cold seizure on a small air cooled engine?
by motor_oil_madman
06/30/16 11:20 PM
Walmart.com PUPP 5W-20 $22.47
by mike718
06/30/16 11:20 PM
Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
06/30/16 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
06/30/16 08:39 PM
Firestone TF2876 C&P
by holdorf333
06/30/16 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
06/30/16 08:30 PM
Got to experience cornering ABS today
by LoneRanger
06/30/16 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
06/30/16 08:03 PM
What product was that?
by another Todd
06/30/16 07:19 PM
choice between reciprocating corded saws
by edwardh1
06/30/16 07:04 PM
Is the driving experience getting worse?
by fdcg27
06/30/16 06:24 PM
Scratched wheel
by gabriel9766
06/30/16 05:52 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
62 registered (AirgunSavant, bdcardinal, Bandito440, 2015_PSD, barkingspider, 8 invisible), 1207 Guests and 11 Spiders online.
58322 Members
66 Forums
251064 Topics
Page 1 of 3 1 2 3 >
#3282054 - 02/14/14 02:17 PM 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill
chaser06 Offline
Loc: Wisconsin
This is the first UOA on my new Camry. This is a commuter vehicle seeing about 110 miles per day. Usage is primarily highway (about 80%). As expected, certain wear metals are high as well as silicon. I was pleased to see a remaining TBN of 1.9 although this vehicle sees highway use most of the time.
Any comments are welcome.
Code:
2014 Camry 2.5L
Toyota 0W20 Factory Fill
Miles on Oil:  9,925
Miles on Vehicle:  9,925
No Oil added
Sample taken: 2/12/14
ALUMINUM       5
CHROMIUM       0
IRON           21
COPPER         101
LEAD           1
TIN            0
MOLYBDENUM     162
NICKEL         3
MANGANESE      9
SILVER         0
TITANIUM       47
POTASSIUM      8
BORON          3
SILICON        242
SODIUM         369
CALCIUM        1506
MAGNESIUM      7
PHOSPHORUS     651
ZINC           752
BARIUM         3
cSt Viscosity @ 100C   6.33
SUS Viscosity @ 210F   46.9
Flashpoint in F        385
Fuel %                  TR
Water %                 0.0
Antifreeze %            0.0
Insolubles %            0.3
TBN                     1.9
Edited by chaser06 (02/14/14 02:26 PM)
'09 Honda CR-V EX-L
'14 Toyota Camry XLE 2.5L
#3282061 - 02/14/14 02:22 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
Klutch9 Offline
Loc: Rochester, MI, US, World
That's a nice TBN with nearly 10k miles on the oil. That makes me even more excited to use my TGMO 0w-20 this summer smile how do you like the car?
'11 Fusion 2.5L - 61k miles - Napa 0w20, Fram TG filter
'08 Sedona LWB 3.8L - 96k miles - Napa 0w20, K&N PS filter
#3282066 - 02/14/14 02:31 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: Klutch9]
chaser06 Offline
Loc: Wisconsin
The Camry meets my needs as a commuter. It gets good fuel economy, has a nice ride, handles well, and has decent acceleration. Avg fuel economy for the life of the vehicle is 30.6 mpg. I'm expecting an increase as warmer weather arrives and winter fuel is phased out. I purchased it in Oct 2013.
'09 Honda CR-V EX-L
#3282073 - 02/14/14 02:37 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
SatinSilver Offline
Loc: Ohio
No Accord anymore huh?
Originally Posted By: chaser06
Here is the first UOA on my Honda. The vehicle has a total of 19,668 miles with almost 10k on this sample. No oil was added during this run. I drive about 100 miles per day commuting mostly highway miles (about 90%). My Maintenance minder was at 15% when I changed the oil.
Miles on oil: 9962
Miles on vehicle: 19668
Date of test: 6/13/08
Oil: Mobil 1 5W-20
Oil Filter: Purolator PureOne
Iron 18
Chromium 0
Lead 4
Copper 9
Tin 0
Aluminum 10
Nickel 5
Silver 0
Silicon 25
Boron 47
Sodium 24
Magnesium 17
Calcium 2081
Barium 0
Phosphorus 668
Zinc 823
Molybdenum 92
Titanium 0
Vanadium 0
Potassium 0
Fuel <1
Visc100 7.39
Water 0
Coolant No
TBN 3.39
Any comments?
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC filter
#3282079 - 02/14/14 02:46 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: SatinSilver]
chaser06 Offline
Loc: Wisconsin
Nope. I thought I'd try something different.
'09 Honda CR-V EX-L
#3282084 - 02/14/14 02:48 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
walk23 Offline
Loc: TX - TEXAS
Noticed the titanium in the factory fill. The high wear numbers and high silicon causes me to wonder whether shorter first oil changes are the way to go. Any opinions ?
