Here my oil analysis for an OCI of 9,194 miles on Mobil1 High Mileage 10W-30.
Looks like I can push it even a bit further.
Around 7,000 with this oil I added 2oz of LC20. I'm not sure if I should use LC20 based on these results with this oil. Would like to hear your thoughts.
[coded]
2004 Volvo V70 2.4NA
OIL TYPE & GRADE: Mobil 1 High Mileage 10W/30
OIL USE INTERVAL: 9,194 Miles
Miles on car: 109,504
COMMENTS:
From what we can see, it looks like you shouldn't have any trouble extending your oil changes. Universal averages are based on a ~5,500-mile oil run, so your metals are way below average on a per-mile basis, and that's a good sign that the engine has no issues. We found some sodium, which isn't an additive in Mobil 1, but it could be residual from a past oil. It could also be antifreeze, but we don't see any other signs of that.
As for the LC20, it's probably not hurting, but we doubt there's much benefit, either.
Your TBN is good at 2.1, so try 11,000 miles next oil.
ALUMINUM: 3
CHROMIUM: 0
IRON: 8
COPPER: 3
LEAD: 0
TIN: 0
MOLYBDENUM: 64
NICKEL: 0
MANGANESE: 4
SILVER: 0
TITANIUM: 1
POTASSIUM: 2
BORON: 19
SILICON: 4
SODIUM: 66
CALCIUM: 1031
MAGNESIUM: 521
PHOSPHORUS: 834
ZINC: 894
BARIUM: 0
PROPERTIES
SUS Viscosity @ 210°F: 59.1
cSt Viscosity @ 100°C: 9.96
Flashpoint in °F: 380
Fuel %: Antifreeze %: ?
Water %: 0.0
Insolubles %: 0.3
TBN: 2.1
[/coded]
[coded]
COMMENTS:
ALUMINUM: 3
CHROMIUM: 0
IRON: 8
COPPER: 3
LEAD: 0
TIN: 0
MOLYBDENUM: 64
NICKEL: 0
MANGANESE: 4
SILVER: 0
TITANIUM: 1
POTASSIUM: 2
BORON: 19
SILICON: 4
SODIUM: 66
CALCIUM: 1031
MAGNESIUM: 521
PHOSPHORUS: 834
ZINC: 894
BARIUM: 0
PROPERTIES
Water %: 0.0
Insolubles %: 0.3
TBN: 2.1
[/coded]
