How do you politely say no to people?
by motor_oil_madman
Today at 12:39 AM
To change or not?
by ram_man
Yesterday at 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
Yesterday at 11:20 PM
Camaro "How its Made" TV show Observations
by SumpChump
Yesterday at 11:08 PM
Wondering if sitting with few quick starts degrad
by corndogzombie
Yesterday at 10:51 PM
whole hog cook w/ pics
by 04SE
Yesterday at 10:12 PM
redo a/c in 1994 dakota 2wd
by bmwjohn
Yesterday at 09:37 PM
How to post UOA's on here?
by motor_oil_madman
Yesterday at 09:34 PM
Remanns Brand Remanufactured engines
by TiredTrucker
Yesterday at 09:11 PM
Best long lasting door hinges lurbicate ?
by MetalSlug
Yesterday at 08:59 PM
How do you clean trunk area (not inside the trunk)
by MetalSlug
Yesterday at 08:57 PM
Gas prices do the ol' switcheroo
by grampi
Yesterday at 08:44 PM
jractk, LatitudeDancer, AKN, NickGB, Marcusd1979
58645 Registered Users
13 registered (bbhero, EchoTech1945, Garak, jgeorge, DemoFly, 2 invisible), 923 Guests and 7 Spiders online.
58645 Members
66 Forums
252428 Topics
#3274854 - 02/08/14 01:25 PM 2004 Ford 6.0
highland512 Offline
Loc: Louisiana
Just had this test run on a sample of my Rotella T 15w-40 run in my 6L powerstroke. I went 7,500 miles on this change, I would say 90% of these miles are highway miles. Truck truck had 140,000 at this change. So how does the sample look? This is the first test I have ran on this truck so I have nothing to compare it against.
#3274866 - 02/08/14 01:34 PM Re: 2004 Ford 6.0 [Re: highland512]
DNVDMAX Offline
Loc: Alaska
I think your machine looks like it's doing well. The norm seems to be that slight shearing of viscosity is acceptable with a HEUI fuel delivery system.
Has this truck been bulletproofed? Headgaskets, headstuds, oil cooler and EGR cooler?
Edited by DNVDMAX (02/08/14 01:34 PM)
06 GMC 2500HD DMAX EFILIVE M1 TDT 5w-40 K&N
12 VERSA SEDAN M1 EP 5w-20 Purolator P1
91 GMC K1500 5.7L Maxlife 10w-40 WIX
#3274879 - 02/08/14 01:44 PM Re: 2004 Ford 6.0 [Re: DNVDMAX]
highland512 Offline
Loc: Louisiana
No this truck has been maintained and taken care of. Previous owner had a egr cooler, oil cooler, and all injectors replaced under ford warranty. When I bought the truck he also gave me a journal he had kept on the truck, it had everything right down to when he replaced the windshield wipers. I have owned it since 86,000 miles, I have maintained it much like he did but I am playing around with extending the OCI from 5,000 to 7,500. I have installed a coolant filter with elc, SCT TS livewire monitor, and a 5" exhaust. Oil temp / coolant temp delta stays around 8-10*, EGR is shut off, and I have had 0 troubles in 55,000 miles.
#3276280 - 02/09/14 07:36 PM Re: 2004 Ford 6.0 [Re: highland512]
dnewton3 Offline
Loc: Indianapolis, IN
Your wear looks quite acceptable; nothing to worry about there.
Since your truck has had the biggest issues already dealt with, then I strongly encourage you to get a coolant filter installed; that will make your engine well protected from a repeated failure. The root cause of most 6.0L ills can be traced to the oil cooler becoming blocked on the coolant side. Fresh coolant and a coolant filter pretty much assure the problem will never arise again.
Edited by dnewton3 (02/09/14 07:37 PM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
