2005 F150 steering rack
by Colt45ws
02/08/16 08:12 PM
Tinkering around today with my Cold Air Intake
by GumbyJarvis
02/08/16 07:51 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
25 registered (Char Baby, Black, billt460, 3800Series, 6 invisible), 492 Guests and 201 Spiders online.
56865 Members
66 Forums
244434 Topics
#3282117 - 02/14/14 03:18 PM '04 F550, 6.0L PSD, Delo 400 10w-30, high K, Na
sdan27 Offline
Loc: Michigan
This is the first UOA I've done on the 2004 F550 with a 6.0L Powerstroke we bought as a service truck for use on our farm. Truck has been real great for us so far with few issues. As soon as we got the truck I changed the oil to Delo 400 10w-30 and added some Rev X additive. I also did EGR delete, flushed the cooling system and switched it to a red ELC coolant, added and coolant filter, and added a Fleetguard LF777 bypass filter. I have no idea the history of this truck. I called the Ford dealership it was originally purchased from with the VIN before we committed to purchasing it but they weren't able to give me much service history due to the fact they changed the way they store their files since then? The truck has about 169,000 miles total. I'm not sure the mileage on the oil but it has 187 hours. Changed the oil when we got the truck early last spring.
Fe 17
Cr 1.1
Mn .7
Ni .7
Al 4.4
Pb 4.2
Cu 1.3
Sn 2.1
Si 5.6
Na 39
K 861
B 1032
Mo 72
Mg 574
Ca 1521
P 943
Zn 1056
S 1945
Soot 0%
Oxid 60%
Nitr 58%
Sulf 61%
TBN 10.88
Visc 10.44
Seems real good except for the high Potassium and Sodium indicating might be a head gasket leak or something which these engines are known for. I did have the coolant go down on me some that I had to top it up but I also had an external leak on the radiator which I think I repaired. The Viscosity still seems good and wear metals are real low so do you think I should keep running and resample at a shorter interval to see if the coolant contamination continues to go up or just drain the oil and resample again next year?
Edited by sdan27 (02/14/14 03:19 PM)
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#3282134 - 02/14/14 03:32 PM Re: '04 F550, 6.0L PSD, Delo 400 10w-30, high K, Na [Re: sdan27]
sdan27 Offline
Loc: Michigan
Immediately after my initial post I did a google search on the Rev X additive and high potassium and I guess a lot of people have seen UOA results like that. Sounds like Rev X contains a lot of K, Na, Ca, and B. So, I'll just keep running the oil and see what happens.
#3282264 - 02/14/14 05:54 PM Re: '04 F550, 6.0L PSD, Delo 400 10w-30, high K, Na [Re: sdan27]
dustyroads Offline
Loc: upstate NY
I was kind of thinking along those lines. It seems like I have seen similar boron and potassium numbers in other uoa reports using Rev X or similar products. Even on "rinse" oci there's a fair amount still showing as residue, so to speak.
2011 Taurus sel
2013 Volvo truck with D13
#3284532 - 02/16/14 08:01 PM Re: '04 F550, 6.0L PSD, Delo 400 10w-30, high K, Na [Re: sdan27]
sw99 Offline
Loc: Colorado
On a side note, have you considered Archoil 9100 in lieu of Rev X? I'm sold on the stuff and it's half the price.
2012 Hyundai Tucson 2.4L
2012 Honda Civic EX 1.8L
2001 Ford F350 XLT 7.3L
#3285001 - 02/17/14 10:11 AM Re: '04 F550, 6.0L PSD, Delo 400 10w-30, high K, Na [Re: sdan27]
sdude2k2000 Offline
Loc: Southern Oregon, USA
Just monitor the situation, but just about all the additives for the 6.0 have potassium in them... and quite a bit of it at that.
'08 Ford Fusion SEL 3.0L
Pennzoil Ultra Plat 5w20 | Fram Ultra XG2
'15 Toyota Prius
Toyota 0w20 Synthetic | OEM oil filter
