Found out that my F150 with the 5.0L Coyote needs the plugs done with only 48l on the clock. Figuring I'll get around to it when the weather breaks this spring, and other than finding a good deal on the plugs (SP-519?) I am curious if it matters what dielectric grease I use?
In the past I've used Syl-glide, but that does tend to dry out in this application. Can pick the the permatex stuff for a little under half the cost of the fancy motorcraft XG-3-A silicone grease- is there any reason to stick with the Ford stuff? Or to avoid the permatex?
