Snowdog
by CourierDriver
29 minutes 59 seconds ago
Kendall GT-1 synthetic oils
by SR5
Today at 02:43 AM
2015 F 150
by BISCUT
Today at 01:19 AM
Ever have an "old guy" day?
by daves87rs
Yesterday at 10:25 PM
Fram Ultra C$11.87 (Ontario)
by dgunay
Yesterday at 10:16 PM
dodge 4.7 fram problem?
by joel95ex
Yesterday at 09:45 PM
ok until oil change 4.7 dodge
by joel95ex
Yesterday at 09:41 PM
0w20 vs 5w20 running on a Mazda 3 2014
by Stewie
Yesterday at 09:37 PM
5w20/30 4.4L Castrol Edge WM Canada $24.88
by Stewie
Yesterday at 09:31 PM
Back to greasing stuff...
by JHZR2
Yesterday at 09:04 PM
Castrol Import Multi question
by Carguy21
Yesterday at 08:20 PM
2005 F150 steering rack
by Colt45ws
Yesterday at 08:12 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
76 registered (BlueOvalFitter, b1amgm47, Boomer, Brad_C, 05LGTLtd, 901Memphis, 10 invisible), 942 Guests and 200 Spiders online.
56865 Members
66 Forums
244433 Topics
Page 1 of 4 1 2 3 4 >
#3279185 - 02/12/14 10:22 AM Kreen treatment plan on 2004 Liberty 3.7l burner
deanm11 Offline
Loc: Northern NJ
I don't plan to keep this car long but I'm going to take a shot at significantly improving the oil consumption. 158k miles on it, my mom was the original owner and I've just recently bought it for my daughter to drive until she goes to college.
I did most of the maintenance on the car over its life - slightly neglected at times in terms of letting oil change intervals get to 10k but nothing horrific. Synthetic probably used 2/3 of the time and with whatever oil filter came in an oil change deal. Maybe it was run a bit too low at times after the consumption became an issue- which probably happened a bit after 100k miles. I'm guessing it burns a quart every 700 miles at this point; I'd say that rate has been fairly steady since it started burning. No real mechanical failures on the car; other maintenance has been limited brakes, tires and maybe one trans pan dump change. (I'm changing both trans filters and plan to do about 3 pan dumps.)
I've put in a new PCV and did a pint of MMO in the oil with no discernible effect. I bought a quart of Kreen and have a tentative plan. I'd like any suggestions on amendments but it must include Kreen in plan; I will consider additional products in the plan.
I also have on the way two sets of Autolite 3923/cheap cooper plugs, 2 new NTK upstream oxygen sensors and a few extra oil filters. I will be picking up the oil needed as referenced in the plan.
Plan:
1) Piston soak. Pull plugs and pour about 2oz Kreen in each cylinder through a brake bleed hose. Rotate motor by hand a few revolutions and let sit for about 48 hours. Any need to thread the plugs back in to close off the soak area?
2) Start it up, watch the smoke show for a bit, drive a few miles and bring back warm for oil change.
3) Put in 10w30 Rotella and new filter with a pint of Kreen. (is that too much?)
4) At 500 miles of this oil fill, change oil filter
5) Another 500 miles and put in a high mileage oil/new filter (not decided on 5w30 or 10w30), new plugs, new oxygen sensors
Thanks for any constructive suggestions.
#3279211 - 02/12/14 10:58 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
JHZR2 Offline
Loc: New Jersey
I'm staying tuned. I consume about the same rate and have a lifter tick. Same mileage roughly. I've run kreen without result. Ditto for MMO.
#3279242 - 02/12/14 11:15 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: JHZR2]
Ramblejam Offline
Loc: Kentucky
What vehicle/engine?
Tick on cold start, or constant?
