Hi,
After having had serious trouble removing some nuts on my car, I need to find a solution on how to easily remove the nuts next time. Most of the fasteners are located in areas where it isn't warm/hot (i.e. not close to the engine). I see two solutions:
1. Threadlocker, such as Loctite blue.
2. Anti seize, such as Loctite copper or aluminum paste. Or even Marine grade paste for salty conditions.
I would prefer to use an anti seize product, but I am worried that the nuts might rattle loose due to engine and road vibrations. The reason for my worries are, that the friction factor has been reduced (due to the paste) and in theory an anti seized fastener should easier unwind itself. But what happens in the practical world?
a) Is a threadlocker the truly preferred product in vibrating equipment?
b) Are loosening of anti seized fasteners no problem if they have been torqued correctly?
Anyone with experience that anti seize truly can be used on vibrating equipment? Is it just a matter of the correct torque setting?
Lucas
Lucas
