Looking for info on two quick spray waxes.........
by demarpaint
05/01/16 04:43 AM
The Heroin Epidemic In The U.S....
by qwerty1234
05/01/16 01:28 AM
Air filter wrap
by Duffyjr
04/30/16 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
04/30/16 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
04/30/16 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
04/30/16 09:34 PM
What to use in 99 Buick Lesabre OCI?
by Duffyjr
04/30/16 09:26 PM
Help w/Transmission Drain/Fill 08 Honda CR-V 4wd
by klt1986
04/30/16 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
04/30/16 08:10 PM
Group 5 synthetic oil
by Brayden
04/30/16 08:07 PM
Pennzoil Ultra platinum at Walmart
by RubentheIowan
04/30/16 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
04/30/16 08:03 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
52 registered (Bandito440, bmod305, BobFout, bbhero, AirgunSavant, BobsArmory, 1 invisible), 801 Guests and 93 Spiders online.
57758 Members
66 Forums
248282 Topics
#3113110 - 09/02/13 10:07 PM What oil for a gear box with a wet clutch?
BruceL Offline
Loc: Wisconsin
Picked up a trailer mounted post hole digger. It has a Briggs motor that couples to the auger through a "wet" centrifugal clutch and a gear box. Nice design that allows for leveling and safe operation. I can't find any online info about it. I want to know what oil to put in the gear case that will allow the clutch to work properly. The machine is similar to this online image: Dig-R-Mobile post hole digger
#3113138 - 09/02/13 10:54 PM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
Brybo86 Offline
Loc: Chicago, IL
rotella would be my choice
08 Honda Accord EX-L 2.4L RP 0w20 116k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 178k
95 Yamaha Jog
86 Kawasaki 454Ltd Valvoline 20w50 18k
#3113157 - 09/03/13 12:03 AM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
Bandito440 Online   content
Loc: NYS
Rotella is great, or a motorcycle-specific oil that's designed specifically for wet clutches.
'14 Grand Cherokee EcoDiesel
Pennzoil Euro L & OEM filter
#3115405 - 09/05/13 06:17 AM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
Shannow Online   content
Loc: Oz
Mobil AGri 424 is an 80W gear oil with wet clutch capabilities
#3116685 - 09/06/13 12:03 PM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
camelCase Offline
Loc: Southeastern, USA
Any synthetic automatic transmission fluid around 90wt would work just fine for you. That wet clutch is going to shear the fluid up a bit - but it shouldn't have too large of a charge, so changes shouldn't break the bank.
#3123016 - 09/12/13 07:59 PM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
RDMgr Offline
Loc: USA
Why not use a TO-4 fluid. It's a gear and bearing oil with frictional compound compatibility. SAE 50 or 60 should work.
#3133147 - 09/23/13 08:02 AM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
camelCase Offline
Whichever you use, you will have to change it pretty consistently because that wet clutch is going to shear that oil down to a lower viscosity the more it is used.
Since it's just a gear box and not oil for that little motor, I'm get a high quality ATF fluid or similar and just go with it.
#3273123 - 02/06/14 09:44 PM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
Pistol_Pete Offline
Loc: Wisconsin, United States
The type of gearbox would be very helpful...like what kind of reduction? worm gear? I would start there and use a gear oil specific to the type of gearbox and then make sure it has a anti-friction modifiers for the wet clutch. You need more info to decide on proper recommendations.
#3296183 - 02/27/14 12:00 PM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
drolds Offline
Loc: KS, USA
Use a motorcycle oil w/o friction modifiers in 10W-30.
Dr. Olds
#3296228 - 02/27/14 12:29 PM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
Clevy Offline
Loc: Saskatoon canada
Rotella conventional 15w-40.
2006 Charger RT
Miles x 2 per oil filter
#3311420 - 03/14/14 07:25 AM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
supercity Offline
Loc: Australia
Castrol Agri Trans Plus 80w
#3335008 - 04/06/14 02:00 PM Re: What oil for a gear box with a wet clutch? [Re: BruceL]
ac_tc Offline
Loc: sweden
Universal tractor fluid.
STOU / UTTO.
Ask at the nearest farm shop.
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