#3279287 - 02/12/14 11:37 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
Doog Offline
Loc: North Coast
Your plan sounds interesting and I would follow it. I would however do an oil flush after the kreen with cheap oil for 500 miles. Then go to PP 5w30 or 10w30 if you can find it and purolator filter and do 5000 mile OCI's. I would stay with the PP for the balance of the time you own it. It is a great cleaning oil and will clean that engine over time.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#3279307 - 02/12/14 11:48 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: Ramblejam]
JHZR2 Offline
Loc: New Jersey
Mine is a 91 BMW 318i with M42 engine Ive posted about elsewhere. Tick is only at cold start. Consumption is intermittent. Thoguht kreen or MMO would solve the tick issue but apparently not.
Perhaps tick and consumption are related, like a bad valve...
#3279350 - 02/12/14 12:16 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: JHZR2]
demarpaint Offline
Loc: NY
It could be.
God Bless Our Troops
#3279534 - 02/12/14 03:17 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: Doog]
deanm11 Offline
Loc: Northern NJ
I will incorporate your recommendation, thank you. This process is going to take some time with the modest miles put on this vehicle... I will get it used extra miles over normal to make it go faster.... despite the horrific gas mileage...
Edited by deanm11 (02/12/14 03:17 PM)
#3279570 - 02/12/14 03:45 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
deanm11 Offline
Loc: Northern NJ
Any recommendations on Rotella type for that particular run with the pint of Kreen? It is pretty cold in NJ...
#3279628 - 02/12/14 04:31 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
Trav Offline
Loc: MA, Mittelfranken.de
Yes. Put the plugs back in, hand tight is fine.
Kreens solvents evaporate quickly and you don't want anything like dirt falling in the plug holes.
Piston soak on a V or horizontal engine is a bit of a bugger and is usually not very successful at freeing sticky rings because only part of the piston really "soaks" in the solvent regardless of the product.
Try to get a small hose shooting product all the way around the piston, a large disposable plastic syringe works good.
#3279641 - 02/12/14 04:39 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
TrevorS Offline
Loc: California
Before something like Kreen I might be tempted to try a high ester oil.
If I couldn't wait, I would try a detergent based engine flush product.
Also why not go to thicker / high mileage oil to reduce consumption? A quart every 700 miles must be getting expensive!
#3279647 - 02/12/14 04:42 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: Trav]
demarpaint Offline
Loc: NY
Those syringes work great. Do you also recommend turning the engine over by hand [via a breaker bar] every few hours and refilling? That's how we've done it and it seems to work well.
#3279680 - 02/12/14 05:00 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: demarpaint]
Trav Offline
Sure why not it cant hurt. You just want to get as much product all around the rings as possible.
#3279685 - 02/12/14 05:06 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
TrevorS Offline
Loc: California
I would run Techron through a full tank as well, prior to a piston soak or anything else.
#3279715 - 02/12/14 05:27 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: Trav]
demarpaint Offline
Loc: NY
A nice long soak time works well too. After the soak take the car for a drive and change the oil and filter.
#3279757 - 02/12/14 05:57 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: demarpaint]
Trav Offline
Kreen in the oil probably has a better chance of producing some results if in fact any are obtainable.
You know yourself there is really no magic bullet, once something is stuck (not just sticking) everything you try is a hail Mary pass.
Giving the product time to work is important with any product. Personally for genuinely stuck rings i would soak them in Chemtool and use the Kreen in the oil.
The object is to break the ring free of the carbon and varnish filled grooves, its not easy.
#3279954 - 02/12/14 08:05 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: TrevorS]
deanm11 Offline
Loc: Northern NJ
10w30 as compared to 5w30 and high mileage oil didn't seem to change anything though my records on oil add/consumption were spotty.
A quart every 700 isn't all that expensive actually. It works out to the equivalent of like 10c extra per gallon of gas or something like 0.5 gallon in fuel mileage, for example, assuming $4/qt. This process will cost me roughly $125 - a few extra oil changes, the Kreen plus extra miles on the car to speed the process along. That would take me at least 20,000 miles to recoup from less added oil. These Libertys are pigs on gas mileage- I don't know how people justify them for any reasonable amount of mileage use. They are cheap to buy used though.
