MicroGreen filter at 8,114 miles
by Rex
45 minutes 22 seconds ago
Opinions on this 2006 Lincoln
by Milkman
Today at 01:40 PM
I'm sure these have been posted before but...
by Yup
Today at 01:24 PM
Weedeater nylon string cartridge doesn't feed out
by 69GTX
Today at 01:23 PM
Larger Oil Filter for 2006 Highlander 2.4 Four Cyl
by Samzone
Today at 01:01 PM
I bought a Stihl weed trimmer, but...
by skyactiv
Today at 01:01 PM
2010 Tacoma oil selection help
by bchannell
Today at 12:52 PM
Will this "Universal" coolant work on my Car?
by Miller88
Today at 11:37 AM
Repelling heat
by mjoekingz28
Today at 11:27 AM
Wrong Dipstick? Honda Accord 2.4 Reading Low
by ThirdeYe
Today at 09:09 AM
radiator hose install, 08 Matrix.
by JustinH
Today at 08:56 AM
Bendix CT-3 Brake Pads
by RevelationLion
Today at 08:38 AM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
63 registered (aquariuscsm, bbhero, alan003, 69GTX, Bebop367, Atesz792, 12 invisible), 1893 Guests and 336 Spiders online.
58023 Members
66 Forums
249600 Topics
#3274207 - 02/07/14 08:37 PM Fluid Film for stuck fasteners
buck91 Offline
Loc: West Michigan
Just curious if anyone has tried fluid film as a penetrating oil for stuck nuts and bolts? Figured it creeps like crazy after application, but does so rather slowly, so maybe given time it would work well but that might mean quite a bit of time.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#3274306 - 02/07/14 09:37 PM Re: Fluid Film for stuck fasteners [Re: buck91]
JHZR2 Offline
Loc: New Jersey
Far too viscous. Id use something like PB, kroil, or apparently ATF thinned with acetone works too...
#3274316 - 02/07/14 09:44 PM Re: Fluid Film for stuck fasteners [Re: buck91]
demarpaint Offline
Loc: NY
Kroil would be my first choice followed by PB Blaster.
God Bless Our Troops
#3274356 - 02/07/14 10:23 PM Re: Fluid Film for stuck fasteners [Re: buck91]
oilboy123 Offline
Loc: Everett, Washington
I don't think that's the primary application of the product. Other things would be better.
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
#3308420 - 03/11/14 03:33 PM Re: Fluid Film for stuck fasteners [Re: buck91]
camelCase Offline
Loc: Southeastern, USA
Typically, you want a pretty low viscosity to get good creeping. Think that higher viscosity means more shear is needed to move the fluid, so with low viscosity the fluid will continue to move even with a minute amount of shear (gravity in this case).
I'd go with an actual formulated penetrating spray lube. There are so many uses for a good can of PSL that it's always worth the cost to pickup a can if you don't have any.
#3308516 - 03/11/14 05:07 PM Re: Fluid Film for stuck fasteners [Re: buck91]
buck91 Offline
Loc: West Michigan
Well the situation I had more in mind was on older, rusty nuts and bolts that you know you will need to remove one day, but there is no current need.
For example, strut bolts or other such fasteners on a used car which you know will get replaced eventually but that time has yet to come. To me, it would seem FF would creep nicely over time while not evaporating and rinsing off as readily as a penetrating oil. But that is untested.
2011 F150 4x4 5.0L
1980 Yamaha XS850G
