Building a pole barn
by SVTCobra
05/04/16 09:44 PM
Hemorrhoids ?
by Merkava_4
05/04/16 09:40 PM
Well, I jumped on the ecoboost bandwagon...
by tomcruise
05/04/16 09:18 PM
2016 Audi S3 - EA888 Gen 3 - Factory Fill - 2007mi
by agpatel
05/04/16 09:16 PM
Can you live without credit cards?
by motor_oil_madman
05/04/16 09:04 PM
OC on W201 with LiquiMoly Leichtlauf HT 5W-40
by IllinoisSparky
05/04/16 08:54 PM
The Nooner
by MolaKule
05/04/16 08:14 PM
how often are you guys buying new tires
by bowlofturtle
05/04/16 07:56 PM
Why are some experienced people so conceited?
by motor_oil_madman
05/04/16 07:49 PM
alternative to Netstumbler...
by daves66nova
05/04/16 07:05 PM
Unable To Play Burned CD's in Car Player
by sleddriver
05/04/16 06:58 PM
Visiting Hudson Bay?
by JHZR2
05/04/16 06:54 PM
NatedeScate, Bogie69, Cali, Fyko, Palmer
57794 Registered Users
103 registered (alcyon, 06AllAmerican, abycat, 19jacobob93, 2KBMW, 11 invisible), 1 Guest and 0 Spiders online.
57794 Members
66 Forums
248484 Topics
#3279744 - 02/12/14 05:45 PM Clutch Master cylinder fluid level drop normal?
Drew99GT Offline
Loc: Colorado Springs
Is it normal for the fluid level in a clutch hydraulic system to drop as the friction material on the pressure plate and disk wear away with usage, similar to what happens with the brake fluid level in cars as the pads wear?
Thanks!
Edited by Drew99GT (02/12/14 05:54 PM)
#3279758 - 02/12/14 05:57 PM Re: Clutch Master cylinder fluid level drop normal? [Re: Drew99GT]
oldhp Offline
Loc: Southern Illinois
Yes, same principle.
2014 RAM Express 3.6/8 speed work truck.
2012 Equinox 2.4-Wife's Ride
#3279794 - 02/12/14 06:25 PM Re: Clutch Master cylinder fluid level drop normal? [Re: Drew99GT]
fdcg27 Offline
Loc: OH
The clutch master reservoir level won't drop all that much over the life of a disc in my experience.
If you're seeing much or continued drop, you have a leak.
If it isn't getting worse, don't sweat it.
Just add a little brake fluid as needed.
It won't be much.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3279800 - 02/12/14 06:30 PM Re: Clutch Master cylinder fluid level drop normal? [Re: Drew99GT]
clinebarger Offline
Loc: Fort Worth, Texas
The Fingers on the Pressure Plate move out toward the Clutch Slave Cylinder in turn compressing the Slave Cylinder as the Clutch Disc wears, In theory the level should rise a little.
2001 Chevy Camaro 5.3L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3279843 - 02/12/14 06:51 PM Re: Clutch Master cylinder fluid level drop normal? [Re: clinebarger]
fdcg27 Offline
Loc: OH
But this movement is very small.
The difference in thickness between a new disc and an unserviceable disc is very little, nothing like it is with brake pads.
#3280960 - 02/13/14 04:50 PM Re: Clutch Master cylinder fluid level drop normal? [Re: Drew99GT]
oldhp Offline
My bad.....thinking backwards. Fluid,if anything should rise. Yep.
#3281023 - 02/13/14 05:48 PM Re: Clutch Master cylinder fluid level drop normal? [Re: Drew99GT]
Tones Offline
Loc: Houston, TX
I had one start leaking but showed no outward signs. I figured it out by pushing on the boot. It was full of fluid and held a little pressure.
'11 Toyota Avalon
'11 Toyota Corolla
'10 Honda Civic
'13 Ford F-150 Supercab 5.0
#3281789 - 02/14/14 10:49 AM Re: Clutch Master cylinder fluid level drop normal? [Re: Tones]
Drew99GT Offline
The boot on the slave cylinder?
#3340943 - 04/12/14 07:21 PM Re: Clutch Master cylinder fluid level drop normal? [Re: Drew99GT]
Tones Offline
Loc: Houston, TX
Yes, the boot on the slave cylinder was full of fluid.
'11 Toyota Avalon
'11 Toyota Corolla
'10 Honda Civic