This project is only about the science experiment aspect + being possibly able to sell the car without an oil consumption issue at a better price.
Edited by deanm11 (02/12/14 08:07 PM)
#3280912 - 02/13/14 04:15 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
strat81 Offline
Loc: Nebraska
Add an "italian tune-up" or two to the process.
My GM 5.3L started to sound like death lately - ticking, valve clatter, piston slap... sounded like a diesel even when warm, and that's with M1 0W-40 in there.
Took it on the highway, warmed it up for 10 minutes, then flogged the heck out of it. Lots of idle to redline runs, ran it at 4.5K for a few minutes at a time, etc.
The next morning, it sounded much, much better. The valve clatter and ticking were completely gone, the piston slap greatly reduced when cold.
Whether or not it helped my oil consumption problem, I don't know yet (the 0W-40 was my second attempt to 'fix' that problem). But I do have a new can of Kreen sitting in the garage that will probably get tossed in sometime late next week.
Molon Labe
#3281168 - 02/13/14 07:55 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
Clevy Offline
Loc: Saskatoon canada
K. As far as carbon goes I was stunned by mmo and how it softened the carbon on my stock Harley pistons. I accidentally spilled some on one of my pistons when I took them out to go big bore. The mmo only splashed the piston and not the whole piston was covered. A couple days after spilling on the piston I saw the deposits and they looked wet,and the carbon was so soft I wiped it off with my thumb,then a shop rag,but the deposits that didn't get mmo spilled on them were still as hard as ever and not removable.
So I'm sold on mmo for carbon,and I'd use it for a piston soak. I'd fill the entire cylinder bore then put in the old plugs to close the hole. Leave it for a few days then hand crank the engine slowly so it can splash the valves too.
Just my opinion. Mmo really surprised me and how it softened up the severe carbon deposits on my pistons. Softened them so much they wiped right off revealing a nice shiny crown.
2006 Charger RT
Miles x 2 per oil filter
#3281336 - 02/13/14 10:31 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
TrevorS Offline
Loc: California
MMO didn't work for him in the oil. Do you think the oil neutralized MMOs cleaning ability?
#3281338 - 02/13/14 10:33 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: TrevorS]
Clevy Offline
I didn't suggest adding it to the oil. I suggested a piston soak
2006 Charger RT
#3281428 - 02/14/14 12:55 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
TrevorS Offline
Loc: California
Didn't say you did. Note the past tense in my question.
#3281592 - 02/14/14 07:54 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: TrevorS]
krismoriah72 Offline
Loc: wv
3.7 chrysler engines are known for failed lash adjusters "lifters" which cause the dreaded ticking and oil consumption.
Kreen may do some cleaning but will not repair the issue.
#3281650 - 02/14/14 09:01 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: krismoriah72]
deanm11 Offline
Loc: Northern NJ
Thank you for this info. How is oil consumed due to this? A failed/partially failed lifter leads to incomplete valve opening and then ? For this vehicle, I have not discerned that this motor has noticeable ticking but is possible I just haven't picked it up.
#3281913 - 02/14/14 12:17 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
Loc: wv
If it isnt ticking..then the lifters are probably good.
Does it smoke alot during startup? bluish smoke? if so then valve stem seals most likely.
Does it smoke after warming up? the more fuel you give it the more it smokes? if so then probably cracked or very worn piston ring causing blowby which then goes thru the crankcase into the pcv then burns the oil.
Give us more info so that we can see where you are losing your oil. Also note that heavy oil burning through combustion will lead to failure of your cat converters.
#3281991 - 02/14/14 01:27 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: Trav]
SteveSRT8 Offline
Loc: Sunny Florida
Nope. And it is many times not successful, too. But that is the nature of Kreen, it is unlikely to be needed in any newer good running engine!
