GM worker Saves a life on company property.
by Charlie1935
02/10/16 03:43 PM
Idle wear
by DrRoughneck
02/10/16 03:27 PM
Download a WHOLE site? AllData, Toyota TIS etc
by SumpChump
02/10/16 03:07 PM
Mixing washer fluid with windex?
by 55Test
02/10/16 02:48 PM
Car won't start, no gas movement observed, pump?
by Hal9000
02/10/16 02:39 PM
Mixing premuim with regular gas
by KevinV
02/10/16 02:38 PM
Winchester 9mm steel case
by Sonic
02/10/16 02:33 PM
Towing an automatic, rear-wheel drive?
by Hal9000
02/10/16 02:33 PM
Concealed Cell Phone Permits
by Doog
02/10/16 02:03 PM
Belgian Castrol 0w30 / 2500mi / '04 Volvo S60 2.5T
by charlesb2003
02/10/16 01:52 PM
2013 VW GTI - Engine oil recommendation
by phem0r
02/10/16 01:45 PM
Automotive Firmware updates - who does them?
by OVERKILL
02/10/16 01:14 PM
pocketdrummer, bspag, Lana, phem0r, 19kj57
56882 Registered Users
128 registered (440Magnum, 2015_PSD, 69GTX, 4ever4d, 05LGTLtd, 15 invisible), 1735 Guests and 228 Spiders online.
56881 Members
66 Forums
244513 Topics
Page 1 of 2 1 2 >
#3281021 - 02/13/14 05:48 PM Universal Tractor Transmission Oil (UTTO)
Whitewolf Offline
Loc: MI, USA
I'm looking into UTTO (Tractor Hydraulic Fluids). What I am finding in some cases is not good. Under treating the additive is more common than I thought so what I am looking for is what brand do you use and then has anyone done VOA on the product, that way it is possible to tell in most cases what exactly is being done. Believe it or not some of the really cheap products have little or no additive content at all!
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
#3281078 - 02/13/14 06:38 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
roadrunner1 Offline
Loc: oh
I use John Deere HyGard(ISO 46)/HyGard Low Vis(ISO 32). I have never had a VOA done but I have used this fluid exclusively in all of my hydraulic/tractor applications for over 25 years without issue.
You are correct, there are several sub-par fluids available using out of date specs to catch your attention thinking that they're current.
'15 F350 6.7
#3281127 - 02/13/14 07:30 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
NHGUY Offline
Loc: USA
I wonder how "Navi Gard" does.Seems that is always the amongst the lowest price stuff.
#3281235 - 02/13/14 09:12 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
Donald Offline
Loc: Upstate NY
So what have you found that is good and what is bad. For tractor or Bobcat?
I buy the stuff at TSC for my Bobcat. Its a TSC brand of tractor and hydraulic fluid.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3281237 - 02/13/14 09:14 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
Rand Offline
Loc: NE,Ohio
buy brand name also certain things you learn to avoid.. like ones that list certs from 1970's
2015 Forester I-Premium 6MT
#3281245 - 02/13/14 09:22 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: Donald]
Whitewolf Offline
Loc: MI, USA
Basically you have to look at the physical and chemical properties for a start. We all know that for a UTTO there are only three realistic additive suppliers namely Lubrizol, Oronite and Afton. For all of them we know what the P@C should look like at the correct treat rates. So it's not difficult to figure out when something doesn't look quite right.
~ PJ Plauger
#3281297 - 02/13/14 10:03 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
Ramblejam Offline
Loc: Kentucky
Which products in particular are you talking about?
#3281395 - 02/13/14 11:56 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
Silk Offline
Loc: New Zealand
We use Valvoline Farmplus Hydratrans.
1994 Mercedes C220 - Penrite Advantage 10/40
1987 BMW R65 - Penrite 20/50
1994 Toyota Levin - MSL 5/30
1996 Volvo T5 - Fuchs Ultralube 15/40
#3281443 - 02/14/14 01:36 AM Re: Universal Tractor Transmission Oil (UTTO) [Re: Ramblejam]
Whitewolf Offline
Loc: MI, USA
I am not in a position to name names right now for legal reasons but I know that under treating and additive dilution is going on and I'm not the only one. It's worse than ATF! What people have to look for is wording such as 'recommended for use' or 'meets requirements'. The packaging often looks convincing but it seems that the contents are not.
Edited by Whitewolf (02/14/14 01:37 AM)
~ PJ Plauger
#3281748 - 02/14/14 10:26 AM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
MolaKule Offline
Loc: Iowegia - USA
If a customer has any questions about the additive treat rate in a UTTO, I would advise him to get a VOA and submit it here so we can comment.
I don't think under treating is widespread, but as in some motor oils we have seen, via PQIA, there are some unscrupulous distributors out there.
Plan: Drink coffee, be awesome, and ignore negativity. smile
#3281973 - 02/14/14 01:10 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: MolaKule]
Whitewolf Offline
Loc: MI, USA
You are correct a new oil analysis is needed. It's a bigger problem than perhaps you think. I have been shocked. That's why I raised this subject.
Edited by Whitewolf (02/14/14 01:14 PM)
~ PJ Plauger
#3282033 - 02/14/14 01:58 PM Re: Universal Tractor Transmission Oil (UTTO) [Re: MolaKule]
Whitewolf Offline
Loc: MI, USA
I think that the problem is greater than you think!
~ PJ Plauger
#3290520 - 02/22/14 11:52 AM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
jhellwig Online   content
Loc: Ottumwa, Iowa
I would go with the manufacture recomended fluid instead of a universal fluid. On certin applications there is a noticible difference. If it is just a dry clutch standard transmission that uses tge trans fluid for hydraulica then you can get away with a universal fluid. Anything with wet clutches powershift or hydraulic brakes are sometimes touchy.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2013 Chevy Traverse lt 3.6l direct injection
1983 Chevy K5 350
#3388575 - 06/04/14 11:03 AM Re: Universal Tractor Transmission Oil (UTTO) [Re: Whitewolf]
jake88 Offline
Loc: MO
I always tell people to look for a J20C (or J20D for cold-weather) fluid. That is still the flagship specification for the industry.
The inferior products typically will be made from line wash, napthenic base oils and with little or no additive. They'll make claims like JDT303 or call it "303 Fluid"
'13 Mazda 3 Touring 5DR, 2.0L
'12 Ford Fiesta SE 4DR, 1.6L
#3389349 - 06/05/14 05:10 AM Re: Universal Tractor Transmission Oil (UTTO) [Re: jake88]
Rob_Roy Offline
Loc: Northern, NY
x2.
http://www.tractorlife.com/lawsuit-raises-questions-fluid-quality/
http://www.tractorlife.com/303-tractor-fluid-problems-offset-upfront-savings/
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
Page 1 of 2 1 2 >