2005 F-150
5w20 PU/ FU XG-2
2013 Nissan 2.5 Altima SL
0W20 PP GTL/ FU7317
#3282104 - 02/14/14 03:03 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: walk23]
BISCUT Offline
Loc: NewYorkistan
Amen to you!! Commuter car or not, takes a pair to run FF to 10k. Impressied with the results also.
2015 F150 Lariat M1 0-20 FRAM ULTRA (12k)
2007 Maxima M1 5-30 FRAM ULTRA (113k)
#3282114 - 02/14/14 03:12 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
Danh Offline
Loc: Illinois
Close to shearing out of grade, though. Don't know if oils used during break-in shear more than normal, but this seems worth watching, especially as your use pattern is close to ideal.
#3282125 - 02/14/14 03:25 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
BearZDefect Offline
Loc: Lexington, KY
It appears 10,000 miles on TGMO in your usage pattern works well. I would continue with confidence.
However, under Toyota Care for the Camry 2.5, dealers will only change the oil every 10,000 miles (or one year) regardless of usage conditions. I am not confident that the oil will keep the engine clean for 10,000 miles of only short trips. At 5,000 miles the dealer only checks the level and rotates wheels, no oil change.
#3282178 - 02/14/14 04:21 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: BearZDefect]
chaser06 Offline
Loc: Wisconsin
Toyota specifies synthetic oil and after reading various posts on this site regarding TGMO I decided to follow Toyota's recommendations. If my use consisted of only short trips I think my OCI would be less; not 5,000 miles, maybe 7,500.
Toyota's "maintenance minder" (sorry, I'm used to Honda's) appears to be purely odometer based; every 5,000 miles.
'09 Honda CR-V EX-L
#3282193 - 02/14/14 04:49 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
Barkleymut Offline
Loc: Richmond, VA
you could always change the oil at 7k with some ST. Just leave the filter on.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#3282290 - 02/14/14 06:17 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
dustyroads Offline
Loc: upstate NY
Very impressive! Does TGMO off the shelf have sodium or titanium in it?
2011 Taurus sel
QSGB 5W20 MC FL500S
#3282599 - 02/15/14 03:29 AM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: walk23]
Patman Offline
Loc: Oakville, Ontario
What high wear numbers? The numbers in this UOA look great!
2005 Corvette (M1 5w30 & Fram Ultra)
2006 Civic EX Coupe (M1 0w20 & M1 filter)
2010 BMW 328i X-Drive (M1 0w40 & Mann filter)
#3282796 - 02/15/14 09:39 AM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: Patman]
SatinSilver Offline
Loc: Ohio
+1, yeah really, I was thinking the same thing. My dad has a 2012 Camry and brother just bought a 2014 Camry. So it's good to see this report. Dad has been going 10k intervals and I've been checking the level every few weeks. It's coming up on 40k miles.
#3283272 - 02/15/14 04:45 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: Patman]
ccl088 Offline
Loc: Louisiana
Copper @ 101 for one..
#3283300 - 02/15/14 05:01 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: ccl088]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
What copper numbers should a factory fill that has been run for almost 10,000 miles display?
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3283318 - 02/15/14 05:11 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: walk23]
Spector Offline
Loc: Chattanooga, TN
Well, metal wear is related to miles driven and in this case we also have the break in period where iron and copper are usually huge. I would love to see labs start reporting wear metals in PPM/mile as that is more relevant that just PPM. 20 PPM of iron in 3000 miles may be of a little concern but 20 ppm of iron in 10,000 miles, fantastic! Of course after the engine has been broken in and that can be anywhere from 20,000 t0 50,000 plus miles
Silicon numbers at 10,000 miles kind of useless due to break in. Remember UOA is trend analysis and need several more samples to really get some concept of how the engine is breaking in and operating
Edited by Spector (02/15/14 05:13 PM)
#3283438 - 02/15/14 07:16 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: dustyroads]
cookieman214 Offline
Loc: SC
Toyota 0W-20 SN Virgin UOA
Iron 0.7
Nickel 0.0
Chromium 0.1
Titanium 0.2
Copper 0.0
Aluminum 1.5
Tin 0.7
Silicon 5.7
Potassium 0.0
Sodium 1.1
Boron 0.6
Barium 0.0
Calcium 2829
Magnesium 12
Molybdenum 124 Was 800 SM rated
Sodium 1.1
Phosphorus 906
Sulfur 3489
Zinc 910
[email protected] 37.38
[email protected] 8.54
VI 216
TBN 6.84
#3283505 - 02/15/14 08:28 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: ccl088]
Patman Offline
That's not alarming at all, a lot of engines put out a lot of copper (such as the LS2 in my Corvette) but yet the other wear metals remain low, which shows that the copper in the oil is not abrasive. Just look at the other wear metals in this report, they are incredibly low. So all that copper in the oil is not a cause for concern at all.
