Anyone here gotten late life orthodontics?
by LoneRanger
08/29/16 12:30 PM
iPhone Touch Disease
by Pop_Rivit
08/29/16 11:22 AM
Windows RUN (tool) troubleshoot
by Triple_Se7en
08/29/16 10:58 AM
Spark plug gaps
by SpeedyG75VW
08/29/16 10:27 AM
Funny Craigslist ad
by Drew99GT
08/29/16 10:23 AM
Formula Shell dino
by Camprunner
08/29/16 10:05 AM
Linux Distro for laptop
by LeakySeals
08/29/16 09:24 AM
GM Pickup Trucks With G-80 Locker Read This
by Silverado12
08/29/16 09:12 AM
M1 EP 0w20, 12764 mi oci, 50302 mi 2013 RAV4
by SF0059
08/29/16 08:25 AM
AC blows dead animal smell with a huge vibration!
by puredata
08/29/16 08:04 AM
Oil consumption early vs. late in OCI
by skaughtz
08/29/16 08:03 AM
Kaepernick disses national anthem
by grampi
08/29/16 07:19 AM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
103 registered (74Scout, 1JZ_E46, 901Memphis, Al, 87sammy, AirgunSavant, 6 invisible), 1768 Guests and 9 Spiders online.
58952 Members
66 Forums
253721 Topics
#3274995 - 02/08/14 04:01 PM CCV Filter
JDW Offline
Loc: South
Not sure if the right place to put this , But thought I would post my setup for the CCV Filter , Helps very much under boost , even others that I know that have N/A engines benefit using them, Just 3k on my rebuild mine is dry as a bone.
Ford's & Wix filter's Amsoil 5W-30 SS
2014 Wix Master Tech
#3275030 - 02/08/14 04:35 PM Re: CCV Filter [Re: JDW]
bepperb Offline
Loc: Milwaukee, WI
Well it can't be a huge benefit if it's as dry as a bone...
But if I had a Direct Injection car this is certainly something I would consider. That unit you have certainly looks well built.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#3275153 - 02/08/14 06:22 PM Re: CCV Filter [Re: JDW]
CurtisB Offline
Loc: Edmonton, Alberta, Canada
That looks like a JLT PCV catch can unit? I did enough reading on catch cans before I did my own purchase/install, and the consensus was that the JLT catch cans don't work well. I have a two chamber UPR catch can on my '13 F150 5.0L and after only 1000 easy highway kms it caught a surprising amount of oil/fuel/water. I installed it using Goodyear emissions rated braided hose, and I also spliced and reused the OEM PCV quick connecters. The UPR unit is billet aluminum and pricey, but it's A+ quality and the results speak for itself.
P.S: This post would have been better off in the mechanical/maintenance forum list.
Install:
1000 km results:
2008 F150 XL 4.6L 2WD - FL820s, M1 AFE 0w20
2013 F150 STX 5.0L 4WD - FL500S, M1 5w20
#3275176 - 02/08/14 06:47 PM Re: CCV Filter [Re: JDW]
CurtisB Offline
Something else I noticed in your picture. Do you have that catch can plumbed from your valve cover inlet to the intake air tube? If so, that's why it's not catching any oil. PCV oil separators need to be plumbed from the PCV valve to the throttle body. The intake tube to valve cover is the PCV air inlet (clean air enters) and the PCV valve to throttle body is the outlet (oil vapors present).
#3275205 - 02/08/14 07:17 PM Re: CCV Filter [Re: JDW]
JDW Offline
Loc: South
I have a PVC one on order for good measure , Per my engine builder and he has built many a Supercharged 4.6 . Oil DOES make its way up there on that side . I have seen it and all have been with JLT units, Have not heard about the bad reviews on them but for my fellow MN12 owners they work well.
Pic before the rebuilt
Edited by JDW (02/08/14 07:22 PM)
#3306437 - 03/09/14 07:12 PM Re: CCV Filter [Re: JDW]
TiredTrucker Offline
Loc: Central Iowa
I am glad I put the Conceptual Polymer High Efficiency catch can on my pickup. In a little over 8000 miles, it has collected about 12 oz of oil and glop out of the PCV line from going to the intake. I think it would have caught more if the vehicle had not been parked in a heated garage most of the time for the night. I noticed a larger amount of condensation/oil goo the times that it had to sit out and start cold outside.
http://www.conceptualpolymer.com/High%20Efficiency%20Air.htm
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