We have had great success with Kreen here, sometimes truly amazing. And it is wonderful for carbon build up. The best I have ever seen IME...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3281996 - 02/14/14 01:29 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: strat81]
SteveSRT8 Offline
Loc: Sunny Florida
make sure you use the Kreen in both the gas and the oil as recommended on the can.
Judging from your story some of the noise you were hearing was carbon knock, the ITU knocked some of it out for a quieter engine. Carbon knock is often confused with piston slap and can seem very similar...
#3282895 - 02/15/14 11:06 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
deanm11 Offline
Loc: Northern NJ
Piston soak in progress. I screwed up the plan by reading the can instructions- they suggest adding the Kreen to your existing fill so after I read that I put it into the oil without remembering I was going to put it in with fresh Rotella. The original plan was kind of long for how little this car gets used so with my screw-up and in combination with the advice I've gotten, here's what I've done and the simplified plan:
1) Pulled plugs and put about 1.5oz Kreen per cylinder with syringe and hose. Replaced plugs loosely and cranked motor over a few times. Put about 8oz Kreen in 3/4 tank of fuel. Put about 16oz Kreen in existing oi fill. 158,457 miles Feb 15,2014
2) After 48hrs of soak, drive around 200 miles and change oil with 10w30 T5 Rotella and new filter
3) Drive 500 miles, put in Penzoil Platinum 10w30 and new filter, new plugs, new oxygen sensors
4) Monitor new consumption rate closely
Now that I've blown my Kreen supply, I guess I would consider an additional product in the Rotella run (and consider running it longer than the 500mi).
#3283023 - 02/15/14 01:07 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
deanm11 Offline
Loc: Northern NJ
I'm probably going to order another quart of Kreen. I want to get it in the Rotella run.
#3290778 - 02/22/14 03:50 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
steve20 Offline
Loc: Morris County NJ
since the vehicle is not used often---what do you think of this idea? Put the required amount of fresh Kreen in the oil. Only run the motor for 10 minutes every day for 5 days in a row---just enough for Kreen to circulate and start its cleaning, this will also help reduce the amount of product which evaporates. After 5 days drive normally
427 Chevy Powered
#3297414 - 02/28/14 02:12 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: steve20]
deanm11 Offline
Loc: Northern NJ
The Liberty got 100 or so more miles on it, maybe 200 since the initial Kreen. I plan to change the oil/filter with Rotella tomorrow. I'm thinking of cutting the old oil filter open to see if I can identify carbon chunks.
#3297581 - 02/28/14 05:10 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: SteveSRT8]
strat81 Offline
Loc: Nebraska
I added Kreen to both oil and gas, as per the directions. What benefit does it have in the fuel tank that I would not see from regular use of Techron or BG 44K?
With the cold weather we've had lately, it seems a bit quieter at cold start than it did prior.
Molon Labe
#3297944 - 03/01/14 05:24 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: strat81]
SteveSRT8 Offline
Loc: Sunny Florida
In our fleet trucks we get carbon build up in the cylinder head. It is a well known issue in engines that are not revved up and wound out regularly. Since we rarely do that sort of thing in a 9000 pound vehicle we suffer a noise that can sound remarkably like piston slap, but is actually carbon deposits.
Kreen easily removes carbon and is highly effective if you need it. It also vaporizes out through the PCV system and can clean the intake and so forth downstream.
But due to the nature of the product it is used in many hopeless cases as a last resort. Thus it is not always an appropriate choice for your particular issue.
I've said this here before, with millions of different vehicles driven in millions of different duty cycles by millions of completely different owners there will always be a few of us with unique problems that may be addressed with additives...
#3299084 - 03/02/14 11:00 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
chrly919 Offline
Loc: Tennessee
I have a 2004 Jeep Grand Cherokee with the 4.7 engine , 140k, with the same issue. Uses a quart about every 500-700 miles. I've used Maxlife 10w40 in it for several years. I would have thought that would help. Haven't tried any additives, although I have used Seafoam in other vehicles for carbon issues.