I would be impressed with these numbers even for a fully broken in engine, so to see this run with 10k on the factory fill, just blows me away. I see absolutely no reason to call for early oil changes based on this UOA.
#3283692 - 02/16/14 01:56 AM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
Thanks for sharing. I just sent in my 2013 Camry 2.5L TGMO 0W-20 for analysis and expect test results back in about a week. I sure hope mine comes back as nice, especially since my sample is a 3k oil change. I am sending it in because the car has to idle 20 min per day during that last 3k ( brutal cold -12F to -27 F) followed by a 40 mile hwy trip. Curious to see if the oil has thinned due to fuel dilution or if it has burned it off.
Such a thing as a 15k oil change or a lifetime transmission fluid!!??
#3284990 - 02/17/14 09:56 AM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
addyguy Offline
Loc: Canada
That isn't exactly TGMO.
What it is, I suspect, is Mobil Super 0W-20, Mobil less-expensive syn oil. We know Mobil makes the FF for Toyota, so they are using a lower-cost option for the FF.
We know this because Mobil Super uses Ti in it's add pack, we've seen this in VOA's.
2010 Kia Soul 2U - 2.0L I-4, auto, 86k miles.
QSGB 5W-20, NAPA select filter(?)
#3285172 - 02/17/14 12:49 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
Maxima97 Offline
Loc: WA - Washington
My think is the same Mobil 0w-20 in FF. The UOA looks great. Just change it out after 7.5k. No big deal.
97 Maxima, Maxlife 5W30
99 LX470,PU 5W30
98 Explorer,PU 5W30
93 Prizm, PU 5W30
01 Camry,G oil 5W30
95 Villager,Maxlife 5W30
05 Accord,Idemitsu 0W20
#3285349 - 02/17/14 04:02 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: addyguy]
chaser06 Offline
Loc: Wisconsin
I searched for a VOA for mobil super synthetic 0w20 voa and the closest I got was for a 5w20. Do you have a link?
'09 Honda CR-V EX-L
#3285351 - 02/17/14 04:03 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: Maxima97]
chaser06 Offline
Loc: Wisconsin
Why do you recommend changing it out at 7.5K?
'09 Honda CR-V EX-L
#3290739 - 02/22/14 03:08 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
SumpChump Offline
What amazes me is that his Moly is 160something and my UOA on the same oil but with 1/3 as many miles came back with Moly of 54.
#3290743 - 02/22/14 03:15 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: SumpChump]
SatinSilver Offline
Loc: Ohio
Was this on your Corolla or Camry?
http://www.bobistheoilguy.com/forums/ubb...-20#Post3289770
#3291245 - 02/23/14 01:00 AM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: SatinSilver]
SumpChump Offline
http://www.bobistheoilguy.com/forums/ubb...-20#Post3289770 [/quote]
My New Camry.... Well actually my new Corolla also. Both had Moly of 54 to 44 range after many less miles on the oil than the OP's. Like 1/3 the miles for my Camry oil and 1/9 the mile on the Corolla oil. And both of mine were not factory fills as the OP's was. These were TGMO second and third fills, again, with many less miles on the oil. Could he have had SM rated TGMO for his factory fill? Can't understand how my Moly was lower .
#3291376 - 02/23/14 07:53 AM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: SumpChump]
chaser06 Offline
Loc: Wisconsin
My vehicle was built in August 2013 so I would say it's unlikely the factory had inventory of SM then.
Our usage patterns are very different. My usage is almost all highway miles with little warm up. Your's see extensive warm up and more city/rural usage.
It's still surprising however that TBN can be so low in one and Moly has taken such a hit.
What's your plan?
'09 Honda CR-V EX-L
#3291388 - 02/23/14 08:13 AM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
SumpChump Offline
No plan other than frequent oil changes. Blackstone mentioned all was goin great. Perhaps they know something about the motors as they break in, eating up the TBN and Moly? They expressed no concern in their narrative report heading box.
I guess my plan also includes 'watch'. As in pay for another UOA in the next two oil changes to see if the Moly and TBN are still being eaten (down).
#3292650 - 02/24/14 10:12 AM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: SumpChump]
chaser06 Offline
Loc: Wisconsin
I'd be interested in seeing a UOA of your use when temperatures rise and you're not warming up the vehicle(s) as much.
Edited by chaser06 (02/24/14 10:13 AM)
'09 Honda CR-V EX-L
#3299414 - 03/02/14 04:10 PM Re: 2014 Camry 2.5L, 9925 miles, 0W20 Factory Fill [Re: chaser06]
2011Eco Offline
Loc: WI
It is great to see this report. My wife now drives a 2014 Camry 4 cylinder and I just changed the oil at 5K and sending in the sample tomorrow to Blackstone. I will then have Toyota change at 10K and 20K...I wonder if I can get the oil sample when the dealer changes it....
I put Mobil 1 OW-20 in as the replacement...
Page 1 of 3 1 2 3 >