99 Honda CRV AWD 250k
PHM 5w30 Purolator PureOne
04 Jeep G Cherokee 4x4 145k
Maxlife 10w40 PureOne
93 Corvette coupe M1 5w30
01 Corvette coupe M1 5w30
#3309069 - 03/12/14 08:03 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
deanm11 Offline
Loc: Northern NJ
I am now finally in the observation phase- that is observing to see if consumption has improved. I had put the Kreen in with the existing oil so I have relatively fresh Rotella with no additives, a few hundred miles in. I am observing the dipstick level after the car has sat for at least 6 hours.. Probably 200 miles into it and no material move on the level. I believe the operating range on the dipstick is near a quart. I'd be very satisfied if the level moves 25% or less than the operating range in 500 miles- that would imply improvement to >=2000mi/quart.
There is one significant flaw in my test, I am sorry to report. I had just begun to see a bit of oil on the garage floor. I don't recall it when we first took over the vehicle in November and for a while I thought the oil was from when a different vehicle was in that garage slot. I finally determined I had a modest RH valve cover leak. I'm sure it had to be leaking more modestly at some point and just burning/not enough to hit the ground. So some consumption may have been from this.. that said, the heavy usage has been for a number of years, so my best guess is that this issue was at most 1/4 to 1/3 of my problem, but I can't be sure.
I changed the valve cover gasket over the weekend. There were a couple of gunky/sludgy spots in there. Sorry I didn't take pictures. Since I wasn't primarily responsible for the maintenance, there may have been a cycle or too of conventional oil to 10k+ miles.
#3336199 - 04/07/14 07:36 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
deanm11 Offline
Loc: Northern NJ
So-so results as of late I think. Also hard to interpret with the valve cover leak issue. I bought a can of seafoam on sale that I am considering running into each of manifold, oil and fuel sometime soon and get PP in there. (still running the Rotella) From additional reading, I would consider trying GM top end cleaner that seems to have a good reputation.
Mar 1, 2014 158,661 miles
Mar 5, 2014 158,730 miles: Oil level ~75% operating range, just into upper cross-hatch
Mar 11, 2014 158,805 miles: Oil level ~70% oper. Range, just at beginning of upper cross-hatch
Mar 15, 2014 158,914 miles: 253 miles in. Oil level ~70% oper. Range, just at beginning of upper cross-hatch
Mar 21, 2014 159,018 miles: 357 miles in. Oil level ~60% oper. Range
Mar 25, 2014 159,128 miles: 467 miles in. Oil level ~55% oper. Range
Apr 6, 2014 159,354 miles: 693 miles in. Oil level ~35% oper. Range
#3336930 - 04/08/14 03:11 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: strat81]
strat81 Offline
Loc: Nebraska
Well, 1K miles and about 1 month later on my Rainier:
-Slightly less cold start noise
-Engine 'felt' like it wound spin easier. Deposits gone or thinning of the oil from the Kreen? All in my head?
And the not so good news:
-It apparently cleaned my rear main seal (or maybe the M1 0W-40 did?). What used to be a damp bell housing turned into a drip. Perhaps the RMS has been the source of my consumption?
Anyway, I changed the oil and filter. I put in Maxlife Blend 10W-40 along with some AT-205 ReSeal. Filter is a NAPA Silver. The 10W-40 has made the engine quiet. No piston slap at all. But, it's the thickest oil I've run in this thing, others being 5W-30 and 0W-40, which I'll still use during the cold weather.
Also threw a P0332 so it looks like the intake has to come off for new knock sensors (85k miles). I hate this car.
Edited by strat81 (04/08/14 03:19 PM)
Molon Labe
#3372422 - 05/15/14 11:38 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
Turk Offline
Loc: MN
Hey deanm11,
What's the latest Kreen update??
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3429056 - 07/19/14 07:11 AM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: Turk]
Turk Offline
Loc: MN
Originally Posted By: Turk
Hey deanm11,
Bump! Any update as I may be doing something this (like TODAY?) smile
#3470291 - 08/31/14 07:32 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: Turk]
deanm11 Offline
Loc: Northern NJ
Sorry for the delay.
I think I only got marginal results in the end. I think I am burning a quart/1000mi. This test was imprecise at best because of not having measured the consumption before. I just dumped the Rotella for 10w30 Pennzoil Platinum and will monitor again.
#3471018 - 09/01/14 04:48 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
123Saab Offline
Loc: PA
I have a bottle of Lubro-Moly Pro-Line Engine Flush that I haven used yet, Will use it for my next OC on my 03 Ranger.
I wonder if that could help with your situation?
I have a 3.7L in a Liberty as well, 08 model.
Uses no oil but then it has not yet broken 100K (97K ATM)
I run 5w-20 Valvoline maxlife in it and a bottle of Liqui-Moly Ceratec at the last OC.
Twenty-twenty-twenty four hours to go I wanna be sedated
Nothin' to do and no where to go-o-oh I wanna be sedated
#3472844 - 09/03/14 12:41 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
sleddriver Offline
Loc: Central Texas
Enjoyed reading your account. Sounds like you're frustrated with the results. I've used BG109 engine flush on the sled with good results, but I didn't have the oil comsumption problem you do.
You can search for it under my name and read up on my experience. Good luck!
1998 Volvo V70 T5 210,045 mi. Original Owner.
#3557791 - 12/06/14 05:14 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
deanm11 Offline
Loc: Northern NJ
About 1300 miles into the Pennzoil Platinum change. I've added a quart and am probably in the ballpark of the same dipstick level as after the change. So I'd say I'm now slightly more optimistic that I did improve it some.
#3568579 - 12/17/14 01:16 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
jacky Offline
Loc: wv usa
i would use high mileage oil from now on, maybe try an additive like motor honey, and change the oil more often like every 3,000 miles, and check your oil at least weekly,always keep top off oil with you
1999 plymouth breeze 107,000
#3569657 - 12/18/14 01:44 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
ltslimjim Offline
Loc: WatUpDoc
No need to add a viscosity thickener alone as that will just deplete the additives by volume; aka replacing 1 quart of formulated oil with something that has minimal additives.
OTOH, Lubro Moly's motor oil saver will thicken but has additives FWIW.
However, a High Mileage like MaxLife syn blend or full syn in appropriate grade is your best bet.
+ Maybe Motor Oil Saver.
If I was dealing with consumption and was attempting to see how a lube choice would affect that, I'd go for a HM oil like that with PERHAPS the Motor Oil Saver to prevent burning through at such a rate.
At this point, you'd be concerned of valves leaking or piston rings sticking to let through too much blow-by. That is assuming not much in the way of external engine leaks of course.
Edited by ltslimjim (12/18/14 01:47 PM)
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#3592978 - 01/08/15 04:16 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
deanm11 Offline
Loc: Northern NJ
The Liberty still doesn't get a lot of miles but my tracking of the consumption is still indicating very close to around 1qt/a bit more than 1000mi. I'm likely to sell the car before I try much more- I'm wanting better gas mileage and generally safer car for my college age daughter to drive when home. It doesn't even have ABS- it was an option.
#3593280 - 01/08/15 10:18 PM Re: Kreen treatment plan on 2004 Liberty 3.7l burner [Re: deanm11]
Finz Offline
Loc: Northern NJ
Thanks for the update dean... Was right there with you hoping for more success.
Good call on replacing the car for your daughter: ABS in NJ winters... A must
God Bless America... We really need it about now
06 Odyssey
06 Civic coupe
05 Accord 2.4 sedan
11 Civic 1.8 sedan
98 Accord 2.3 sedan
